20 Most Recent NexxTech ESDVD100 System Questions & Answers
Your only choice is to look it up on the NexxTech website.
NexxTech... | Answered on Dec 21, 2013
I had to gently clean the lense with a q-tip with just a hint of rubbing alcohol on it then move the laser carriage all the way out and in two or three times then play a CD for the player to work again. There was a fine layer of dust around the laser so I think that it may be very sensitive to that kind of thing.
NexxTech... | Answered on Jun 11, 2012
If you are faced with the TV set that has only antenna F type connector, Or alternately if just 2 screws, a "Balun" for TV is added for those to get the antenna type connection on the two screw types and you need to get what is called an "RF Modulator" that will convert the split up signal off the DVD player to the one antenna type terminal.
NexxTech... | Answered on Dec 21, 2011
If google and manufacturer website are of no help then ask a search agency like http://manualfox.com/remote.htm - They do a great job.
The service is not for free, but often worthy (you only pay if they find what you are asking for).
NexxTech... | Answered on Jun 18, 2010
You can try cleaning it with a dvd disk cleaner first. If that dont work by a cheap dvd player and run it to the inputs on the back of the surround player.
NexxTech... | Answered on May 24, 2010
change the disc spin motor
NexxTech... | Answered on Apr 09, 2010
I solved the problem by buying a new DVD player- wouldn't have been able to replace a motor, and repair cost is as much as a new purchase-the times we live in! Thanks for the info which helped me make the decision.
NexxTech... | Answered on Oct 24, 2009
Mine started doing this just the other day and stopped playing the DVD it was playing. I found a solution for a portable player that worked on this one. You need to open it, eject the tray and slide the laser carriage back and forth all the way two or three times gently and by grabbing on to plastic that hooks around the metal bar on the right if you are facing the player from the front. Then plug it in and play a CD all the way through and this recalibrates the laser.
I wonder how many people throw away their DVD players when this is all it needs. Makes me sick to think about it.
NexxTech... | Answered on Sep 26, 2009
Just wire your TV audio out to one of the receivers (DVD player) audio in and select AUX when you want the TV sound to play through the surround sound. You also might want to turn the volume down or off on your TV to get the full surround sound feeling, but that's your call.
NexxTech... | Answered on Sep 24, 2009
I have the same problem with my esdvd100 were it stop recoginze my dvd or cd. msg: No Disk
NexxTech... | Answered on Mar 02, 2009
Ok simply do this: "Google" your name of webcam plus the words Driver windows Download. EG: Mywebcam123 driver windows download The links provided will point ya to a download site where you can DL the driver, usually unzip and install.
NexxTech... | Answered on Jan 02, 2009
Someone on this site suggested a fix for a different player.  Open up the unit to get to the dvd changer.  If the disk are not aligned, then push them so they are even.  It may take a while to see where they are but it worked for me.
NexxTech... | Answered on Nov 30, 2008
You need to be sure to remove the discs from the disc changer and close the disc changer. Make sure that your TV is on the Blue Screen and it should say " Progressive Scan Mode" Press and hold the stop button on the unit....not the remote for 5 seconds or more and it should reset. However, if your TV is a Progressive Scan compatible TV, you may need to refer to the user guide for the TV as well....Many newer TVs Use a Progressive Scan Setup, but this solution should still work for you. Make sure all discs are removed FIRST!!!
NexxTech... | Answered on Jul 27, 2008
it would help to know what machine your playing these in . your media seems to be have recorded inna different format maybe your discs are not burned properly maybe theres a fault in your machine i would take it back to the shop or the media back the shop oh and if burning you must not use ne other program its probably your using media that is not finalized or your machine isnt designed to play them discs your using
NexxTech... | Answered on May 13, 2008
NexxTech ESDVD100 System Logo
27 questions posted
Top NexxTech Audio Players & Recorders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a NexxTech Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • NexxTech Audio Players & Recorders
Most Popular Question
nextech esdvd100 stoped recognise dvd cd
  • Audio Players & Recorders
