20 Most Recent Lenovo Z565 Notebook Questions & Answers
2answers
Z565 usb ports broken
talk to pc and repairman he should now.
1/5/2015 8:37:13 PM • Lenovo Z565... • Answered on Jan 05, 2015
Why would some keys on notebook computer stop working
try using duster (nitrogen gas spray). its just a high pressure spray that cleans out the stuff under neath the keys. are the keys sticky? if so, try pulling the keys off and cleaning them with rubbing alcohol(While its turned off)
8/14/2012 1:27:39 AM • Lenovo Z565... • Answered on Aug 14, 2012
I need to reformat my Z565 Lenovo, and i'm
Hi fritzc,
I see you want to reformat your Lenovo back to factory Defaults I believe.
To do so follow the instructions Below.
  • Turn your Lenovo OFF
  • Once powered Down look for the orrange Arrow beside the power button that will probably have a Pinhole Button beside it.
  • Once located you will need to press that Pinhole Button Down for mat least 5 seconds this will turn the Lenovo system ON.
  • You Should see Lenovo One Kwey Rescue System and a green Wallpaper made out of Leaves or Grass.
  • Select One key Recovery if not with the mouse use the keyboard Arrow keys.
  • Then after selecting one key recovery select restore from Initial Backup then press Enter
  • after selecting restore from Initial Backup you should get info about the restoration asking if you agree to the restoration setting everything to Default and that files will be deleted if so then click yes to begin the Restoration.
  • One key recovery takes at least 20 mins to 25 mins depending on the Hard drive Content and Hard Drive space that will be formatted back to defaults.
If One key CRecovery Fails then most Likely you will need to call Lenovo to be able to get the Recovery Disc sent you this will be Free since your OKR or One Key recovery isn't working but if it Does the disc will be sent in a different way, for the Disc to be Ordered the number to call is 1-877 737 1092 Operating Hours are Mon- Fri EST 10AM-11PM.
I hope this will be helpful.
Have a nice day
mvincentc
6/10/2011 10:40:07 AM • Lenovo Z565... • Answered on Jun 10, 2011
I brought a lenovo idea
- you need to send the system to lenovo's depot in grapevine texas
- call lenovo and avail an ADP or accidental damage protection $69
- do not tell them what happen
- call lenovo after 3 days and tell them that system is not booting to windows
- they will advised you to send the system to depot
- if you don't have ADP this will cost you around $300
5/23/2011 6:34:05 PM • Lenovo Z565... • Answered on May 23, 2011
No sound from internal speakers
Man check the sound card or look if the wires are disconnected or look that are speakers disabled in your computer thankzzzzzzzzzzzzzzzz
5/19/2011 1:07:45 AM • Lenovo Z565... • Answered on May 19, 2011
2answers
The z565 does not start
Welcome to Fixya
Try to power up the laptop usng the adapter only. Take out the battery then turn on the laptop using the adapter only. Double check also the light indicator infront of the laptop. Power light should be lit up when you use the power adapter. If the power light is not present then the problem could be the adapter itself or the mainboard of the laptop.
Let me know if yor have further questions.
Thank you for using Fixya! If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
3/17/2011 1:06:19 PM • Lenovo Z565... • Answered on Mar 17, 2011
Screen goes dead but able to project to external
There's nothing "user-replaceable" about the laptop's LCD screen.
Instead, take the computer to a qualified technician, for trouble-shooting, and maybe for replacement of the LCD screen.
