20 Most Recent Pioneer DEH-P9600MP CD Player Questions & Answers
yes it is a over heting problem
Pioneer... | Answered on Jul 05, 2011
sounds like you have a bad flexible cable. in my shop it would be about a 50.00 repair. i don't know what other places would charge.
Pioneer... | Answered on Aug 06, 2010
try pacparts.com
Pioneer... | Answered on May 26, 2010
pull the unit out and make sure that your connections are all good and solid -if you wiggled it and it worked momentarily- then chances are the wiring or wiring harness is loose and needs some attention
Pioneer... | Answered on Jan 16, 2010
I have the same deck. replace the flex ribbon to sub panel. It's a problem with this deck. I've replaced the rear panel ribbon numerous times as well as the front panel ribbon.
Pioneer... | Answered on Jun 30, 2009
YOU NEED TO REPLACE A RIBBON CABLE CALL 1 800 421 5080 IS A COMPANY NAMED PACIFIC PARTS THEY SELL THAT PART.
Pioneer... | Answered on Mar 19, 2009
no i havnt found the problem yet but my brother who repairs electronics will be back from australia in the nex few days ill run it past him thanks steve
Pioneer... | Answered on Feb 18, 2009
I had load of these units and the cure is simple. You need to replace the ribbon to the faceplate as these get damaged due to wear and tear. Every unit i had with this fault, i fixed by replacing this ribbon. Buy the ribbon and surround as the new surround is a modified one to give extra life to the ribbon. Hope this helps, good luck!
Pioneer... | Answered on Feb 07, 2009
my 9600 gat the same problem.. been told the ribbon needs replacing they sell on ebay for about £30 or you can send ur h/u to pioneer to do but that will be more expensive..
hope this helps
Pioneer... | Answered on Jan 15, 2009
first check all of your power and ground connections and be sure your battery is good then try the small reset button on the front face. if that does not work you may need a new flexible ribbon cable that you can find on ebay cheap.
Pioneer... | Answered on Jan 09, 2009
you need a new flexable ribbon cable. try ebay or pacparts.com
try pacparts.com
An install gone bad. Something is hindering free movement of the face plate open mechanism. Closely inspect the top edge of the bezel, is the face plate trim ( thin plastic ornamental frame covering the ugly aluminium mounting sleeve) snapped securely back in place? has it been fitted upside down?, is it deformed?.
Pioneer... | Answered on May 27, 2008
to the battery
Pioneer... | Answered on May 17, 2008
find an unused or broken stereo, and use the one off it
Pioneer DEH-P9600MP CD Player Logo
Popular Tags
25 questions posted
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Sumeet Sodhi
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Car Audio & Video
Most Popular Question
unit appears dead prevously cured
  • Car Audio & Video
