20 Most Recent OKI MICROLINE 3320 Matrix Printer Questions & Answers
Alas you cannot clear the ram which is holding your print jobs. This is not a common problem but have seen it before. The only way to resolve it is to replace the main control board.
OKI MICROLINE... | Answered on Sep 30, 2017
If you need Okidata Printer Customer Service, then you can contact with us, okidata printer support 1877-778-8#9#6#9.We are always here with tech team for your help. For further Info Click:https://goo.gl/Ltis3S
OKI MICROLINE... | Answered on Apr 20, 2017
the printer normally prints the font set in the computer as it replicates the document
OKI MICROLINE... | Answered on Mar 30, 2015
it was made for chain form papers....
OKI MICROLINE... | Answered on Oct 30, 2014
Go to http://www.okidata.com/mkt/html/nf/Drivers.html and download the drivers, which work with your OS, for your printer.
OKI MICROLINE... | Answered on Sep 13, 2011
find out that any other device is working on that USB port? if yes then try with other cd, ask the dealer to provide u other cd. may be any file corrupted on that cd. if any device not working on that port may be the port is defective or may be it is disable from bios setting. go to bios setting while u turn on the pc see the message appears press DEL or press F12 to go to bios seeting. go to bios setting & find USB port is enable or disable. enable it.
ur printer need servicing
OKI MICROLINE... | Answered on Aug 12, 2010
Hi Kienan,
I understand that you are facing mis-aligned print problem while printing on the forms. This is not due to any hardware problem but with the settings.
Measure the height of the form on which you are trying to print and set the appropriate paper Length in the printer setting. The below shown images will well explain about how to set the settings in your printer.
The supported paper sizes in various trays can be known from he below picture:
After you successfully finished setting up the paper size in the printer, your printer should work fine.
Please let me know about the problem if still you are facing problem, so that I can provide some other solutions.
Thanks
OKI MICROLINE... | Answered on Feb 25, 2010
There is no easy way. You need to adjust starting position for every form. There is fine feed function and Top Of Form setting procedure, so you can adjust the minimum space between top of porm and first printed string (user's guide explains in details how to do it). But after that you need to decide whether you manually set the start position by rotating the knob or play with your application to adjust margins etc.
OKI MICROLINE... | Answered on Sep 24, 2009
Just go to FORMAT and select LINE and SPACING option..there you should select 1.5 spacing....this will solve your problem..
OKI MICROLINE... | Answered on Jun 22, 2009
Look on preferences, check if A4 is used for paper layout...
OKI MICROLINE... | Answered on Jun 09, 2009
Hi chris_tzo;
Without knowing your configuration on your servers, it sounds like a sharing issue on the printer. If one of the servers is set to be a print server, then you need to duplicate that on the other. If you don't have a print server, then you are sharing the printer from a workstation. In that case, what I would suggest, from the computer that you are having problems with. Drill down into the network to the computer/server that is sharing the printer and when you get to the printer, right click the printer and click connect. This will load a direct connection to your computer, and you shouldn't have any disconnect issues again. If you do, I'd say it's a network IP problem that is causing the disconnect, which is a whole other can of worms.
Good Luck
Mark
Please don't forget to leave a rating
Thanks
OKI MICROLINE... | Answered on Apr 04, 2009
change to letter
OKI MICROLINE... | Answered on May 13, 2008
OKI MICROLINE 3320 Matrix Printer Logo
38 questions posted
Top OKI Office Equipment & Supplies Experts
Thomas F. Schneider
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
MICROLINE OKI
  • MICROLINE OKI
Most Popular Question
install printer without disk
  • Office Equipment & Supplies
