20 Most Recent Konica Minolta Minolta FAX3900 Digital Copier, Copier/Fax Machine 16 ppm printing and up to 600 dpi resolution, rec... Printer Questions & Answers
Service manuals electronic components datasheets and equipment schematics...
try this for the service manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Mar 10, 2018
Which cartridge there are two one is toner the other is the drum which is where the toner cartridge is installed.
Konica Minolta... | Answered on Dec 25, 2016
clean the rollers with small amount of water and soap or replace them also check the path use a business card to push through the area where the paper bends to go under neath
have a tech come out hard to over the internet
Konica Minolta... | Answered on Jan 18, 2016
toner and drum are separate the toner attaches to the drum unit.
Konica Minolta... | Answered on May 26, 2015
what do you mean stop. unplug fax line. press stop/clear button don't fax
Konica Minolta... | Answered on May 25, 2015
PROBABLY BAD PHONE LINE, CAN TRY SOME OF THE FOLLOWING
SLOW DOWN THE RX TO 1700
TURN OFF ECM
INSTALL DSL FILTER EVEN IF ITS NOT A DSL LINE
MAKE SURE THE PHONE COPANY KNOWS ITS A FAX LINE
IF ITS VOIP IT MAY NEVER WORK WELL
RESEAT ALL CONNECTORS IN FAX 3900
TRY SETTING TO MMR
MAY ALSO BE PROBLEM WITH THE SENDING FAX MACHINEOR, THERE PHONE LINE
Konica Minolta... | Answered on Aug 30, 2013
USER MANUAL Page 3-34
Press STATUS key 3 times. Press YES. Press UP and DOWN keys to select the report you wish to print.
TX Result Report The document number, recipient name, date sent, starting time of transmission, number of document pages, time required, mode.
RX Result Report The document number, caller name, date received, starting time of reception, number of pages received, time required, mode, and reception result are printed.
The machine can also be set to print this report automatically after every 60 transmissions/receptions.
Konica Minolta... | Answered on Feb 25, 2011
1. Turn the machine OFF.
2. Press and hold the STOP key.
3. Power the machine ON and release STOP after 5 seconds.
d/c stands for drum cartridge. It's the unit your toner slides into.
Konica Minolta... | Answered on Aug 06, 2010
just change the date under utilities, initial user data, date& time
Konica Minolta... | Answered on Jul 28, 2010
I have a Minolta Fax 3900 and it at times while trying to send a fax will say *tx cancel* and only send 2 pages of a fax. It appears like it does send the fax but it might not be the complete fax. I can't cancel the fax or stop it either. Does anyone know how to fix this problem.
Konica Minolta... | Answered on Apr 30, 2010
29 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
konica minolta fax 3900 showing error
  • Office Equipment & Supplies
