20 Most Recent Pioneer DEH-P2500 CD Player Questions & Answers
Hi Elimo
Two pics as the manual had the paragraph separated. This is for DEH 2500 only. Let me know if you want the 1500 as well.
Pioneer... | Answered on May 02, 2013
there is no reset button on most pioneer cd players only pioneers that carry reset buttons are the in dash or double din players that play dvd's
Pioneer... | Answered on Mar 14, 2013
The specs don't mention MP3 anywhere, so the answer most probably is "No".
Pioneer... | Answered on Apr 19, 2012
Ok turn the system off to where only the clock is on, the green button lower left of the tuner buttons, press & hold down untill you see ((( ))) on the left & right side of the unit, then use the tuner buttons to a just the time !! GOOD LUCK ;-)
Pioneer... | Answered on Dec 27, 2011
Hold down the green button till its shuts off then press it again till you see the clock come on you will see (( )) on both sides of the clock then you move the tuner buttons up or down to change the time !
Press FUNCTION to select CLOCK. Press FUNCTION repeatedly until CLOCK appears in the display. Press until the segment of the clock you want to set. Pressing will select one segment of clock, hours - minutes. That segment should then "Blink". Press ^ or v to set the CLOCK. Pressing ^ or v will increase or decrease the hours -minutes.
Hope that helps, good luck with it.
Pioneer... | Answered on Mar 29, 2011
Those cables are for audio out only you need an IP Bus adapter to connect the AUX input. the CDRB20 or CDRB10 is what you need. the CDRB20 allows for more inputs as well such as CD changers, and XM radio tuners.
Pioneer... | Answered on Mar 13, 2011
According to the user's manual the following procedure is used to set the clock.
Manual is at this link http://www.retrevo.com/support/Pioneer-DEH-P2500-Car-Receivers-manual/id/23227dj392/t/2/
Here's the procedure indicated in the manual
1 Press SOURCE and hold until the unit turns off.
2. Press FUNCTION and hold until the clock appears in the display.
3. Press FUNCTION to select clock.
4. Press the Left Triangle or Right Triangle to select the segment of the clock display you wish to set.
5. Press the Up or Down Triangle button to change the digit up or down.
Pioneer... | Answered on Jan 12, 2011
Pioneer DEH-P2500 CD Player Logo
41 questions posted
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Sumeet Sodhi
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Car Audio & Video
Most Popular Question
play burned mp3 disc pioneer deh p2500
  • Car Audio & Video
