20 Most Recent
Oritron NPD3117 DVD Player Questions & Answers
Oritron DVD 3116 Dvd Player
i have the same machine. it does the same thing. if you just let it sit for a few minutes, it will start up and play.
hope this helps.
DVD3119- I do not have a remote control and-
Is this a retail copy of a DVD? If so then is the other side of disc usuable? Sometimes the DVD manufactures will use double sided discs meaning you have to flip them over. If there is printing on the other side than it is not of this type but if both sides are shiny and look the same try to flip it over. Maybe if you have some DVD software program on your computer and can open and explore the disc in 'My Computer' and select your D drive or whichever the disc is in. You must right click and then explore. You will see a file called video ts and go into that one and you can open the files to view them in your software program such as Nero Showtime or realplayer or any other. You can go down the list and see if you can find any other episodes. I hope this helps alittle. If not return the disc for a new one maybe it was a defect from manufacture. Also i do see some of the remotes on ebay for under 5 dollars might be worth a shot to get a new remote there. Good luck with this.
Oritron dvd 3119 player
You have to blindly instruct the NTSC/PAL menu item, which toggles between NTSC and PAL;
This is how it is done:
1) turn your dvd player off.
2) Turn it back on and make sure there is no DVD in the player tray.
This will ensure the menus are active
3) Using the remote, press the dowm menu selector key exactly three times
4) press the center menu select key once.
This will activate the display adjustement menu
5) press the down menu key exactly once.
This will activate the NTSC/PAL menu
6) press the center menu key
DONE.
The player should now have switched back to NTCS if it was in PAL.
IF it was in NTSC it should have switched back to PAL.
Note: If you still have the manual you can follow the menu tree blindly using the instructions in the manual. The above sequence is for activating the NTSC/PAL menu.
This player can also switch to progressive scan, which creates a similar problem. At least the progressive scan menu has enough warnings before it will actvate.
after unsuccessfully trying to naviagate the menu , i unplugged the dvd player for 10 or 15 min. then plugged it in again and changed the output i had it plugged into,,from video 1 to video 2 and i got my picture back it seems fine now
Pscan mode
i have dav2503 and i cant get it out of pscan how do i fix it?
Oritron no picture
Phase Alternating Line (PAL) is a colour encoding system for analogue television used in broadcasttelevision systems in most countries broadcasting at 625-line / 50 field (25 frame) per second (576i)
NTSC is the video system or standard used in North America and most of South America. In NTSC, 30 frames are transmitted each second. Each frame is made up of 525 individual scan lines.
You might try disconnecting all power from the system. unplug it.
disconnect the TV. Power back up. Maybe it will reset to factory settings. See if your TV will have a switch to NTSC.
10/5/2017 12:26:12 AM •
Oritron...
Answered
on Oct 05, 2017
Someone please give me the codes for oritron dvd player. I lost the codes for thisvibe axcess 5 in 1 remote. Please help
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
10/21/2016 2:50:49 AM •
Oritron...
Answered
on Oct 21, 2016
Oritron amplifier has no input ?
Check its powersupply regulator circuit, and main amplifier circuit for any shorted component/s. Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help
5/20/2012 1:06:31 AM •
Oritron...
Answered
on May 20, 2012
A DVD is stuck in
well looks like the disc is lodged into the track thats why you cant open it, the grinding noise is the track slipping on the motor gears as it forces to attempt to open and fails..
what we need to do is open this up and remove the disc manually..
- unplug the device (dont wanna get electrocuted)
- remove the screws to the back and under the player
- lift the cover off by sliding it back then raising it up , prying with a bladed screw driver helps.
- you will now see the disc stuck under this metal / plastic piece if you can see the disc at all.
- remove the screws holding the disc tray top in place. remove the disc and reassemble.
that should solve the problem, let me know how it turns out of if you need more help if you ran into a tight spot.
4/5/2011 1:06:24 AM •
Oritron...
Answered
on Apr 05, 2011
