20 Most Recent Canon iP2700 Inkjet Photo Printer Questions & Answers
it basically disconnected from network you need to connect it again with network just look for wireless network wizard and the follow the option
skype id :Johnwalker800969
Canon iP2700... | Answered on Sep 12, 2016
If you wish to get some details; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
Canon iP2700... | Answered on Jun 13, 2016
Try to clean the encoder strip inside the printer,open the cover and clean it with your finger gently.hope it works
Canon iP2700... | Answered on Jul 16, 2015
Run the utility maintenance printer coming with the printer , for to clean the head from your printer.
God bless you
Canon iP2700... | Answered on Mar 19, 2015
cannon ip2700 printer error number 5B00
Canon iP2700... | Answered on Apr 23, 2014
head are not rining
Canon iP2700... | Answered on Dec 03, 2013
After refilling your ink, it may prompt your ink very low... but it is nature there is no problem and effect for that... don worry! All the Canon printer prompt like that.... thanks
follow this instruction and fix it. God bless you
  • 1
    Make sure that the printer is connected to a power outlet. The power cable should be connected in the back of the printer and to a working electrical socket.
  • 2
    Check that the wire from the printer is running to the correct port on the computer tower. The wire runs from the small, square port on the printer to one of the USB ports on your tower or laptop computer.
  • Sponsored Links
  • 3
    Turn the printer on. Much of your printing failures can be avoided by making sure that the power is turned on before selecting the print command.
  • 4
    Install any updates or replacement software needed to run your printer on your computer. You can get this software from the manufacturer's website and will be notified through your printer drive if there is something new to download.
Feeder Problems
  • 5
    Pull out all of the paper supply in the printer and make sure that all pieces of paper are flat and whole. Any folded corners, crumpled sheets or torn pieces should be thrown away.
  • 6
    Check the size of the paper you are using and check the paper guide on the supply to make sure the paper is the correct size. The paper guide is the small plastic clip that holds the paper steady in the feeder.
  • 7
    Open the cover of the printer and make sure there is no paper stuck within the feed rollers. You should pull out the jammed paper if there is any, including any little torn pieces that may be stuck inside.
  • 8
    Clean out the feed rollers with compressed air to remove any dirt inside the printer and refill the paper supply.
Ink Problems
  • 9
    Check the ink levels in your cartridges to see if you have to replace the ink. You can do this through the control panel of your printer software. If you don't know where to find these controls, just search your computer for 'printer drive'.
  • 10
    Open the cover of the printer and wait for the ink cartridges to stop in front of you within the printer. This will allow you to take them out and replace them with full ones.
  • 11
    Pull the cartridges out of the printer. The number of cartridges and how to remove them will vary with your model of printer, but usually there is a small clip holding the top edge of the cartridge in place. Just push this clip back and pull the ink out.
  • 12
    Pull the protective seal off the head of the new ink cartridge. This is where the ink comes out and when you pull off the seal it will allow the ink to descend.
  • 13
    Drop the ink cartridges into the printer and push each cartridge into place. If there are clips you will hear them click when the cartridges are in place.
  • 14
    Run a diagnostics test on your ink heads if your ink problems persist after refilling the ink. This will help you clear out the heads.
Read more: http://www.ehow.com/how_6789824_troubleshoot-canon-printer-problems.html#ixzz2ZRL06I56
Canon iP2700... | Answered on Jul 18, 2013
Press resume button for 5 secs. This works for other canon models using cis.
Thank you for using fixya, have a nice day!
If this helps, please rate me :)
Canon iP2700... | Answered on Jun 01, 2013
Canon iP2700 Inkjet Photo Printer Logo
98 questions posted
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
printer error 5b00 ip2700
  • Office Equipment & Supplies
