20 Most Recent Minolta magicolor 2200 EN Laser Printer Questions & Answers
tip
Cost Saving Advice
<ul> <li>Consider disposing of waste toner yourself<br />Waste toner is not environmentally friendly. But, instead of replacing the waste toner bottle, check with environmental experts in your area for what to do with the waste toner. It may be a simple matter of collecting the toner in a coffee can and turning it in somehwere.</li> <li>Never buy toner cartridges<br />Nothing about toner cartridges for this printer ever really wears out from normal use. And, refilling them is clean and easy once you know how. But, more importantly, it costs about <b>90% to 95% less</b>. </li> <li>Never replace parts just because the printer tells you to.<br />Serviceable OEM parts for this printer well outlast the printer's pushy insistance to replace them. All new serviceable parts come with a fuse. As soon as you install the part, the new fuse causes the printer to reset the page count for that part. Then, the printer blows the fuse. If the printer has been printing fine, but refuses to print because it claims a part must be replaced, remove the part, find the fuse, replace it, re-install the part, and voila!</li> <li>If a part really does need to be replaced, scavange parts from an abandoned 2200.<br />Chances are that plenty owners of this printer have gotten tired of replacing the over-priced parts.All you have to do is find one that has yet to dump the printer (like me... hint, hint).</li></ul>
Qms 2200 paper mismatch error
Initial Thoughts The problem seems to be a fault in a paper feed sensor. This would explain the size mismatch, since these sensors are how the printer detects the paper size. And, it would explain why printing starts two-thirds down the page, since these sensors are also used in timing where on the page to start printing. However, a document passes through three software applications before it actually prints. And, any one of them could be causing the paper size mismatch. Insight Although paper sensors are usually low-tech and easy to remedy, they are often difficult to find and can sometimes be difficult to get to. Most such sensors are simple switches (toggles) and others are optical sensors that work like the electric eye of a garage door opening system. And, the solution may be as simple as a tiny piece of paper stuck on one of them. However, sensors such as these are quite numerous on this printer and can be hidden anywhere. The three software applications I referred to are:
1. The document rendering application, such as Adobe Reader, Microsoft Word, etc.
2. The print writer. This is part of the device driver software package. It breaks up a print request and converts it to a standard format that the printer will always recognize and manages transmission of each page to the system spooler or directly to the printer.
3. The printer firmware. I'm not sure of everything this does related to the print stream. But, part of it must manage resources, such as ensuring the right size paper is being fed.
5/16/2011 8:10:31 PM • Minolta... • Answered on May 16, 2011
My Magicolor 2200 ghosts in color and in black.
This is a symptom of a well-used transfer belt. Replacing it should do the trick.
To verify: Check the transfer belt. The transfer belt is the large replaceable unit close to the center of the printer. It should have excess toner clinging to it. Don't bother trying to clean it off. It will just return the next time you print.
I'm currently looking for a way to squeeze a little more life out of it. But, am having no luck so far.
3/15/2011 12:33:36 AM • Minolta... • Answered on Mar 15, 2011
Download toolbox 940c
For what model sir/mam? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/8/2015 4:31:46 AM • Minolta... • Answered on Feb 08, 2015
Pagemaker 7 0
Are all of the image unit and color toner Minolta/QMS (OEM) not third party. Does the machine print the demo page OK? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/4/2015 11:03:24 PM • Minolta... • Answered on Feb 04, 2015
Konica minolta magicolor 8650
What about the machine showing a code or image problem you did not state the problem when you submitted the question. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/4/2015 10:55:31 PM • Minolta... • Answered on Feb 04, 2015
Konica minolta printer problems
What model and code is it displaying Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/23/2015 12:47:20 AM • Minolta... • Answered on Jan 23, 2015
Printer is printing all the pages on top of each other
What is the model and what is make? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/22/2015 11:23:38 PM • Minolta... • Answered on Jan 22, 2015
Paper size error on 1690mf
Machine mite be set for metric paper and computer printing in inch Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/29/2014 10:38:04 PM • Minolta... • Answered on Dec 29, 2014
Hi, can some one help me; i've error code 3b02 displayed in minolta c452
Sir/Mam, Turn off the main power switch, ensure the sub power switch is on. The sub power switch is located on the right side of the control panel. Then holding down the Utility/Counter button turn the main power switch on. Close the front door you must keep the Utility button down. The screen will show TROUBLE RESET touch it sees a "OK" then power off the machine. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back, you need a Fusing unit or a High Current Device for the fusing unit. Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE! THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!!
