20 Most Recent KitchenAid Architect II Superba EQ Series KUDE20FB Questions & Answers
Kitchenaid Superba Gas oven and cooktop. I frequently get a F2: E1 code, which goes away when I reset the fuse. Also, the 1, 4, and 7 touch pads don't work but all others do.
You have a bad touchpad. The ribbon cable is a failure point on all of these whirlpool built ovens. Enter the model number in at this link and see if they make a replacement keypad for your oven: Introducing the Ledgestone Technologies Touchpad
8/30/2016 7:03:27 PM • KitchenAid... • Answered on Aug 30, 2016
Fix f5 e 1
F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds. 2. Re-apply power and observe for at least one minute. 3. If code re-appears, replace control board (also called ERC or clock). Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
6/5/2015 12:40:14 AM • KitchenAid... • Answered on Jun 05, 2015
Code f5 e1 unlocked door
STOP SPAM!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
6/5/2015 12:39:46 AM • KitchenAid... • Answered on Jun 05, 2015
How to Fix E1 F5 code error
STOP SPAM!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
6/5/2015 12:39:15 AM • KitchenAid... • Answered on Jun 05, 2015
I have the Kitchenaid Superba Convection wall oven Model KEBS207DBL1 and it won't stop beeping. Shows error code F2 e3 at times. Is there a fix?
This typically indicates an issue with the touchpad or control board. Here are some steps you can take to troubleshoot and potentially resolve the issue: Check the Cable Connection: The error code could be due to the touchpad cable being unplugged. Ensure a proper connection between your appliance's touchpad and the control board. Power Reset: You can try resetting the oven by turning off the fuse or circuit breaker, waiting for 1 minute, and then turning it back on. Repeated power restarts may allow the oven to reset and resolve the issue. Replace the TouchPad or Control Board: If the connection is fine and the error code persists, the issue might be a malfunctioning touchpad or a fault on the control board. In such instances, it's recommended to replace these parts entirely. Please note that this should be done by a professional to ensure safety and correct installation.
4/18/2024 2:32:53 PM • KitchenAid Ovens • Answered on Apr 18, 2024
Why is my Kitchenaid double oven tripping my main breaker when both are on at the same time?
Read off the power consumption of each oven and other equipment being fed from the cooker supply and have an electrician check the size of your cooker feed cable and main cooker breaker. If the cable is not thick enough for the oven, you cannot increase the breaker size! The breaker may of course be faulty, measure the current draw as the brealer trips.
7/5/2023 5:48:28 AM • KitchenAid Ovens • Answered on Jul 05, 2023
2answers
KitchenAid KERI203PBS Oven. I set to 400, it only gets to about 325.
Question edited for clarity, the MAKER, and 'what is is'. Question moved to KitchenAid. You may have a bad sensor. Not sure Amazon is the best place to buy. A lot of parts are no longer available, so you should perhaps be thinking of a replacement? https://www.partselect.com/Models/KERA205PSS5/Sections/CHASSIS-PARTS/?ModelID=679473&ModelNum=KERA205PSS5&mfgModelNum=&ManufactureID=3&Selected=N7FWPBQ3&Position=1&mfg=Whirlpool&Type=Range&Mark=1 Is the fan spinning okay? This suggests a bad fan. It has a small circular element around the fan. https://www.google.com/search?q=kitchenaid+keri203pbs+oven+not+reaching+temperature ..
8/28/2022 9:50:28 AM • KitchenAid Ovens • Answered on Aug 28, 2022
Kitchenaid architect 2 series model# kgr58075550 dead need locations of fuses and board to check
sounds like overheated bad control board or transformer
8/28/2022 9:48:57 AM • KitchenAid Ovens • Answered on Aug 28, 2022
Why is my KEBC107KSS oven Close Door Light intermittently On when my door latch is working perfectly fine?
WE HAVE NO INFORMATION AND SEBSTITUTE PARTS SORRY
1/2/2022 11:09:42 PM • KitchenAid Ovens • Answered on Jan 02, 2022
Kitchenaid KGRS807SSS00 oven gas valve shutting off after successful ignition
Do you have a flame sensor ? As it sounds like the flame sensor is not clean . Or its cracked and not sending a signal back to the spark module . I would also check the connetions are clean and tight .
9/12/2021 7:13:32 PM • KitchenAid Ovens • Answered on Sep 12, 2021
Kitchenaid superba owners manual kebc107kss03
Request the Superba model kebc107kss03 manual directly from KitchenAid.
10/29/2020 3:38:47 PM • KitchenAid Ovens • Answered on Oct 29, 2020
I have a KitchenAid Superba double wall oven Model KEBS207DBL1. None of the four oven lights will come on.
Is it possible you've blown a breaker? Probably a double-breaker, 220V.
10/27/2020 11:54:26 AM • KitchenAid Ovens • Answered on Oct 27, 2020
2answers
KitchenAid Superba oven will not
the latch the hooks into the door is caught inside the slot where it locks into when in self clean,you have to move the latch,unplug it,look through the air vents or slots up above the door if you can get a screw driver in there try to move the latch or if you can get something down inside to move the latch,i used a plastic long wire tie to do this before,i slid the tie down around the metal hook part of the latch that locks into the door,and pulled it to the left and got the door to open,it got hung up in the hole and the door wouldn't open but what ever works you have to move the hook part of the latch to get the door open,you can try picking up on the door to see if you can get it open or you'll have to pull the oven out and take the top off to get at the latch,hope this helps
7/4/2020 5:47:20 PM • KitchenAid Ovens • Answered on Jul 04, 2020
I have a KitchenAid KOCE500ESS04 with a error F6 E8 contact MW AM. What could be the problem?
In our case, the error code was displayed on a KitchenAid microwave/oven combo. It turned out to be a $4 fuse called the "Main Cavity Fuse". Good luck.
3/4/2020 9:05:02 PM • KitchenAid Ovens • Answered on Mar 04, 2020
KitchenAid Architect II Superba EQ Series KUDE20FB Logo
4 questions posted
Top KitchenAid Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Ovens
  • KitchenAid Ovens
Most Popular Question
kitchenaid superba gas oven cooktop
  • Ovens
