20 Most Recent Bosch Tassimo T65 Questions & Answers
Why does my Tassimo stop and flash refer to user manuel which I haven't got
If you put Bosch Tassimo user manual into Google you will be able to get download and print off a manual.
3/14/2016 5:12:59 AM • Bosch Tassimo... • Answered on Mar 14, 2016
Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it
Bosch Tassimo T65 Repair Questions,... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > Bosch > TASSIMO
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it · Bosch Tassimo... ' Posted on Aug 23, 2014 ' Be the ...
Bosch TASSIMO red light water full Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/red_light_water.../tassimo
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it. Aug 23, 2014 ' Coffee Makers & Espresso Machines.
Bosch TASSIMO cleaning condensation tray Unsolved ...
www.fixya.com/unsolved_problems/...condensation_tray/.../tassimo
12/18/2015 1:00:52 AM • Bosch Tassimo... • Answered on Dec 18, 2015
My Bosch tas45 is leaking water underneath
repair services know how to fix them
8/12/2021 8:19:00 AM • Bosch TASSIMO... • Answered on Aug 12, 2021
How do I Descale my bosh tassimo with baking soda
Use what the brand recommend.
You are only asking for trouble if not.
Believe me.
This is part of my daily work.
Greetings from
Certified Bosch Siemens tech
9/9/2019 5:15:49 PM • Bosch TASSIMO... • Answered on Sep 09, 2019
5answers
Bosch Tassimo machine leaking from inside! How do I dismatle it?
Before you attempt to dismantle the Bosch Tassimo, you need to determine how/where it is leaking. (1) Before making a drink with the unit remove the cup tray and ensure the bottom where it fits is dry. Replace the drink tray (2) Make a drink or use the cleaning disk, put a cup under as normal and start the cycle. (3) After the drink is made or a clean cycle remove the bottom cup tray and see if the bottom where it fits is wet.
If it's wet you have two (2) problems
(1) The pressure valve on the top of the heater is staying open, usually due to using water that has lots of calcium in it. (2) The pipe that leads from this pipe to the bottom tray is leaking (it's not a good fit in any of these machines, and causes water to drip from underneath.
Don't take it apart yet! Buy some de-scaler from AP-Wagner.com and run this a few times, it should clear it. If it doesn't you have no choice but to open the thing.
If you have the model with a filter use it and change it when it tells you. If you don't have a built in filter, don't use water directly from the tap, run water through a Brita filter or similar
If the bottom tray doesn't get wet, take it apart to see where it's leaking. 99.99999999999999% of the time it the valve.
So how to take the thing apart.
(1) The sides (silver or black) slide to the rear. However, you have to put something in the back between the side and the rear cover to pry them apart while pushing to the rear. It's very difficult. I use a 6" steel ruler. You have to bend the sides to overcome the catches that hold them in place. You'll see a small rectangular slot at the back of each side. They will come off eventually.
(2) Once off you'll have to remove the lid where you put the disc in. Remove the 4 screws under the lid deck. (3) Remove the water pipe screws (2) and the bar code scanner screws (2). Be careful of the barcode scanner the cable is very, very delicate (I always unplug it from the circuit board and remove it completely, lift the black tabs at either side of the cable). Lift of the lid assembly. (3a) Remove the screw from the underneath the unit at the back, this allows the front to move out. (4) At each corner of the top carefully pry the locking mechanisms until the top is free. Remove the pink (thick) pipe and the pink (thin) pipe and turn the top around out of the way of the heater unit. A coiled steel spring will drop out, it's easy to replace when the top is back on. (5) Where the thin pink pipe goes to is a back pressure release valve carefully pry the clips apart and remove. Take out the rubber O-ring and the valve. Carefully remove any calcified deposits from under the rubber (blue) valve. (6) Reassemble valve (7) Reassemble top, and lid taking care with the bar code reader. (8) Test before replacing the sides
The thick pink pipe that descends from the top, that you removed earlier goes to the bottom tray, you will notice it is very loose (they all are) and it leaks. Put a tie wrap around it to seal it.
Good luck, it's not an easy fix, they were never meant to be taken apart to be repaired - not very ECO friendly. Let your MP/Congressman know, these should end up in a landfill because of 50 cent valve, and they don't come apart.
2/23/2019 7:02:17 PM • Bosch TASSIMO... • Answered on Feb 23, 2019
Bosh tassimo coffee machine only works on first part of clean dose not clean second part no frothy milk
My bosh coffee machine heats the milk the coffee comes through but the water doesn’t this pours out all over the worktop.
2/23/2019 6:59:56 PM • Bosch TASSIMO... • Answered on Feb 23, 2019
Tassimo lid stuck
Common problem with them. They are having issues with the lids locking and not unlocking. They suggest you call 1-877-834-7271 customer service. They've been having people return them.
5/7/2018 5:28:47 PM • Bosch TASSIMO... • Answered on May 07, 2018
0answers
The lid won't open
Shut off & Pull harder! Milk may have escaped and dried it shut. then clean the inside and remove parts and soak those too in hot soapy water...
8/30/2016 1:28:37 PM • Bosch TASSIMO... • Answered on Aug 30, 2016
Requires 220v, can it be converted to 110v?
NO if the plate states 220 volts ten it has be constructed to run 220 volts if you powr supply is 110 volts you may be able to get an inverter that will boost that power supply to 220-240 volts
3/31/2016 11:40:17 PM • Bosch TASSIMO... • Answered on Mar 31, 2016
Why is my tassimo not putting out enough water when making coffee
Descaled and cleaned but still not getting a full cup !!
3/13/2016 12:03:55 PM • Bosch TASSIMO... • Answered on Mar 13, 2016
Bosch Tassimo T65 Logo
3 questions posted
Top Bosch Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
ray gallant
ADMIN Canada
ADMIN Canada
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
TASSIMO Bosch
  • TASSIMO Bosch
Most Popular Question
tassimo stop flash refer user manuel got
  • Coffee Makers & Espresso Machines
