20 Most Recent ViewSonic VA1913w Monitor Questions & Answers
Blinking on/off light.
Here's some tricks I would try... 1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor. 2. Verify the monitor cable is firmly connected to the computer and the monitor. 3. Verify that you have turned the monitor power switch on. 4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works). 5. If the power light on the monitor is not on, try a different power cord. 6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced. 7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers. Good luck.
7/19/2014 4:13:52 PM • ViewSonic... • Answered on Jul 19, 2014
I connected va1913w monitor but can not find where
Look for the green mimi phone jack on the back to connect the cable to the PC AUDIO LINE OUT.
See page 9 of the user manual here: http://www.viewsoniceurope.com/ru/assets/040/11346.pdf
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
5/6/2011 2:48:02 PM • ViewSonic... • Answered on May 06, 2011
I have a red line going down my screen is it
Most times when this happens, it means the monitor must be replaced. I suspect that you may soon get more lines on the screen. It would be the screen itself.
4/19/2011 4:18:30 PM • ViewSonic... • Answered on Apr 19, 2011
2answers
My monitor viewsonic VA1932 wm gets electric shock if I touch the VGA,DVI ports and the metal placed in the base
This is a hazard that you need to figure out. First thing is to check the power cables, Some of those monitors use a separate power brick and some dont. IF yours has a power brick, make sure it is made by viewsonic. It maybe a polarization issue with the wrong power unit. If the monitor plugs straight into the power cord and then into the outlet, check the cord ends to see if they are polarized ( one is bigger than the other spade) If they are different sizes where they plug into the wall, there is something more serious wrong inside the unit. You should use an electric meter to see how high the voltage is. IF it is more than 50 Volts you should stop using the unit. That model number is not listed on Viewsonics website. There is one that is close but they are not making it any longer.
4/5/2020 12:30:13 PM • ViewSonic... • Answered on Apr 05, 2020
VIEWSONIC VX2880ML 4K MONITOR ,FRONT CONTROLS WONT WORK ,HELP
https://support.viewsonic.com/en/support/solutions/articles/33000221575-what-to-do-when-no-display-from-my-monitor-
4/4/2020 1:07:49 PM • ViewSonic... • Answered on Apr 04, 2020
Viewsonic VX2835wm monitor that powers up with a good screen for a couple of seconds and then goes blank. I replaced the power board and it still does the same thing. Could it be the on/off switch?
FIRST WE DO NORMAL AND LATER TRUE CAUSE. gee that is normal on all monitors and by Energy Star laws too. the monitor if the PC is dead or in speed mode, shuts of in 15 to 90 seconds, all do, every one. the monitor has self sleep, all do. everyone ever made did. even back to CRT days. and the OSD button goes dead after. that. too. fooling the untrained. here is the first tests, NO PC connected at all power on see power light glow correct color then see Viewsonic splash screen push the menu button now. quickly, if button dead hold it for 10 to 15 second to reverse the button lock now, see OSD works. if you test the monitor on a good PC not in sleep mode the but working PC, your monitor is ok. this monitor is very very old, 2004? it has CCFL back lamps not LED< and all fully used CCFL lamps are now no good, used 8yrs a day at 5years are no good. that is why we use LED back lamps now. this is what they do: all do , used fully. 1: goEs dead forever, (vast did) 2: INTERMITTANT . (BINGO YOU ) OR INVERTER DEAD. 3: DIM BULBS (like me. lol) 4 TURN YELLOW FOR WHITE screens. 5: STROBEs. (FLASHes) AND A VERY EXPENSIVE SURE, THAT. AND LABOR.
4/4/2020 1:05:14 PM • ViewSonic... • Answered on Apr 04, 2020
How can I unlock osd on my TV viewsonic n2011
OSD Lock: Press and hold [AUTO] and the up arrow for 10 seconds. If any other buttons are pressed the message OSD Locked will display for 3 seconds. OSD Unlock: Press and hold [AUTO] and the up arrow again for 10 seconds. http://www.viewsonicglobal.com/public/products_download/user_guide/Display/VA1903A/VA1903a_UG_ENG.pdf?pass
4/4/2020 1:02:43 PM • ViewSonic... • Answered on Apr 04, 2020
Vx922 capacitors will they work on a viewsonic va1930wm
https://www.youtube.com/watch?v=X6Tn6a_Xy7Y
4/4/2020 1:00:50 PM • ViewSonic... • Answered on Apr 04, 2020
My monitor is all purple and white how do I fix that on a viewsonic
https://www.youtube.com/watch?v=-EfwZnWYrvI
4/4/2020 12:57:32 PM • ViewSonic... • Answered on Apr 04, 2020
How to remove back panel of viewsonic va2046
Hello Edelberto, this monitor does not disarm by the back to disarm the monitor, you have to remove, with great care, the front frame and there you will see the obstacles you have to remove the panel assembly and the platelets I hope you can disarm it, comment the results Greetings Franco Dosil Hola Edelberto,este monitor no de desarma por la parte posterior para desarmar el monitor, tienes que retirar, con mucho cuidado, el marco frontal y ahi veras las trabas que tiene para sacar el conjunto del panel y las plaquetas Espero que puedas desarmarlo, comenta los resultados Saludos Franco Dosil http://www.viewsonicglobal.com/public/products_download/36/29622.pdf http://www.viewsonicglobal.com/public/products_download/36/29639.pdf
5/13/2019 1:16:45 AM • ViewSonic... • Answered on May 13, 2019
Viewsonic vx922 capacitor compaiable va1930wm montor
As long as they are the same value
4/18/2019 6:31:34 PM • ViewSonic... • Answered on Apr 18, 2019
VGA Monitor starts flickering brightly after 20-30 minutes of use
The problem is seems to be in power supply section. it may be need to repair by electronic technician, after using any monitor 5 to10 years there may be power section or lcd panel may be damage.
