20 Most Recent Toshiba Satellite L645DS4037 Notebook PC Questions & Answers
  • You can try a can of liquiod air first and blow out the dust inside the fan and you can also add more cooling thermal paste to the heat sink above the CPU.
  • There is an youtube video that will show you this procedure if you are technical savy.
I’m happy to assist further over the phone at https://www.6ya.com/expert/vincent_e64835e2b80feb5e
Toshiba... • Answered on Apr 23, 2014
Sorry you are going to have to order a replacement keyboard. You can almost replace it yourself if you have some technical knowledge. There is a video on how to replace the keyboard on you tube. Toshiba Keyboard Replacement Satellite Laptop I’m happy to assist further over the phone at https://www.6ya.com/expert/vincent_e64835e2b80feb5e
tegantung dari pemakaian, jika di gunakan untuk game, video atau musik memang cenderung lebih cepat panas... solusinya, beli lah cooler fan, harganya tidak terlalu mahal, kurang lebih 75ribu rupiah
Toshiba... • Answered on Apr 16, 2013
The Windows operating sustem appears to be corrupted and most like to get a working computer you need to restore it back to the factore default condition.Before you attemp to do this and to back up data, remove the hard disk from the Toshiba and connect this hard disk to an USB hard drive adapter, then plug this adapter into the USB port of a working computer. This computer will see this as an external storage device. You can then open the various folders on this drive and back up your data on this computer or an USB memory stick.To restore your Toshiba, insert the hard disk back into the Toshiba and follow these instructions..Restore Toshiba to Out of the Box ConditionIf your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on your notebook.2. When the machine Starts beeping; release the 0 key.3. When prompted by the warning screen; select Yes to continue with the systemrecovery.4. Select Recovery of Factory Default Software; click Next.5. Select Recover to out-of-box state. 6. Click Next again.7. Click Next to Start recovery. 8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.http://www.fixya.com/support/r8248520-restore_toshiba_out_box_condition
Toshiba... • Answered on Mar 07, 2012
it sounds as though its not seeing the hard drive. Power up and press delete to get into the bios. The hard drive should be seen in the first or second screen. If its not there then you will need a new one and a new installation of windows.
Toshiba... • Answered on Aug 29, 2011
for using web cam go to control panel, camera
and for check the web cam and audio use software that using webcam and audio device like Yahoo messanger or skypee, with that software you can make video call to another person
i hope this helpful
thank you for using fixya
Toshiba... • Answered on Feb 10, 2011
You can download any/allthe Windows XP or Vista device drivers for your model laptop from the ToshibaWEB site from their download page. Make sure you enter the model of your laptopso you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Toshiba... • Answered on Dec 23, 2010
Press and hold the "0" key on the keyboard while powering on the computer.
Toshiba... • Answered on Dec 14, 2010
You may have to call Toshiba direct at: Computers: (800) 457-7777 (toll-free)
When you first start up and the screen turns black you have about two seconds to press F8 or F12 that will allow you to get in from the back door. Again, I would recommend that you call Toshiba for details on how to override.
Toshiba... • Answered on Dec 08, 2010
It is possible to connect a modem to the laptop. Connect the modem to the laptop using the telephone style socket on the laptop. The mother board will then pick this up and load the relevant drivers for your modem.
If you are not sure, contact Toshiba online. They are extremely helpfull.
Hope this helps.
Toshiba... • Answered on Nov 06, 2010
it is still under warranty -- why not get Toshiba tech support to help you ? they are obligated to assit your issues, the computer is new
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2681555&rpn=PSK0QU&modelFilter=L645D-S4037&selCategory=2756709&selFamily=1073768663
Toshiba... • Answered on Oct 19, 2010
Just restore your system from a backup taken before the error code started. If you have no backup then you need to format your hard disk and do a complete reinstall of all your software.
Toshiba... • Answered on Mar 19, 2020
If you know the DVD and the DVD drive is in proper working order, it could mean that the software you are running just may have some problems. Try downloading a copy of VLC (VideoLan Client) this application is free and open source (and no it's not something I created and am just trying to get people to use...it's just something that works great, and completely free) VLC can play almost any video file or DVD that it encounters. If VLC can't play it, I would think it's likely there may be something with your disk or your DVD drive.
Toshiba... • Answered on Mar 11, 2020
dvd players play vob or mp4 format. so try "convert x to dvd" software to burn your dvds in the right format http://www.vso-software.fr/products/convert_x_to_dvd/
Toshiba... • Answered on Feb 16, 2020
If you want to play DVDs from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk. The best solution to make the player region free is to install a piece of software (Passkey for DVD) that allows you to play DVDs from any region and Passkey for Blu-ray that allows you to play Blu-rays from any region. There are several available on the Internet but my favourite is DVD-Region Free From: - www.dvdfab.com/products,free.htm
Toshiba... • Answered on Dec 05, 2019
Hello,Do you have a wifi card in the computer? It is a hardware part that you need so that the computer can connect to the wifi. If you have that but can't find it in the operating system. I suggest that you either install or update the driver for it. You can use RadarSync to scan your computer for the available updates of your wifi driver. Make sure that you connect to the internet first using your ethernet so that it will detect the available driver updates somewhere in the databases of the manufacturer. Davidhttp://goo.gl/CxsY9u
Toshiba... • Answered on Sep 25, 2019
Hello, to get the driver for your Toshiba, follow the steps below: go to http://support.toshiba.com/drivers enter your laptop model ( Satellite L505) and download sound drivers and other necessary drivers needed for your laptop to operate well. Good luck.
Toshiba... • Answered on Sep 12, 2019
uninstall the software and put it again
Toshiba... • Answered on Sep 06, 2019
Toshiba Satellite L645DS4037 Notebook PC Logo
Popular Tags
21 questions posted
Top Toshiba Computers & Internet Experts
k24674
Michael Thomas
Michael Thomas
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
kenapa toshiba kok cepat panas
  • Computers & Internet
