20 Most Recent Koss KS4102 System Questions & Answers
0answers
I have a koss ks4102
Source the TV-related audio from the Cable Box,. Treat it like any other audio device.
3/14/2011 10:36:53 AM • Koss KS4102... • Answered on Mar 14, 2011
How do i get sound from my tv to my surround sound
Make sure the cables are hooked into AUDIO OUT from the TV and AUDIO IN from the reciever.
3/14/2011 4:29:56 AM • Koss KS4102... • Answered on Mar 14, 2011
How do you hook up from receiver to tv
How do you hook up receiver to tv
3/12/2011 11:02:48 PM • Koss KS4102... • Answered on Mar 12, 2011
My remote control for Koss dvd player [KS4102]
1)take the remote & check in electronic market (or)u can get universal remote.
6/3/2010 6:00:18 PM • Koss KS4102... • Answered on Jun 03, 2010
0answers
When i try to play dvd it wont read it then it
is it dvd drive or cd drive man .......
4/24/2009 6:34:13 AM • Koss KS4102... • Answered on Apr 24, 2009
How to set up koss dig home theater dvd to my tv
Just use rca cables
4/8/2009 6:30:57 AM • Koss KS4102... • Answered on Apr 08, 2009
Audio
all KOSS unit i encountered are power amp ICs problem, might be yours. usually what comes first dead is the subwoofer channel. try, take that IC off first, and if it doesnt work, look for 10ohm resistor along the supply line going to the IC. to know where to find the supply pins, download the IC specs on the web such as http://alldatasheet.com/. be careful when removing the IC, this is not an easy job as I handled it. The IC is under the heatsink. once you found the bad IC, the unit will on except that channel you have pulled the part off. its a surface mount IC, if your not use to solder components such as 0402 sizes, i would suggest to have it repaired on technician. hope this help.
4/5/2009 1:57:43 AM • Koss KS4102... • Answered on Apr 05, 2009
Cannot find dvd code for my koss dvd player
the three digit codes are 216 or 573
3/15/2009 7:22:26 PM • Koss KS4102... • Answered on Mar 15, 2009
3answers
Koss KS4102 audio delay problem
You can get the update file from here. http://www.kevinschaefer.net/upgrade.zip. Good Luck and let us know how this turns out for you.
3/11/2009 6:59:50 AM • Koss KS4102... • Answered on Mar 11, 2009
Can't get remote to work
Since you don't know which end is defective, you might take the remote to about any store that sells and services consumer gear; they will have a primitive sensor that can detect if the remote is putting out some infrared but the common type of detector cannot tell you if the coding is correct or not.
If you find though that the remote is putting out anything at all, it is probably working properly.
Unfortunately that will mean that the receiving end is bad and that will be more costly to have repaired.
A handy device can be had for $10 US here:
http://www.ersweb.com/Infratector.htm
3/9/2009 1:50:43 AM • Koss KS4102... • Answered on Mar 09, 2009
Koss ks4102 pal/ntsc output
try to unplug the system for about 20min to see if it will reset the system
12/18/2008 9:44:57 PM • Koss KS4102... • Answered on Dec 18, 2008
Problem with surround working with just the t.v. on
What type of plug from the TV are you hooking up to the sound system? Its has to be a HDMI or a scart. If its not and your using the rca red and white. The reciver has to be on the synth surrond setting or look in the owners manual, it will tell you what setting the reciver has to be on when using a non surround set or hookup
11/30/2008 5:44:12 PM • Koss KS4102... • Answered on Nov 30, 2008
Video difficulty
You've probably given up on getting an answer since it has been some months but in case you haven't axed both yet . . .
You might try the DVD player on someone elses TV to isolate the problem to the player or the TV.  Or the reverse; one of the two is not synchronizing right and it is the TV's job to tweak itself to lock the picture from an external source.  It is unusual for any modern TV to have problems synchronizing with another device, even if they aren't too stable so I would suspect the DVD player first.
10/3/2008 12:06:41 AM • Koss KS4102... • Answered on Oct 03, 2008
DVD DOOR
Mine does the same...i dont no how to fix it correctly but whenever i hold my tray in and dont let it pop back out it will read my disks...not really a solution but it works
1/4/2008 6:43:26 PM • Koss KS4102... • Answered on Jan 04, 2008
Dvd's
DVD-R
DVD-RW
DVD+R
DVD+RW
CD (Audio)
CD-R
CD-RW
S/VCD
There ya go! Easy info. Have a good one. :)
Cyryl
12/7/2007 2:40:59 AM • Koss KS4102... • Answered on Dec 07, 2007
Koss KS4102 System Logo
29 questions posted
Popular Products
Top Koss Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Eric
ADMIN Eric
techdaipy
techdaipy
Level 1 Expert
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Koss Audio Players & Recorders
Most Popular Question
set up koss dig home theater dvd tv
  • Audio Players & Recorders