1/30/2019 6:15:31 AM • ViewSonic... • Answered on Jan 30, 2019
I have a Viewsonic VE710b monitor. When I connect it to my computer and turn both on, the monitor shows a "No Signal" message. I've checked the connections and all are good. Is my monitor damaged?
First, I'm not a Viewsonic representative. * Check your warranty. call for support. *** Following for information only.*** * No signal means no usable signal for a specific input on the TV or monitor. * If it's just a monitor and not a multi-function TV that also has a Computer to video input then you need to check the device that's hooked up to the monitor as single function monitor's usually only have one input. * If this is a TV then you need to go to the TV menu and check the "Input Source" to make sure it's on the input plug your using. (I'm using HDMi-2 on my laptop to TV) * If it's not on the correct input then there will be a different signal (DVD, VCR, etc.) or none at all (No Signal) if those units are turned off. * Unplug all devices (to reset) and count to 10. Power up and perform set up to your existing configuration. * Note; as of Jan 2018 most cable TV are not broadcasting in analog (chan 3) and must use a digital tuner to get signal. Some cable Co. provide converters (for a fee?) * Check with your service provider for more information. Aloha, ukeboy57 PS, If you do have a damaged input (or feed) then check your video device for alternative outputs; IE: RCA Vid-Right-Left audio, HDMI, Split video (Y-G-B), VGA, S-plug, etc.
12/30/2018 6:37:33 PM • ViewSonic... • Answered on Dec 30, 2018
My Viewsonic T-46 is stuck in scanning and repairing C drive on start. Can I stop or work around this?
no PC stated. no OS stated, so... weak answers... next.actually only old windows did that! once it needs to do that, that means the HDD shows errors. they are not ever supposed to show errorsand in fact self repair them selves (2001 to now HDD)what I do is shut the PC off.them test the hDD as remote disk and run smart testsor boot the same PC with say linux demo disk (or usb stick)and RUN SMART test.if the fail the HDD is no good. hopeless cases.the next actions is backup data.the PC you have running silly old chkdskwill actually damage more data doing that,that is why w10 does not do that, it just tells you smart fails on HDD0 or the like.Just 2 steps of you have the linux media pre made.as all techs do.no PC stated and viewsonic is not a PC.boot to linux, click try me, then run disktestif it fails smart tests the hdd is bad.http://pcdied.com/linux.html
12/22/2018 8:24:18 PM • ViewSonic... • Answered on Dec 22, 2018
Va1928 opening case - ViewSonic VA1928wm Monitor
so you want to open the va1928 case.did you take off the stand and full remove the stand mount first.and see screws hidden there, did you remove all screws on the back first? the mount is steel and has 4 screws , off those first.the book is free to read, users guidepage 10, says wall mountthis 1 page shows,1: remove the snap off lastic panel first. that normally hide cables on rear, or just hides the steel mount.and the magic 4 screws on it. then pry it.steps 1 to 4, page 10https://www.manualslib.com/manual/266493/Viewsonic-Va1926w.html?page=10#manualthen remove all other screws you see and it comes apart.this is close, nice clear english too. refreshing.https://www.youtube.com/watch?v=UJuMdIUQ_k8 the pr ytools are; in order of best to worst are.1: using std, cell phone pry tools.2: using a Guitar pick,3: wreck your CC , us an old useless credit card.4: now use screwdriver an mangle the edges for "art"5: claw hammer it? or a finely sharpened crow bar?
12/22/2018 8:20:21 PM • ViewSonic... • Answered on Dec 22, 2018
My Viewsonic VW2439WM dual display monitor now has a green tint.
VW? what is this VW? prefix? VX or VG is common,Im guessing VXthe manual has no word "dual" in it,so that is perplexing.are you attempting dual displays on 1 PC, (unstated PC)yes, /nothe VX has 3 inputs ports, dvi, vga and HDMIi guess the VGA port fails.why not use VGA to DVI adapter, even as a test. dirt cheap too.why not test any monitor on 2 PC'S Not just 1.then you learn if the monitor is good or bad, in one simple step.?why ask this? you told me HDMI works so why not use HDMI.or does the VGA port must work for other computers, we dont know how any one uses monitors, the possibles are endless.even as service monitor, ok?if the VGA fails on 2 PCs, (it spec resolution) the port is bad.RGB, did you reset the monitor first, do the OSD reset stated in the manual. sure worth a shot that....called RECALL in the manual please read the manual. page 15.page 12Color Adjust provides several color adjustment modes, including preset colortemperatures and a User Color mode which allows independent adjustment ofred (R), green (G), and blue (B). The factory setting for this product is 6500K(6500 Kelvin). make sure not fiddled wrong?
12/20/2018 1:11:46 PM • ViewSonic... • Answered on Dec 20, 2018
Can a viewsonic vsd220 smart monitor get firmware updates
no , leave it alone if a monitor runs perfectly do not mess with that. but yes, only Viewsonic.com can help, only them. they made it we make nothing at all here,.
12/18/2018 10:48:50 PM • ViewSonic... • Answered on Dec 18, 2018
ViewSonic VA1913w Monitor Logo
5 questions posted
Top ViewSonic Computers & Internet Experts
Ekse
Michael Thomas
Michael Thomas
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ViewSonic Computers & Internet
Most Popular Question
blinking off light
  • Computers & Internet
