20 Most Recent
Jensen JBD-100 UNIVERSAL BLUETOOTHR CLOCK RADIO Questions & Answers
Jensen jbd-100 change clock
Take battery out and unplug to force a reset.
Hold Display until it starts flashing 12 hr
----use tuning buttons if you need to change that to 24hr
Tap Display to confirm setting and move to next stage
Repeat the same steps of tap Display and then use tuning to adjust up or down for the hour and minutes.
Make sure to increase hour setting enough to have the "pm" show up for times after noon when using 12 hr format
How to set time on jensen jcr-425
To set the time on a Jensen JCR-425 clock radio:
- Press and hold the "Time Set" button until the display flashes.
- Press the "Hour" and "Minute" buttons to adjust the time.
- Press "Time Set" again to confirm.
Jensen Compact Disc Music system JMC-500W. Open/Close button not opening the lid
Please hold down the open/close button instead of just pressing it. Then you can press the lid while this is happening. I think you might already suspect this, but it sounds like the hook that connects to a portion of the lid isn't unhooken during the button press. Friction might be a cause or the hook-movement might not be functioning as smoothly due to other factors.
If the issue continues, we might have to consult Jensen on a potential repair/replacement of the item as well.
