20 Most Recent
Plustek UT16 USB Scanner Questions & Answers
Do not know the power
On the bottom of the scanner, there may be a label that shows the voltage and amp rating of the adapter required.
I cant install plstek opticpro ut16 scanner in my pc
Try this steps before you install
1. Start -> Click Run
2. Enter msconfig and click ok
3. Click Startup tab
4. Uncheck program that you don't want to startup
You can disable programs that you don't want automatically load when you start your computer. By disabling these programs will help your computer startup faster.
5. Click Ok and restart
Now you should notice that your computer startup faster.
My Hot Tips to Make Your Computer Faster:
* Regularly check your startup folder to prevent malicious programs installed itself without your knowledge.
* Delete the temporary files from Temp folder (Start > Run > %temp% > delete all files).
* Upgrade your RAM to makes your computer boot faster : )
I hope this article can helps you to make your computer faster..
Unable to install the opticpro ut16
If you are running Windows XP, you're in luck, but the company has discontinued this model, no longer supports it, and has no drivers for Windows Vista. The link to the driver is right here: http://www.plustek.de/uk/support/download-result.php (note: if this is not an active link, copy and paste it in your browser's address bar.)
I could only find the driver on the UK site, as the American site was down. It is the same driver. Hope this helps.
