20 Most Recent
OKI C5250n Printer Questions & Answers
Toner sensor error 413K displayed
In the side of the blue handle on the toner there should be a window that has a white flag inside it. the surface of the flag may be dirty and require cleaning. alternatively, there is a sensor opposite this in the side of the printer that "looks" for the white flag moving during the startup sequence that may also require cleaning. K in the code would indicate K or black toner is the one to be checking.
Faint line when printing a letter
hi this may be the toner roller or supply drum for the toner cartridge . if it scratched or worn it leaves marks on the drum or the roller, which in turn fills with toner and leaves an imprint on the page, you can check these , just remove the toner cartridge and look at the green roller and also look at the black roller, it might be a simple case of changing it or cleaning it....hope this helps
What kind of photo paper should I use to print out photos
Hi Anne,
The printer you have is a laser (LED) printer. This means it uses high temperature at the end of the printing process to "fix" the image into the paper.
The paper you appear to have used is for a HP Inkjet printer...basically when you put that paper through your laser printer it "melt it" and blister it. What you need to use is Laser photo paper (
here an example)
Cheers,
Ed
Oki c5250n paper jam
Unfortunately this may require and engineers visit. If you pull down the MP assembly by using the handle in the middle at the front of the printer you can then see a small "gearbox" at the right hand side of the transfer belt. This is common to feeds from both trays and could be worn. If you remove tray 1 and temporarily tape up the sensor arms to fool the printer into thinking it has a full tray installed, you can the test, by applying a little pressure to the feed roller, to see if it positively moves forward or if you are able to stop it turning. On a brighter note, you may just need new rollers instead of cleaning them.
Printing envelopes on the Oki C5250
There are 2 entrances into the multi purpose tray. The one I needed access to opened from the sides and not the front (which opened the entire front cover). There was then a flap inside which allowed me to adjust the size of the documents to feed in, including envelopes, which the main tray doesn't.
Oki 5250 380 paper jam
Sometimes you will find debris has fallen into the printer. Take off back to clean it out. Something as small as a staple can create this problem.
Oki C5250
Here's the link;
http://www.oki.co.uk/binaryData/10009/C5250uEN3.pdf
and here is the product info page if you need more;
http://www.oki.co.uk/fcgi-bin/public.fcgi?pid=118&cid=125&chid=10&pdflag=2&prid=534
Hope this helps :)
