20 Most Recent Olivetti (AA6195) Internal 8x CD-ROM Drive Questions & Answers
Olvietti
The company that made the printer should have a web site, this is one I found that should help http://www.opendrivers.com/company/21438/olivetti-free-driver-download.html3
There are many others if you google it. Just go there, download the driver(program that makes the printer work with your computer) and you should have it. You can also take the file and save it to disk so you have a disk with the driver on it in case you get a new computer.
11/4/2008 10:20:31 PM • Olivetti... • Answered on Nov 04, 2008
Hi I have recently just got an Olivetti MF201 Plus from another office within my compnay & have been left to my own devices to get it setup. There is no CD with it. Is there a driver I can download?
google --olivetti mf201 drivers and download directly from the site the driver should be in the down load but if not search on the site for drivers for that unit
9/11/2017 11:05:35 AM • Olivetti... • Answered on Sep 11, 2017
Olivetti printer not printing
first check your connectivity from printer to pc
1/26/2014 12:10:32 PM • Olivetti... • Answered on Jan 26, 2014
0answers
How to install Olivetti PR2
station 1 and station 2 button are blink and not ready for print
9/9/2010 5:50:57 AM • Olivetti... • Answered on Sep 09, 2010
No sound
The two most frequent sources for the loss of sound are bad connections and corrupted drivers.
To check connections make sure wires are not faulty. Check for crimps or damaged areas. Try a different set of speakers to see if they work. Make sure connecting plugs are placed in proper hole for sound out/speaker on back of sound card. If these check out and still no sound reseat the sound card [if not on mainboard sound] by turning off the unit, opening it [making sure to be grounded so no static electric discharge can damage the unit or its peripherals, then dismount the sound card from its slot after disconnecting all plugs attached to it, checking its connections for corrosion [this can be cleaned with a standard pencil eraser if any is noted], and reseating and securing it in its slot. Restore all connections and turn the unit back on and check for sound.
To deal with corrupted drivers check "Device Manager" to see if the sound card is showing a "bang" next to it [a black exclamation point in a yellow circle]. While not always present when drivers have become corrupted if it is that is most certainly the issue. Look up the support site for the manufacturer of the sound card or the chipset if it is on mainboard sound, and then download the most current drivers from the site. Installing them should overwrite any corrupted files and correct the problem if a corrupted driver is the source of the issue.
2/4/2010 9:41:24 AM • Olivetti... • Answered on Feb 04, 2010
Olicard 100 su linux xandros installato su asus
dont understand
12/22/2009 4:48:40 PM • Olivetti... • Answered on Dec 22, 2009
Can't boot it up,.
Can you tell me whatkind of a computer it is? a old one? started up with discs?
9/11/2009 6:22:47 PM • Olivetti... • Answered on Sep 11, 2009
Power on failure
Remove the battery. Plug the AC adapter. Then try to power on.
If it still fails to boot up, it is a no post issue, probably a systemboard failure.
Hope this helps...
