20 Most Recent Pioneer DEH-2000 CD Changer Questions & Answers
This is different on every stereo, but generally the RCA ports in the back of the stereo are labeled "Aux" or something to that extent.
First, you must purchase a headphone jack to RCA cable which can connect to both your stereo and your ipod.
Connect the cable, turn your ipod on and start playing a song. Turn the volume on the stereo to a moderate volume so you can hear when the song is being played through your stereo. Then, using the selector switch, turn the stereo from "Radio" to "Aux" or whatever it says next to the the RCA plug ins on the back.
Pioneer DEH-2000... | Answered on May 28, 2014
here is the link to the manuals for your deck:
http://www.pioneer.co.uk/uk/support/manuals/DEH-2000MP/index.html
see installation manual page 4 for the wiring diagagram
Cheers!
Pioneer DEH-2000... | Answered on Feb 16, 2010
The solution that worked for me is:
1) turn off the radio.
2) Push and hold the power button down (the dial). DON'T release the button.
3) The unit will display the time on the lcd screen with the numbers flashing, (only hr or min).
4) use the up/dwn, right/left buttons to set the clock.
5) turn off the unit by pushing the power button (again, the dial).
That is it. the clock should be set.
Hope that helps,
Pioneer DEH-2000... | Answered on Mar 15, 2009
Hi Mark, please download from pioneer website, or put in a search on google for this models user manual.
cheers.
Pioneer Car... | Answered on Mar 30, 2020
Hi Abling, the nearest you could compare with is a schematic for a SA-7800. check it out, it might help you.
download from elektrotanya.com.
Cheers.
Hi Lindeni, switch off the entire system, remove the power feed from the electricity, let the amp stand for about 10mins or so. Then remove all the speaker wires from the back and all the rca/hdmi connectors from the input sockets etc.
reconnect the power wire to electrcity and switch on the amp.
If the amp clicks on and goes back in to shutdown/protection mode, the there is an internal circuit problem. you will then need to take it in for repairs.
If the amp screen stays on etc, then you mite have a wiring OR a speaker problem with one or two of your speakers. Best to get all the speakers and cables independantly checked before carrying out this testing.
cheers.
Hi Josh, if the installation was done by yourself, check the wiring of the yellow and red cables.
the yellow one should be connected directly to an uniterrupted strong +12volt supply line, like the +ve battery line.
the red wire can be connected to this line as well, or it can be connected to a "switched +12volt" supply line like the accessory line of the ignition switch barrel.
cheers.
Hi nick, there could be a problem with the unit wiring or with the speakers connected to the unit. Firstly Have your unit independantely bench tested, if all is okay then you know the problem is with your spk wiring or with the speakers.
If there are any speakers that you know that are not working, then isolate them and recheck the sound.
if the unit is found to be faulty then best to hand it to a repair technician.
cheers.
In an era where Best Essay Writing Service in USA are thriving, it has become increasingly difficult for students to identify with a reliable company that offers Top Essay Writing Services and Legit Top Essay Writing.
Pioneer Car... | Answered on Mar 24, 2020
"Error 22" on a Pioneer usually means an unsupported CD format. The disc you are trying to play is not supported or is very badly scratched so the player cannot determine the format.
Pioneer Car... | Answered on Mar 12, 2020
You damaged the speakers due to overloading with the old stereo. Run the wire that should go the rear speakers to the speaker in the door to test the theory.
Pioneer Car... | Answered on Mar 08, 2020
See this:
Carrozzeria AVIC DRZ09 Navigation installation disk
Next see this:
carrozzeria avic drz09 navigation installation disk Google Search
Then see this:
http://search.pioneer.co.jp/?ie=u&la=ja&domain=pioneer&kw=carrozzeria+maps&x=0&y=0
KNOW this site is in Japanese so use CHROME to view that site and CHROME will translate for you! From there FISH... for maps, DRZ09 ~ everything you can think of...
Anthony
Pioneer Car... | Answered on Mar 04, 2020
There is a small battery on the motherboard. It needs replacing.
Pioneer Car... | Answered on Feb 10, 2020
Car Audio & Video Logo
10 questions posted
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Sumeet Sodhi
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Car Audio & Video
Most Popular Question
pioneer deh 2000 cd changer wiring
  • Car Audio & Video
