20 Most Recent
Phylrich Mirabella 3/4 Inch Thermostat, Trim Only - TH234TO_047 Questions & Answers
How to modify kenwood th234 from channel mode to vfo mode?
manual.
kenwood.com/files/B62-0790-10.pdf
o Contains 60 memory channels programmable with desired frequencies and ... o Do not modify this transceiver unless instructed by this manual or by ... BASIC TRANSCEIVER MODES . ..... 1 Press [VFO] to select VFO mode. P1'I switch, and ...
manual.
kenwood.com/files/TH-D7-English.pdf
memory channel to be named using up to 8 ... Do not modify this transceiver unless instructed by ...... In VFO or Memory Recall mode, use the keypad to select a ...
www.welcomehome.org/rainbow/.../
kenwood/
kenwood-th78-mods.html
Nov 17, 1995 - (When William's early-model TH-78 was upgraded his mods (removed .... channel (if in memory recall mode) or last frequency (if in VFO mode).Missing: th234
12/21/2015 1:44:19 AM •
Phylrich...
Answered
on Dec 21, 2015
What is sketching?
Artists often sketch out their thoughts for a painting
before actually painting it. Sketch sets have paper, pencils, colors and other
items such as pastels, and charcoal that one would need for sketching purposes.
A sketch is the first step you need to do before you start painting.
How do I remove air bubbles from resin artwork?
I often get asked the question, "How do I remove air bubbles from epoxy resin artwork?" If you've ever seen blisters or bubbles in your epoxy resin artwork, then you're not alone. It happens to the best of us. These air bubbles are caused by trapped air. There's two ways to get rid of that pesky air: 1. Gently push the bubble to coax it out 2. Pop the bubble The best method for removing air bubbles is to use a Dremel or drill bit (which is what I use). It makes easy work of pushing the air out and makes perfect round holes as well. Now when time comes for casting resin, don't forget your hole!
Press drying flowers
What you can do is put the flower between two pieces of tissue paper in a heavy book and microwave the book for about thirty seconds at a time until done.
I have a Cricut expression 2. It turns on but I'm unable to get the home screen to come on. The screen just freezes on Cricut expression 2
- Turn on the machine, with no cartridge installed. Roll the Speed, Size and Pressure dials all the way down to the lowest possible setting on each.
- Grab the blade assembly with two fingers and pull the carriage gently all the way to the left. Behind where the carriage usually sits is a red button. Press and hold the button for three to five seconds and release.
- Go back to the three dials marked Speed, Size and Pressure, and roll each one all the way up and down three or four times.
- Press the Cut button, then turn off the machine. Let the machine sit for 15 to 20 minutes to clear the memory.
- Load a cartridge, turn the machine back on and try it out. If you are still experiencing problems, you may have a defective machine. Return it to the manufacturer with the original receipt.
Brio train 512
Depends what you mean by small hills? Has the loco climbed these small hills in the past without problem? A one in twelve (one inch climb for every twelve inches travelled) incline is about as much as this loco could manage I imagine, and even less when loaded with box cars etc. Sadly the traction drive on these loco's seems to have a short life. I have heard that giving the loco a good firm solid whack down onto a hard surface may get the internal gears to settle down and get more traction. There's an average chance it might work. Do not attempt to open it up, this will create a real mess because it's just about impossible to get all the minute loaded springs back into their correct place.
