20 Most Recent Mach Speed Trio Stealth G2 Tablet - Android 4.0 Ice Cream Sandwich, 7 Questions & Answers
Not likely you have a built in scan program on your tablet.
You can easily download one for your android.
Avira comes to mind.
Mach Speed Trio... | Answered on Jan 12, 2020
my table resets up on ever boot , you have to renter all the info every time you boot it up, Trio G2 10in
Mach Speed Trio... | Answered on Jul 24, 2018
The internal battery may be unable to recharge.
Mach Speed Trio... | Answered on Jan 29, 2018
Most tablets available nowadays are Android-based ones. And most of them can be "factory reset" to leave them as brand new.
First, understand that if you continue, all the information you already added to your tablet will be erased. If you have any info you need to retrieve, please, do not go on and try something different, OK?
All right... Let's go on... The best way to know how to factory reset (or "hard reset", as it is also called) your device is to check in the Internet if there is already a description of the whole process. Assuming that you have a Samsung Galaxy Note 8 tablet, search in Google for "how to factory reset a Samsung Galaxy Note 8 tablet?" Follow the instructions and you will have your tablet running as if it had just been taken out of its box!
If you cannot find the instructions for your specific device, you could, then, try to check if it can enter recovery mode. First, completely switch off your tablet. Then, press at the same time and maintain pressed the "Power" button and the "Volume Up" button and wait for the device to power on, when you can release the keys. An "Android System Recovery" page should appear. If that is the case, you can navigate through the options using "Volume Up" and "Volume Down" keys. Go to the "wipe data/factory reset" option and activate it, pressing the "Power" button. Your tablet should reset (it will take a while).
If you didn't enter the reset page with those keys, repeat the process, this time pressing "Power" and "Volume Down" keys (different tablets have different combinations of keys to enter recovery mode.)
Hope you may find this information helpful!.
Mach Speed Trio... | Answered on Dec 05, 2017
if other solution fails, you can do a hard reset.
follow this procedure.
1. switch the tab off. after,
2. long press power button +
volume down key simultaneously.
3. after it shows the logo then
release the power button but
continue pressing the volume key
until the wipe or reset menu
appears.
try it, it works and start thngz afresh
Mach Speed Trio... | Answered on Aug 04, 2016
Hi Johnny, The link below is a YouTube video showing how to fix your tablet, Also there's video's down the right side of the link that may help as well....CHEERS..
How To fix any Android Phone Tablet that won turn on
Mach Speed Trio... | Answered on May 13, 2016
I am not going to say no for sure but 90 percent sure there is not. The problem is you would have to scale the signal down to a composite signal. Now that can be done but at a pretty hefty cost and that is if the cable is available to come off of your tablet. From there it would have to go from 1080P to HD15. Then you would have to have a HD15 to composite scale converter. Then go to the tvs RCA input. The scale converter, the right one, is going to be about 200 bucks.
Mach Speed Trio... | Answered on Mar 21, 2016
Settings > Language and Input and tap on Language which is the top option on right.
Mach Speed Trio... | Answered on Dec 28, 2015
This should work on any Android 4.0 and newer tablet.
To take a screenshot on your device, press the Volume Down and Power keys at the same time.
The screen will flash, you'll hear a sound, and you'll see a framed image appear and fade into the notification bar. The "Saving screenshot" notification will appear.
Mach Speed Trio Stealth G2 Tablet - Android 4.0 Ice Cream Sandwich, 7 Logo
356 questions posted
Top Mach Speed Trio Tablets & eReaders Experts
Tom Chichester
Lawrence Oravetz
 Grubhead
Grubhead
Are you a Mach Speed Trio Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Mach Speed Trio Tablets & eReaders
Most Popular Question
screenshot trio stealth g2 9 7 tablet
  • Tablets & eReaders