4/11/2021 10:42:47 PM • Minolta Office... • Answered on Apr 11, 2021
Konika minolta c554e error code C-3102. HOW DO YOU FIX THIS.
1 Check the fusing unit for proper installation and correct as necessary.
2 Check the connector between M3-PRCB CN2 for proper connection and correct as necessary.
3 Check the connector of M3 for proper drive coupling and correct as necessary.
4 PS37 I/O check, sensor check.
5 M3 operation check PRCB CN2-9 (REM) PRCB CN2-12 (LOCK) bizhub C554 22-J bizhub C454 21-J.
6. Replace M3.
7. Replace the fusing unit.
8. Replace PRCB.
9/4/2020 10:28:41 AM • Minolta Office... • Answered on Sep 04, 2020
2answers
How to fix Error Code C3901 on a Minolta Bizhub 420 copier
FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!! 1. Turn OFF the main power switch. Inside machine, leave sub-power switch on (Right side of control panel) 2. Turn main power switch ON while pressing the Utility/Counter key. 3. Touch [Trouble Reset]. 4. Check to make sure that [OK] is displayed and then it has been reset. 5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
8/23/2020 3:14:47 PM • Minolta Office... • Answered on Aug 23, 2020
How clear error message c2558 konika minolta bizhub 206
Check the drum and developer units
3/28/2020 7:10:04 PM • Minolta Office... • Answered on Mar 28, 2020
Conica minolta c7000, erro c-2452
Magenta developer unit and or motor has the developer for the Magenta been replaced was it done properly? Was developer unit replace?????
3/28/2020 7:09:28 PM • Minolta Office... • Answered on Mar 28, 2020
SIR KONIKA MINOLTA 165E PROBLEM C2558
Replace the drum and developer units
3/28/2020 7:01:56 PM • Minolta Office... • Answered on Mar 28, 2020
HOW TO CHOOSE PAPER TRAY ON MINOLTA cs pro ep 2050
You can copy from the bypass tray but not print. Go to the paper select and select bypass tray ensure paper is properly oriented.
3/28/2020 7:01:30 PM • Minolta Office... • Answered on Mar 28, 2020
What is soloution that after printing page automatically ink toner feed as per requirement.konica minolta 751 mODEL
The developer has not been changed and needs to changed. The drum also need to be replaced.
3/28/2020 6:59:35 PM • Minolta Office... • Answered on Mar 28, 2020
Minolta 2400W Wont try to feed paper.
IT is 16year old today, and there are no spare parts, for it. cept used on ebay. the blinking lights in the manual mean, toner cartridge dead or fake one installed. on page 11. if got it to work there are no windows 10 drivers, now. XP yes. see that page 11 states on errors. https://www.manualslib.com/manual/90066/Konica-Minolta-Magicolor-2400w.html?page=11#manual the service manual is here, https://www.manualslib.com/manual/805991/Konica-Minolta-Magicolor-2400w.html RTM?
3/4/2020 12:32:39 PM • Minolta Office... • Answered on Mar 04, 2020
Minolta magicolor 2200 EN Laser Printer Logo
3 questions posted
Top Minolta Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
Ekse
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Magicolor Minolta
  • Magicolor Minolta
Most Popular Question
magicolor 2200 ghosts in color in black
  • Office Equipment & Supplies