2/12/2011 11:16:44 PM • Lenovo Z565... • Answered on Feb 12, 2011
Lenovo Y550P stopped charging battery
Check the Power Adapter and Outlet: Ensure that the AC power adapter is securely connected to both your laptop and a functional power outlet. If your laptop has an AC power indicator light, make sure it's illuminated. If not, try a different wall outlet (avoid using a power bar) . Battery Charge Stops at 60%: If your battery charge stops at 55%-60% and shows a "plugged in, not charging" message, it might be due to a power management setting. Some Lenovo laptops have a feature that limits battery charging to extend battery life. To disable this: For models with Lenovo Energy Management, Lenovo Power Manager, OneKey Optimizer, Lenovo Settings, or Lenovo Vantage: Check if "Conservation Mode" is turned on. If so, turn it off. If the issue persists, try updating your laptop's BIOS: Go to the Lenovo support website, download the latest BIOS for your model, and install it. Reboot your PC and check if the problem is resolved. Hard Reset: Sometimes a hard reset can help resolve charging issues: Shut down your computer. Remove the battery (if detachable). Hold down the power button for 30 seconds (with the battery removed). Reattach the battery, plug in the AC adapter, and turn on the computer. The battery should start charging . If these steps don't solve the problem, there might be other causes.
4/1/2024 3:48:51 PM • Lenovo Computers... • Answered on Apr 01, 2024
I am using lenovo y510p gaming series laptop, when I try to play RDR2 game. It gives error that your drivers need to be updated.
In that case I would go onto the Lenovo web site and update the drivers. Never download drivers from other sources!
3/27/2024 4:44:19 PM • Lenovo Computers... • Answered on Mar 27, 2024
2answers
How to connect an onn wireless mouse to a lenovo chromebook? i tried doing this 3 times and still wont connect.
Firstly, try turning over your Bluetooth mouse and find the power switch. Make sure it's turned to ON. You should see the optical light turn on (usually red). Place the mouse back flat on your mouse pad. On your Chromebook, select the lower right corner of the taskbar. In the window that pops up, select the Bluetooth icon. If the Bluetooth status is currently off, enable the toggle switch to enable Bluetooth. Once enabled, you'll see a scanning status as your Chromebook looks for active, nearby Bluetooth devices. When your wireless mouse appears, you can select it to pair and connect to it. Once your Chromebook has made its connection with your Bluetooth wireless mouse, you'll notice the mouse pointer moving when you move your mouse
2/19/2024 8:12:43 PM • Lenovo Computers... • Answered on Feb 19, 2024
How to fix slot has been permanently lock lenovo s90-a
how to remove sim slot permanently lock in lenovo s90-a
11/26/2023 11:35:16 AM • Lenovo Computers... • Answered on Nov 26, 2023
Lenovo ThinkPad L510 boot menu disabled
Repeatedly tap the F1 key when the Lenovo, ThinkPad, ThinkStation, or ThinkCentre logo appears, The computer may beep once to indicate that it will boot to BIOS. How to Enable Boot device List F12 Option The following example shows a system that has an option to enable or disable the Boot device List F12 Option. Go into the BIOS to enable Boot device List F12 Option (option is usually under the Startup tab).
11/25/2023 6:18:45 AM • Lenovo Computers... • Answered on Nov 25, 2023
2answers
How do I take a screenshot with Lenovo SK-8821 keyboard?
It is very simple. Just press window key and then press PrintScreen key simultaneously. OR you just press PrintScreen key And then open paint Then press ctrl+v it will paste your screenshot. and then save it.
11/18/2023 6:00:48 PM • Lenovo Computers... • Answered on Nov 18, 2023
How to remove keypad from Lenovo thinkpad
Removal steps of keyboardLoosen the screw to the unlocked position to unlock the keyboard frame. Turn over the computer. To reveal the screw heads beneath the frame, use the flat-head screwdriver to slide the keyboard forward by 2.5 mm (0.1 inch). Use the cross-head screwdriver to loosen the screws.
Removal and installation steps for keyboard - ThinkPad T470s
11/5/2023 12:30:23 AM • Lenovo Computers... • Answered on Nov 05, 2023
3answers
Can we undo window 7 anytime upgrade
no once you have upgraded, it cannot be degraded to the previous version. and do you think this will solve the issue? you had the same problem even before with windows 7 home basic genuine version,then how could you think about this problem.let me tell you that genuine or piracy version of windows does not harm the machine but it is *********** board which is creating problem.this symptom "sudden shutdown" suggests that you need to change *********** board if it is not repairable.