9/12/2008 10:52:41 AM • Olivetti... • Answered on Sep 12, 2008
Where can i get mastering machine learning Tips for Tackling Assignment
Mastering Machine Learning: Tips for Tackling Assignments Conquering machine learning assignments requires a blend of theoretical understanding, practical application, and strategic problem-solving. Here are some tips to help you excel:Foundational Knowledge: Solid Understanding of Concepts: Ensure you grasp the core concepts like supervised vs. unsupervised learning, different algorithms (regression, classification, clustering, etc.), and their applications. Mathematics and Statistics: Brush up on essential math and statistics, including linear algebra, calculus, probability, and statistical distributions. Programming Skills: Hone your programming skills in languages like Python or R, including libraries like NumPy, Pandas, Scikit-learn, and TensorFlow.Tackling Assignments: Thorough Understanding: Carefully read and understand the assignment instructions and objectives. Identify the specific problem you need to solve and the expected deliverables. Data Exploration and Preparation: Analyze the provided data: Understand the features, data types, missing values, and potential biases. Data Cleaning and Preprocessing: Address missing values, outliers, and inconsistencies. Feature Engineering: Create new features or transform existing ones to improve model performance. Model Selection and Training: Choose appropriate algorithms: Select algorithms based on the problem type (classification, regression, etc.) and data characteristics. Model Training: Train your model on the prepared data and tune hyperparameters to optimize performance. Evaluation: Evaluate your model's performance using metrics like accuracy, precision, recall, F1-score, or AUC-ROC curve. Experimentation and Iteration: Try different algorithms and hyperparameter settings: Compare the performance of various models to find the best fit. Cross-validation: Use techniques like k-fold cross-validation to assess modelgeneralizability and avoid overfitting. Regularization: Apply regularization techniques like L1/L2 to prevent overfitting and improve modelgeneralizability. Interpretation and Communication: Analyze results: Understand why your model performs well or poorly and identify areas for improvement. Visualize results: Use plots and graphs to illustrate your findings and insights. Clear Communication: Present your results and explain your approach in a clear and concise manner.Resources for Learning and Support: Online Courses: Platforms like Coursera, edX, Udemy, and Udacity offer comprehensive machine learning courses. Books and Tutorials: Numerous books and online tutorials cover machine learning concepts and techniques. Open-Source Libraries and Frameworks: Explore libraries like Scikit-learn, TensorFlow, PyTorch, and Keras for implementing machine learning models. Community Forums and Q&A Sites: Seek help and engage in discussions on platforms like Stack Overflow, Reddit's Machine Learning subreddit, and Kaggle forums. University Resources: If you're a student, leverage university resources like libraries, workshops, and professors' office hours. Remember: Practice is key: The more you practice, the better you'll understand the nuances of machine learning and improve your problem-solving skills. Start with simple projects and gradually increase complexity. Don't be afraid to experiment and try different approaches. Seek help when needed and learn from others' experiences.
4/24/2024 9:45:52 AM • Computers &... • Answered 4 hours ago
3answers
How do I find The best Roofing Service Contractor in Houston, Texas?
To find the best roofing service contractor in Houston, Texas, ask for recommendations from locals, check online reviews, verify licenses and insurance, and interview multiple contractors. Trust your instincts and choose wisely.
4/24/2024 4:31:29 AM • Computers &... • Answered 9 hours ago
Upgrades software
If you want to upgrade your software for example your operating system. Your systems unit support only for windows 7, windows 8 and windows 8.1. You may visit this website to download the latest driver for your operating system installed. http://support.lenovo.com/en_PH/downloads/detail.page?DocID=DS035527
4/22/2024 1:20:20 PM • Computers &... • Answered 2 days ago
2answers
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
4/21/2024 5:41:42 AM • Computers &... • Answered 3 days ago
2answers
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
4/21/2024 4:20:47 AM • Computers &... • Answered 3 days ago
Do you guys know some good custom web app development services?
DICEUS with 13 years experience. SIMFORM for modernizing legacy architecture. ColorWhistle for leads. PixelCrayons for tailoring to your specific needs.
4/18/2024 5:17:23 AM • Computers &... • Answered on Apr 18, 2024
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired anemployment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut. They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
4/17/2024 5:31:31 PM • Computers &... • Answered on Apr 17, 2024
Implementing Reliable WordPress Website Backups: A Solution to Downtime and Errorsi wan
Keep a backup on your hard drive or a backup. The backup system is a free service supplied by your internet provider. If you use it daily or after every update, there will never be an issue.
4/16/2024 4:37:13 PM • Computers &... • Answered on Apr 16, 2024
How to get free backlinks?
YouTube Backlink Generator https://ovdss.com/apps/youtube-backlink-generator
4/13/2024 3:06:42 PM • Computers &... • Answered on Apr 13, 2024
Computers & Internet Logo
2 questions posted
Top Olivetti Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Olivetti Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Olivetti Computers & Internet
Most Popular Question
olvietti
  • Computers & Internet
