20 Most Recent
Minolta DiALTA Di181 Printer Questions & Answers
Dialta di181 clear M4 error code
M-4 replace the drum it has reach the max of 80,000 copies. replace the drum then clear the counter. just clearing the counter will not be good the machine knows when the counter is clear it has a new drum and will adjust High voltages accordingly if the old drum is in there then you get code and image problems
try web site below for part start with drum being replace recommend the cleaning blade also be replaced. Don't for get to clear the counters first install the drum and run F5 Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
Minolta di181 0000 service call
Check the rear of the machine looking at it remove the cover left side motor is bad or the control board that feeds it. But check also the front of the machine the fuser THE HOT PART it may be jammed or gears are broken that motor turn the fusing unit open close front door to reset Btw, I’m available to help over the phone in case u need at
Code m4
a maintenance counter has to be cleared. this can only be done by a technician
