20 Most Recent Pioneer PRO-100 TV Questions & Answers
Check and replace its tuner. It is faulty. If you wish to get some details; visit the site linked here. Pull up older posts.
Pioneer PRO-100... | Answered on Jul 13, 2017
convergence can not go all a suddenly it might be due to magnetic affact.if it is so remove it very near to tv or you must have tilted tv due to some reason. if it is due to ckt near e/w correction.
Pioneer PRO-100... | Answered on Mar 22, 2012
Retire it? Are there no television servicers in your area? Being a tech wizard seems to be a requirement for merely hooking up and operating some systems, but repair is still a valid option for most electronic items. Consult an experienced electronic technician specialized in television repair, another 10 years of operation is possible. Needless disposal only depletes our landfill space.
Pioneer PRO-100... | Answered on Sep 05, 2009
hi..first check it out the brightness.It is available in the
menu button,available on the top of the tv.If it still doesnt
work Projection TVs have a high intensity lamp as the light
source. They wear out and gradually get dim.You probably
need to replace it.
check it out..
thank u..
rate my response..
Pioneer PRO-100... | Answered on May 05, 2009
Hi, afraid Tvs aint somthing i fix but i found this service manual thought it might help. http://www.tradebit.com/filesharing.php/1/132 All the best John
Pioneer PRO-100... | Answered on Jan 14, 2009
In the center of the console on the tv below the screen there should be a push button you can get to with a paperclip or something similar, however the service mode options are not exactly self explainitory
Pioneer PRO-100... | Answered on Jan 08, 2009
My set is doing the same thing again. The last time I fixed this (4 years ago) it was a capacitor gone bad in the power supply for the 24v standby circuit. (C166)
The service manuals can be ordered directly from Pioneer Part Number ARP3014 for Pro-100 model.
Pioneer PRO-100... | Answered on Dec 21, 2008
If the picture looks like you need 3-D glasses to view it, the problem is you have two bad convergence IC's. if that was the case, 450 bucks is a bit steep for this repair. It should run you about 250 to 300 bucks. Good Luck
Pioneer PRO-100... | Answered on Nov 21, 2008
Could be a few things.First check your sleep timer.Sounds like a fail safe mode that when the tvs left on accidentally it shuts itself down so it wont overheat and die prematurely.The last resort is to remove the circuit board and carefully inspect the solder joints near the power supply with a magnifying glass and a bright light.Then resolder those.
Pioneer PRO-100... | Answered on Dec 28, 2006
Rachael, The Pioneer PRO-100 is a rear projection 51 inch TV of 1000 lines resolution. I do not know enough about the type of projection to answer this question. They use Liquid Crystal Display panels through which a powerful light shines, or Texas DLP micro-mirrors which reflect the light. As the deflection is digital in nature it does not `die' like a C R Tubed television. Are you saying now it won't come on at all, and shows the red light? I can only think it is like a projector and has fans to cool the lamp. To start with the fan may get squeaky due to a dry bearing (common problem). Eventually the fan will stop or not supply enough air and the lamp will overheat and burn out. They cost 250£ to 450£ to replace.(UHP mercury vapour lamps) In your TV it seems that something in the optics has bad distortion and de-focussing due to the overheated lamp. This could be much more expensive to put right.
Pioneer PRO-100... | Answered on Oct 23, 2006
As long as you have a HDMI port you should be able to use it. If you have only one, you won't be able to have any other player plugged in. The firestick doesn't care if the port it is plugged into is labeled 1 or 2 or 3
Pioneer... | Answered on Nov 09, 2019
Pioneer PRO-100 TV Logo
Popular Tags
17 questions posted
Top Pioneer Televison & Video Experts
Marvin
Marvin
Ekse
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Televison & Video
Most Popular Question
pioneer elite pro 100 projection tv
  • Televison & Video
