20 Most Recent Vivitar V7028 Digital Camera Questions & Answers
You can download the manual here. Admittedly, the Vivitar site sometimes has problems, but I just successfully downloaded the full manual minutes ago. If you still can't get it, try again the next day.
Vivitar V7028... | Answered on Nov 01, 2011
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Vivitar V7028... | Answered on Jul 24, 2011
NO A DIFFERENT MODEL OPTION WILL NOT WORK WITH YOUR CAMERA. UNINSTALL THE COMPLETE SOFTWARE THAT YOU HAD INSTALLED AND REINSTALL IT AGAIN WITH THE DRIVERS .CONNECT THE CAMERA AFTER THE INSTALLATION IS COMPLETE.
REGARDS.
PLZ. DONT FORGET TO RATE MY SUGGESTION
Vivitar V7028... | Answered on Jul 06, 2011
The 7028 does record video, but without sound.
Vivitar V7028... | Answered on Feb 17, 2011
Where can I get a CD to run and load on to the computer to download my pictures?
Vivitar V7028... | Answered on Jan 09, 2011
If your camera won't turn on, first of all try to charge your batteries until it's fully charged. If this doesn't solve your problems, check if your battery pack is busted by using your power supply to turn your camera on. If using a power supply solves your problem then consider replacing the battery of your digital camera.
Vivitar V7028... | Answered on Dec 26, 2010
just push and slide away from the camera?
Vivitar V7028... | Answered on Dec 21, 2010
You can download the manual from the manufacturer's web site at
http://vivitar.com/files_products/436/ViviCam_7028_Camera_Manual.pdf
Vivitar V7028... | Answered on Dec 08, 2010
ViviCam X014 Digital Camera - Vivitar
www.vivitar.com > files_products > ViviCam_X014_Camera_Manual
PDF Vivitar makes capturing those special moments as easy as possible. Note: Your camera needs an SD Memory card (up to 32GB) for normal use. SD Memory cards are not included and need to be purchased separately. Please read this manual carefully first in order to get the most out of your digital camera.
Vivitar Cameras | Answered on Mar 09, 2020
As this forum is for cameras, it is unlikely we can help. Try an alternative forum.
Vivitar Cameras | Answered on Jan 04, 2020
NEVER HAD A CAMERA THAT YOU COULDN'T .
Vivitar Cameras | Answered on Dec 17, 2019
could be a stuck (broken) lens, broken CCD or broken LCD cable. (white light means backlight is working) I would suggest taking it to a repairman.
Vivitar Cameras | Answered on Dec 02, 2019
I presume you mean the software relating to this camera does not install.
Is the software the correct version for your OS ?
Vivitar Cameras | Answered on Oct 30, 2019
ivitar Entries
Vivitar Cameras | Answered on Oct 20, 2019
All digital cameras have an internal battery that you cannot change. When the battery fails you have to send the camera in for repairs.
Vivitar Cameras | Answered on Sep 27, 2019
Do you mean the Vivitar ViviCam X014N? If so, the battery compartment is on the right hand side as you look back of the camera with the view screen and menu buttons. The cover on the battery compartment will rotate up from the bottom of the camera when opened. This is shown in the manual although it isn't completely clear. The current link to the manual for the ViviCam X014 is http://www.vivitar.com/files_products/445/ViviCam_X014_Camera_Manual.pdf . See pages 3-4 for the pictures of the battery compartment location. Note: the N suffix refers to the case color. The manual applies to any ViviCam X014.
I hope this helps.
Vivitar Cameras | Answered on Sep 01, 2019
Vivitar V7028 Digital Camera Logo
11 questions posted
Top Vivitar Cameras Experts
Ekse
Barbat Nae
Barbat Nae
Jeffrey Groves
Jeffrey Groves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
View Most Popular
Vivitar Cameras
  • Vivitar Cameras
Most Popular Question
camera dosent turn
  • Cameras
