20 Most Recent 04-05 Sg5 Front Lip Ds-Style Urethane Questions & Answers
Clarion cz301e
You can purchase a harness adapter that will plug into the original radios harness. The other end of the adapter harness has loose wires with tinned ends which you connect to the new radio's harness, which as the same colors as the adapter wires.
  • Metra Model: 70-8901 is one adapter that I believe will work.
  • Scosche item Number: 16845632 is another adapter.
  • If you want to buy locally, Best Buy will probably have one or the other. If you want to buy on line, just do a search for the name and model numbers.
Subaru ForesterReceiver Wiring Harness
5/13/2014 3:52:55 AM • 04-05 Sg5 Front... • Answered on May 13, 2014
Subaru bulldog starts and runs for 10 seconds and quits
You have a fuel related problem. It sounds like a faulty fuel filter or a fuel pump or a possible leak in th fuel line. I hope this helps.
4/10/2017 6:54:22 PM • Subaru Vehicle... • Answered on Apr 10, 2017
tip
Subary(2010 Outback) ignition key remote door lock function
My 2010 Subaru Outback (Euro spec) has for a long time been bugged with intermittent functioning of the kemote unloc/lock of the ignition key. I changed the battery several times, mistakenly thinking this was the cause. However, when I disassembled the remote unit of the ignition key, I found that the battery contact for the positive pole had come loose from the printed curcuit Board, given intermittent power to the module. I turned out that the printed curcuit Board can be extracted by gently prying open the Remote unit holding the battery and the Electronics inside. The battery pole contact can then be soldered back in place as a remedy of the problem. As this had happened to both keys fairly parallely I suspect a production or design flaw. Anyway, soldering it back up saved me a lot of money for potentially replacing both keys/Remotes. The attached pictures are marked up with repair advise for anyone who wants to give it ago with the soldering iron.
Electronic unit retrieved from key unit
on Jul 12, 2016 • Subaru Cars & Trucks
WHAT IS THE BELT ALINEMENT
dont you mean tension and what is it on
9/6/2014 2:22:23 AM • Subaru Vehicle... • Answered on Sep 06, 2014
How to replace 1994 subaru outback abs tone ring
YOU HAVE TO PRESS THE HUB ASSEMBLY APART AND REMOVE THE ALLEN BOLTS. I THINK THEY ARE FIVE MM. THEN INSTALL THE NEW ONE AND REPLACE THE WHEEL BEARING AND PRESS IT BACK TOGETHER AND INSTALL BACK ON THE CAR.
8/25/2014 6:35:16 PM • Subaru Vehicle... • Answered on Aug 25, 2014
Tronk want open with push botton
open the trunk manually and look at the latch the should be a lock out tab that's probably pushed down. push it up and it will work.
8/20/2014 12:19:56 AM • Subaru Vehicle... • Answered on Aug 20, 2014
3answers
Do i have to take cambelt of to change water pump on subaru impreza
try thermostat as water punp would be leaking or sqealing if it was the water pump check all cheap things first 99% thermostat is stuck
8/17/2014 5:39:28 AM • Subaru Vehicle... • Answered on Aug 17, 2014
Where is the cooling sensor for a subaru impreza?
Most Subaru's have the cooling sensor in the coolant connection pipe that runs under the intake manifold and connects the LH and RH engine cooling galleries. There are different colour sensors, what meant they have a different resistance to meet the temperture gauge, make sure you fit the same colour.
6/12/2014 1:42:54 AM • Subaru Vehicle... • Answered on Jun 12, 2014
I have a 98' impreza outback sport, and ABS with a bad ball joint. Would spindle work from similar legacy wagon?
easiest way to find out is call the part store and have then cross reference part #s. you just need to know the year/engine and if it's 2,4,or awd of both cars. Should be quick and easy
5/22/2014 4:02:37 PM • Subaru Vehicle... • Answered on May 22, 2014
Are 1998-2003 Subaru drive shafts the same for all models of that era?
Not necessarily they could differ check your VIN and cross reference it with Subaru parts dept
3/2/2014 6:23:47 AM • Subaru Vehicle... • Answered on Mar 02, 2014
Trunk wont open
It should open with the key even if the cable won't. Does the lever have the same feel to it or does it seem like it isn't connected any more?
1/11/2014 4:36:11 AM • Subaru Vehicle... • Answered on Jan 11, 2014
Torque converter wont seat in the orgiinal place
Torque converter has to click twice while turning it to sit in position.
1/6/2014 12:29:44 AM • Subaru Vehicle... • Answered on Jan 06, 2014
Broken trunk womt open eather by latch or key
Can you remove back seat and go thru there with flaslight and open from there.
12/28/2013 5:07:38 PM • Subaru Vehicle... • Answered on Dec 28, 2013
Subaru transmission 4EAT , wont shift into D or
I HAVE YOU TOP UP transmission FUILED THIS HAPPEND TO ME I TOP UP ALL OK
9/29/2013 2:15:28 AM • Subaru Vehicle... • Answered on Sep 29, 2013
Why is there no idling when starting cold?
What kind of vehicle do you have Anne,year,make,model and engine size?
10/31/2012 6:58:40 PM • Subaru Vehicle... • Answered on Oct 31, 2012
2answers
99 imreza... 102k miles
Hello and welcome to FixYa!
You may just have system failure. As a first course of action, I strongly suggest that you remove the positive battery connector and let it sit for atleast 5mins. before reconnecting it. This will reset the system and can get your vehicle back to it's normal operation.
Hope this helps and thank you for using FixYa! Have a good one!
8/18/2011 10:56:44 PM • Subaru Vehicle... • Answered on Aug 18, 2011
Need to know how to
If it's an Alpine system; turn the ignition on,off,on,off,on,off. The car can start on the fourth turn. If it's a Cod alarm:Programming or Overriding the Alarm when you have lost the remote Open driver's door. Turn ignition key to 'On' Press and *hold programming button* in (see diagram, button under dashboard) After 15 seconds the the door locks will cycle 3 times. Do not release Programming button Press lock (left) button the remotes to be programmed. The door locks will cycle one time. Exit programming mode by releasing Programming button under dashboard and turning key to off.  Code Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area. The botton is recessed in a plastic ring (see diagram). This button must be pressed while programming remotes or if the battery was disconnected and the lights are flashing.
4/4/2011 3:03:52 AM • Subaru Vehicle... • Answered on Apr 04, 2011
I started my car and it started in one go i waited
Check the O2 sensors, I had a problem before when my car would start but would stop shortly after and this was the culprit
3/3/2011 2:25:46 PM • Subaru Vehicle... • Answered on Mar 03, 2011
I unlock my car and
You will have to deactivate the security system first because the security is blocking the ignition or cutting the supply of fuel or the electrical system of the car. There is an error in the security settings of the car.
I will advice you reprogram the cars security settings to be able to use the car properly.
12/31/2010 10:03:20 PM • Subaru Vehicle... • Answered on Dec 31, 2010
04-05 Sg5 Front Lip Ds-Style Urethane Logo
1 questions posted
Top Subaru Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Subaru Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Subaru Vehicle Parts & Accessories
Most Popular Question
clarion cz301e
  • Vehicle Parts & Accessories
