20 Most Recent Pioneer GM-X332 Car Audio Amplifier Questions & Answers
How many total watts
HelloThe power rating for this amp is as follows.Two channel: Sub woofer: Min 35WattsTwo channel: Other than sub woofer : 70WattsOne channel: sub woofer; 100WattsOne channel: other than sub woofer: 200Watts.OK.
12/18/2011 5:32:03 PM • Pioneer GM-X332... • Answered on Dec 18, 2011
I dont Know what guage of wires to use with my Amp
8ga will be fine with the amp listed, but if you plan on upgrading in the future, then go ahead, and buy the bigger wire. 4ga +. See at the time of purchase there is only about $20 difference between 8ga, and 4ga kits, but if you go with the smaller wire for now, and then upgrade later on, you end up paying double for yopur wire, and double for your install (if you arent doing it yourself).
8/7/2009 3:34:44 PM • Pioneer GM-X332... • Answered on Aug 07, 2009
A pioneer 12 speaker with hole in magnet what size and port or solid box does it need
Read the installation instruction for the speaker. They are supplied with the speaker.
1/28/2022 7:25:03 PM • Pioneer Car... • Answered 12 hours ago
3answers
How to bypass pioneer avh p5900 parking break
you have to ground the parking brake wire, but only after the unit is powered so you can go a manual route by using a switch and turn it on manually after you power the unit, or use a relay connected to your remote (amplifier activation) wire
1/13/2022 10:12:40 AM • Pioneer Car... • Answered on Jan 13, 2022
How to fix a pioneer avh-5700 that's missing a parking break wire?
Parking brake wire should be light green.
12/12/2021 9:02:14 PM • Pioneer Car... • Answered on Dec 12, 2021
My power wire pulled out of radio don't kno what slot it goes in
This link has the owner manual, service manual and installation manual. https://www.manualslib.com/manual/129932/Pioneer-Super-Tuner-Iii-D-Deh-P4550.html ..
11/14/2021 8:28:56 PM • Pioneer Car... • Answered on Nov 14, 2021
How can I change the language on a Pioneer Carrozzeria Raku Nave Lite to English. Or is it not possible
Sometimes the changes are generic to a make, there are videos here. Another trick is to use a smartphone with the Google Translate app on it and use the Camera feature to translate what you see. Look for Settings - Language https://www.google.com/search?q=change+the+language+on+a+Pioneer+Carrozzeria+Raku+Nave+Lite ..
10/5/2021 10:28:44 PM • Pioneer Car... • Answered on Oct 05, 2021
I need to know the pinout configuration on a pioneer DEH-15UB
I assume you do not have the harness? I would suggest buying one they are available on ebay, amazon, metraonline.com plus dozens more sources. Connecting wires to the pins on the radio chassis is difficult at best and all it would take is one to touch the wrong one and fry the radio.
8/15/2021 11:59:51 AM • Pioneer Car... • Answered on Aug 15, 2021
"Avh-x1600dvd pioneer wire harness where is the p brake wire an how yo hook up"
The light green wire should be wired to the power supply side of the parking brake switch. This then provides the parking brake on/off information to the multimedia receiver. See section 26 Connection on page 50 of the manual. Pioneer has the manual available on the product support page: https://www.pioneerelectronics.com/PUSA/Car/DVD+Receivers/AVH-X1600DVD . The current link to the manual is AVH-X1600DVD_OwnersManual080814.pdf . I hope this helps. Cindy Wells
7/14/2021 4:57:34 PM • Pioneer Car... • Answered on Jul 14, 2021
Hi there, My pioneer avic mrz09 has failed to read my SD card after removal. The card still works, mounted it on my phone and the videos were playing. How do I fix this or reset the radio
what file system is on the sd card ? ntfs ? or Fat 32 ? the file system may be fat 32 on the pioneer try formating another spare sd card as fat32 and then copy files to it from other problematic sd card
6/8/2021 9:13:56 AM • Pioneer Car... • Answered on Jun 08, 2021
I need the color code for a pioneer AVH-271BT
The manual for the AVH-271BT is available from Pioneer here: https://www.pioneerelectronics.com/StaticFiles/Manuals/Car/AVH-170DVD_OwnersManual032415.pdf . See page 32 for the wiring information. The wires in each figure are indicated by a number; the corresponding color is listed with that number in the key. I hope this helps. Cindy Wells
6/5/2021 11:06:06 PM • Pioneer Car... • Answered on Jun 05, 2021
Pioneer carrozzeria zh9900 need to change it from Japanese to English can it be done
http://www.lionebra.com/_digital_cameras/q6528764-change_language_pioneer Unless it says Japanese only then you cannot. Good Luck!!
5/13/2021 9:14:07 PM • Pioneer Car... • Answered on May 13, 2021
I bought a pioneer avic d3 it has a password whats your favorite sport no its not stolen i got it at a thrift store where i work it was donated to helping hands for the blind organisation please help
Well, that narrows it down a bit. List all the sports then type them in, one at a time, adding character keys where needed.Shall we hear back from you in say six months when you require a repair to the glass in the window you threw it through do you think?Try this; There is a small reset button next to the eject buttom. Use a paper clip or pen tip to push it to reset the unit to the factory settings.
4/18/2021 4:26:53 PM • Pioneer Car... • Answered on Apr 18, 2021
I have a pioneer avic d3 it has password says whats your favorite sport how do i remove it or bypass it please help
Is it stolen? Why don't you know what your favourite sport was set to? Owner's Manual Page 131 ... set , the navigation system prompts for a password. 9 Touch "OK". 10 Reenter the password in case you must enter the current password. The password setting screen appears. 5 Touch "Clear password". 6 Enter the current password. 7 Touch "OK". 8 Touch "Yes". The current password is forgotten Contact the nearest authorized Pioneer Service Station. 129 If the back-up lead is cut or RESET button is pressed... https://www.helpowl.com/p/Pioneer/AVIC-D3/Research/18163?search=avic%20d3%20password%20reset ..
4/17/2021 9:11:12 PM • Pioneer Car... • Answered on Apr 17, 2021
Pioneer GM-X332 Car Audio Amplifier Logo
3 questions posted
Top Pioneer Car Audio & Video Experts
 Francisco Mauricio...
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Car Audio & Video
Most Popular Question
many total watts
  • Car Audio & Video
