20 Most Recent Acer Iconia B1 7-Inch Tablet Black Dual Core A9 1.2Ghz, 512Mb Ram, 8Gb Emmc, Camera, Wi-Fi, Bt, Android 4.1 Questions & Answers
How do I get a smart looking widget for my home page? [email protected]
Look in play store for widgets. Suggestions 1. BBC weather 2. Sky News Top Free in Widgets
7/9/2019 4:13:37 PM • Acer Iconia B1... • Answered on Jul 09, 2019
Acer iconi b1 thermal warning
why does my acer iconia keep saying Thermal warning and shutting down when I have only just switched it on?
7/18/2016 7:44:41 PM • Acer Iconia B1... • Answered on Jul 18, 2016
2answers
Download user manuel
Whether it's a *.pdf file or not, as soon as 1 programme can display the content of the manual, the same programme should be able to print it. e.g. print from adobe accrobat reader directly. Otherwise install the "open office" suite (costs 0) to open the manual file. that software should be able to print the content. (make sure the printer is correctly installed on your system.) Good luck!
4/27/2016 2:27:21 PM • Acer Iconia B1... • Answered on Apr 27, 2016
How do I repair the USB PORT on a ACER ICONIA B1.
Step 1 - Back Case
  • To start, gently separate one corner of the case using the black spudger.
Step 2
  • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
Step 3 - Battery
  • Remove the 5mm screws that are securing the battery to the rest of the tablet.
    • Use the Phillips #00 Screwdriver to remove the 5mm screws.
Step 4 ΒΆ
  • Use the sharper end of the spudger to disconnect the battery from the mother board.
    • The battery connector will slide off.
Step 5 - USB Port
  • After setting aside the battery, remove the two 5mm screws holding the metal plate over the USB port.
Step 6
  • Find and remove the silver 5mm screw holding down the metal cover opposite the USB port.
Step 7
  • Disconnect the blue cable by gently lifting the flap.
  • Remove the indicated 2mm screw holding the speaker in place.
Step 8
  • Pull up the metal panel just enough to allow access, then remove the USB port.
10/29/2014 2:34:23 PM • Acer Iconia B1... • Answered on Oct 29, 2014
User manual
8/3/2014 7:34:10 AM • Acer Iconia B1... • Answered on Aug 03, 2014
How to turn demo mode off on acer b1-720
take the battery out and restart the unit
8/1/2014 3:23:35 AM • Acer Iconia B1... • Answered on Aug 01, 2014
Can sign in to my tablet after my child had attempts 10 time to resolve the screen security
Is your data connection working? If its not then you have a huge problem then go to this webpage this may solve it or even not "http://support.google.com/android/bin/answer.py?hl=en&topic=2500700&ctx=topic&answer=2569768 " OR if you are agreed to lose data to gain access to your phone then get in the boot recovery of the phone.(different phones have different method to get in boot recovery.example- for samsung in switch off condition press "home" +"power key".then go to factory reset and select yes then your phone will be starting new with no lock. OR if you dont want to lose your data get "screen lock bypass" pro version to reset the PIN or lock. But its to late as it should be pre loaded!! OR there are many ways but you will not understand just reset the phone!!
6/20/2014 3:34:01 PM • Acer Iconia B1... • Answered on Jun 20, 2014
0answers
How do i get numbers from my key pad as well as letters?
Your NUMBER pad is down in left corner where it has ABC KEY.It has a ?123 key. Hit it and the alpha keypad will change to numbers.chad man
11/16/2013 2:14:57 PM • Acer Iconia B1... • Answered on Nov 16, 2013
How do you unfreeze an acer tablet
mine did the same. cant do anything !!!
8/26/2013 8:21:17 PM • Acer Iconia B1... • Answered on Aug 26, 2013
How do I delete Kindle books from my acer tablet
You should be able to go to Settings, then locate Apps, then Kindle in the list of Apps, Then Uninstall Kindle.
12/22/2020 4:55:27 PM • Acer Tablets &... • Answered on Dec 22, 2020
My acer iconia tab B A1-A40 won't turn on
check poer button first
12/4/2020 7:52:10 PM • Acer Tablets &... • Answered on Dec 04, 2020
Acer Iconia B1 7-Inch Tablet Black Dual Core A9 1.2Ghz, 512Mb Ram, 8Gb Emmc, Camera, Wi-Fi, Bt, Android 4.1 Logo
29 questions posted
Top Acer Tablets & eReaders Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
NOEL
NOEL
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Acer Tablets & eReaders
Most Popular Question
repair usb port acer iconia b1
  • Tablets & eReaders
