20 Most Recent Magic Chef MCBR360S Stainless Steel Compact Refrigerator Questions & Answers
sadly we can not . try a local appliance repair service
Magic Chef... | Answered on Dec 03, 2017
First you have to leak test it
If you have lost refrigerant, may as well
buy a new one
ALL refrigerant work has to be done
by trained people
NO Refrigerant products come with provision
to attach hose gauge assy
You have to add clamp on or solder on line taps
Not worth doing & if it has R22 it has been band
as of Jan 2014
Magic Chef... | Answered on May 12, 2014
Could be bad start/over load relay, or bad compressor. Try unplugging your frig for say 30 to 40 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. When the start/over load relay fails, it can apply power to both the compressors start coil AND it's run coil at the same time for to long and it very quickly causes and over load situation. I bet your "Starting Components" (start/over load relay) are bad. Any decent appliance parts store will have what you need. Just take in the make, model, and serial number of tour frig.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Magic Chef... | Answered on Oct 12, 2013
You need to replace the start relay and the overload relay.
Here is the overload relay to order.
Here is the start relay to order.
Keep me posted!
then its not a fridge its a cupboard,
Magic Chef... | Answered on Mar 23, 2013
The problem when moisture and oxygen enters the sealed system, it breaks down the refrigerant into hydrochloric and hydrofluoric acids, which then in turn damage the mechanical components. You have a major problem, and I'll save you a house call charge by telling you that the entire sealed system has to be replaced. If you only have the system evacuated and dehydrated, then recharge the system, which even if its done properly and legally, by an EPA Certified Type I Technician, in other words, not recommended for a DIYer, due to the process required, would still be a major repair, and would not last as long as it should due to the acid damage.
Magic Chef... | Answered on Nov 02, 2012
This question has been answered before. I typed your question into Google, and found this info at a FixYa url:
http://www.fixya.com/support/t6042957-fridge_stop_working_comperssor_very
You will need to copy and paste the URL into your Web Browser. There are other links and solutions provided on Google. Hope this helps!
Magic Chef... | Answered on Aug 11, 2012
replace the ptc overload/relay on the compressor this will fix your problem
Magic Chef... | Answered on May 28, 2012
That is called the drain pan. When the machine goes into defrost to clear the ice away form the evaporator coild, the water drains from the freezer into this pan where it then is evaporated from the condensor fan which draws heat from the copmpressor and blows it across the water.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Magic Chef... | Answered on May 19, 2012
The first thing you want to do is open the freezer and see if the fan inside there is running. The reason is the freezer cools the refrigerator side by circulating air from the freezer. If the fan is running then your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
Magic Chef... | Answered on May 18, 2012
Magic Chef MCBR360S Stainless Steel Compact Refrigerator Logo
49 questions posted
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Magic Chef Refrigerators
Most Popular Question
need new start device mcbr360s
  • Refrigerators
