20 Most Recent Pioneer DEH-P6600 CD Player Questions & Answers
had the same problem with a pioneer i took a qtip and some rubbing alcohol and cleaned the gold colored connecters on the face and radio and worked ever sine.
Pioneer... • Answered on Jan 25, 2015
should plug straight in / there should be 2 connector blocks one with all the power leads and the other(8wires) for the speakers
Pioneer... • Answered on Jun 12, 2013
Pioneer... • Answered on Mar 16, 2013
make sure ur antenna's hooked up
Pioneer... • Answered on Jun 17, 2012
    • Turn the stereo off by pressing the "source" button on the bottom left corner of the stereo's face. Press the "function" button, the lower of the two buttons to the right of the stereo display, until the clock appears on the display. Press the arrow keys at the far right of the stereo's face to adjust the time. Use the left or right arrows to toggle between hours and minutes. Use the up and down arrow to increase or decrease the hour or minute numbers. Press the "function" button once you have set the display clock to the correct time.
Source- http://www.ehow.com/how_6881633_do-pioneer-deh_p6600-cd-player_.html
Pioneer... • Answered on Jun 23, 2011
Error codes 12 and 17 are for a dirty or scratched disc. First thing to try would be a different disc. If this does not work most higher-end pioneer head units have a software reset button which is not well marked but usually located behind the face plate and you can use a pen or a pin to push this. It needs to be held down for a few seconds and this will reset all of the settings to factory standard. This does mean that you will lose all saved radio stations, clock settings, audio settings etc. If it still wont play any discs after that it will likely need more detailed attention from a technician. Cheers, Dan
Pioneer... • Answered on Apr 27, 2011
yes they are the same radio 1 is just premier brand pioneer
Pioneer... • Answered on Sep 27, 2010
Heres the manual - http://caraudio.manualsonline.com/manuals/mfg/pioneer/dehp6600.html
Pioneer... • Answered on Jul 02, 2010
You need an adapter for a double din to a single din radio. You can get these at almost any place that sells car audio. Yours is a common adapter they are about $15.
Pioneer... • Answered on May 16, 2010
start with a 12 volt light tester or you can just run new ones from your fuse box
Pioneer... • Answered on Apr 15, 2010
If its a aftermarket stereo, the red wire is ignition, yellow wire is constant 12 volts, & black wire is ground. The speaker wires should be purple + & purple w/ black stripe - / white + & white w/ black stripe - / green + & w/ black stripe - / gray + w/ black stripe - /....then blue is for power antenna. Thats most aftermarket radios, some have orange for a dimmer but it depends on the brand.
Pioneer... • Answered on Mar 28, 2010
This is directly from the installation manual from pioneer website for model DEH-P6600
(Yellow/black
If you use a cellular telephone, connect it via the
Audio Mute lead on the cellular telephone. If not,
keep the Audio Mute lead free of any connections.)
Basically, you don't hook it up unles you have a cellular telephone in your vehicle, not a personal cell phone.
Pioneer... • Answered on Mar 09, 2010
is the image set up on demo, or random scroll thru the image menu and set it up as you prefer, that should stop the ever-changing imagery
Pioneer... • Answered on Jan 17, 2010
Pioneer DEH-P6600 CD Player Logo
48 questions posted
Top Pioneer Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Car Audio & Video
Most Popular Question
pioneer deh p6600 head unit when
  • Car Audio & Video