7/29/2023 6:22:17 PM • Lenovo Computers... • Answered on Jul 29, 2023
Refurbished Lenovo w/MS Office 365 stuck in loop.
This commonly happens with pirated software. Remove Office 365 and try a fresh install.
7/13/2023 6:45:50 AM • Lenovo Computers... • Answered on Jul 13, 2023
Lenovo ThinkVision monitor T27h-2L not working with my Thinkpad P50 laptop. Monitor not detected. Just goes into Standby mode.
There could be several reasons why the Lenovo ThinkVision monitor T27h-2L is not working with the Thinkpad P50 laptop. Here are some possible solutions: 1. Check the connections: Make sure that the USB-C cable is properly connected to both the laptop and the monitor. Try using a different USB-C cable to see if that resolves the issue. Also, check if the USB-C port on your laptop is functioning properly. 2. Update drivers: Ensure that you have installed the latest drivers for both your laptop and monitor. You can download the latest drivers from Lenovo's website. 3. Change display settings: Sometimes, changing the display settings can help resolve issues with external monitors. Go to "Display Settings" on your laptop and select "Extend desktop" or "Duplicate desktop" to see if that helps. 4. Reset monitor settings: If none of the above solutions work, try resetting your monitor to its default settings. To do this, press the "Menu" button on your monitor and navigate to "Factory Reset." If none of these solutions work, it's possible that there may be a hardware issue with either your laptop or monitor. In this case, you may need to contact Lenovo support for further assistance.
6/21/2023 8:17:32 PM • Lenovo Computers... • Answered on Jun 21, 2023
2answers
How do I factory reset my Lenovo think pad it doesn't have novo key
If your Lenovo ThinkPad doesn't have a Novo key, you can still perform a factory reset using the Windows installation media. However, please note that this process will erase all data on your computer, so make sure you have backed up any important files before proceeding. Here are the steps: Create a Windows installation media (USB or DVD) using another computer. You can download the Windows installation files from the Microsoft website and use the Windows Media Creation Tool to create the installation media. Insert the Windows installation media into your Lenovo ThinkPad and restart the computer. Press the F12 key repeatedly to enter the boot menu. Select the Windows installation media and press Enter. Follow the on-screen instructions to install Windows. When you reach the "Where do you want to install Windows?" screen, select the partition that contains the current Windows installation and click "Delete." This will erase all data on the partition. Continue with the Windows installation process until it completes. When prompted, set up a new user account and password. Once Windows has finished installing, make sure to install all necessary drivers and software for your Lenovo ThinkPad. Note: If you don't have a valid Windows license key, you will need to purchase one before performing the factory reset.
4/10/2023 8:47:26 PM • Lenovo Computers... • Answered on Apr 10, 2023
User Profile Service service failed after factory reset and unable to access troubleshoot services: Windows 10
It seems that your computer is stuck in a boot loop and you are unable to access the troubleshoot services. Here are some steps you can try to resolve the issue:
  1. Disconnect all external devices from your computer, except for the keyboard and mouse, and restart the computer.
  2. If that does not work, try to access the Advanced Startup Options by holding down the shift key while clicking on the Restart option in the Start menu.
  3. If you are unable to access the Advanced Startup Options, you can try to create a Windows 10 installation media on a USB drive using another computer and then boot your computer from the USB drive.
  4. Once you are able to access the Advanced Startup Options, you can try using the Startup Repair tool to fix any issues with the boot process.
  5. If that does not work, you can try using the System Restore tool to restore your computer to an earlier point in time when it was working properly.
  6. If none of these steps work, you may need to consider reinstalling Windows on your computer.
It is also possible that there is a hardware issue causing the problem, in which case you may need to take your computer to a professional for repair.
3/18/2023 6:46:05 PM • Lenovo Computers... • Answered on Mar 18, 2023
Lenovo Z565 Notebook Logo
10 questions posted
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lenovo Computers & Internet
Most Popular Question
need reformat z565 lenovo 39 m
  • Computers & Internet
