20 Most Recent Pioneer DEH-1700 CD Player Questions & Answers
I believe the extraction keys are more or less thin metal shims that push the locking tabs down and prevent the tabs from stopping the removal of the stereo while also acting as catches that allow you to simply insert the keys and then pull on the keys to remove the stereo. If you do not have the right keys, you should be able to make simple metal shims, push them into the left and right sides between the stereo and the mount, once in place you will have to pull the stereo out manually instead of using the keys.
Pioneer DEH-1700... • Answered on Nov 11, 2017
red always 12 v or yellow one is switched by the key of your car
Pioneer DEH-1700... • Answered on Jan 13, 2013
Press SOURCE. See page 7 of the manual for full details.
Pioneer DEH-1700... • Answered on Jun 27, 2012
You also must make sure that it is grounded as well.
If you need more help, let me know and please tell me how you were able to determain that it has power going to the radio. Which wires did you check and how did you check them.
Sometimes having the antenna plugged in will give you a good enough ground to at least check the radio. Most cars have the antenna ground connected to the chassis but not all. This is not intended as a permanent ground.
If all wiring is correct and no fuses are blown, yu may just have a defective radio that needs service.
If I can be more help just let me know.
Dave
Pioneer DEH-1700... • Answered on Apr 26, 2012
the groung wire was torn out of my deh1700 pin connector where does it go back
Pioneer DEH-1700... • Answered on Aug 25, 2011
Yes, it should slip right in, but I recommend you buy the adapter for the wiring harness. Look here for details and instructions are pasted below:
http://www.crutchfield.com/p_130DEH1700/Pioneer-DEH-1700.html?tp=5684
1992-95 Models
See Figure 4
Removing the radio will require removal of the front part of the center console.
The original equipment radio has a coded theft protection circuit. Before beginning removal, be sure to know the code for re-installation. The code is erased whenever the battery is disconnected or the No. 32 (7.5A) fuse from the under hood fuse/relay box is removed. When power is re-connected, the word "CODE" will be displayed and will require entry of the 5-digit code for that particular unit.
WARNING All SRS wire harnesses are covered with a yellow insulation. Read the SRS precautions found in this section and install the short connectors as described.
  1. Disable the SRS system as described in this section.
  2. Remove the center instrument panel by removing the four philips screws on the top and sides.
  3. Disconnect the 4-pin connector from the cigarette lighter.
  4. Remove the two screws, then disconnect the 16-pin connector and the antenna lead.
  5. Carefully pull the radio/cassette player out.
To Install:
  1. Plug in the 16 pin connector and install the two retaining screws.
  2. Plug in the antenna lead, the cigarette lighter and carefully install the unit.
  3. Install the center instrument panel. Re-connect power to the car, and enter the 5-digit theft protection code for the radio/cassette player.
  4. Enable the SRS system.
Pioneer DEH-1700... • Answered on Aug 14, 2011
The chassis of the receiver normally is connected to its ground, it should work, but if want to look for the missing cable please follow the color sequence at the rear connector, the ground wire is the third starting from the yellow cable, the second should be the red one, for more details about your receiver please check the user manual at:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/130DEH1700.PDF
Pioneer DEH-1700... • Answered on Feb 19, 2011
you may have a bad switch.
Pioneer DEH-1700... • Answered on Feb 18, 2011
You can download and print the instruction manual in PDF format by clicking this link.
For installation manual, click here
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Pioneer DEH-1700... • Answered on Jan 29, 2011
with the proper accessories, it should work just fine.
Pioneer DEH-1700... • Answered on Oct 14, 2010
I would go thru the menu functions to be sure the speakers are turned on first.
I would also check the pre outs to be sure they are functioning , then maybe just use them (plugged into an exterior amp).
Pioneer DEH-1700... • Answered on Jul 16, 2010
maybe the wire plug came loose. try pushing each wire in. my system did the same thing and that was the problem. If that don't work, i do not know, sorry.
Pioneer DEH-1700... • Answered on Jul 14, 2010
here is the link for the installation manual and user manual:
http://www.pioneerelectronics.com/PUSA/Support/CarAudioVideo/In-Dash/CD-Players/ci.DEH-1700.Support
see the installation manual page 1 far right side for wiring diagram is listed as other manual
Cheers!
Pioneer DEH-1700... • Answered on Feb 16, 2010
Toddakins05
To set the clock on the DEH-1700
1. Press SOURCE and hold unitl the unit turns off.
2. Press AUDIO and hold until clock appears in the display.
3. Press <- or -> to select the segment of the clock display you wish to set.
4. Press + or - to set the clock.
Note to cancel clock settings press BAND
Hope this helps
Issken
Pioneer DEH-1700... • Answered on Jan 18, 2010
First thing to do is press the "source" button and hold until the unit turns off. Next, press "audio" and hold until clock appears in the display. Then, press the arrows to select the segment of the clock display you wish to set. Now, press + or - to set the clock. To cancel clock settings, press "band". You can also cancel clock settings by holding down "audio" until the unit turns off.
Pioneer DEH-1700 CD Player Logo
65 questions posted
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Car Audio & Video
Most Popular Question
pioneer deh 17 wiring diagram or pinout
  • Car Audio & Video
