20 Most Recent Pioneer PureVision PDP-503MXE 50 in. Plasma Television Questions & Answers
My pd503mxe power supply got
Hi, I have a main power supply board which I may sell as I have replaced mine and it has turned out to not be the faulty board, Kevin. Board number is axy 1059-H
3/9/2014 5:10:29 PM • Pioneer... • Answered on Mar 09, 2014
Pioneer 503mxe cant wire it up
To connect as you describe you will need a tuner card as the 503MXE is a monitor rather than a receiver. Otherwise the only option is to connect a scart to the 5xBNC connectors (Input 2) but you will need to be sure that your digi box outputs RGB over scart. If you have the optional video card (PDA 5002) fitted then you can connect via the s-video connection (Input 3) assuming your digi box has an s-video output.
2/27/2013 7:45:02 PM • Pioneer... • Answered on Feb 27, 2013
I have a PDP 503 mxe that when you switch it on the stand by red light comes on. when i then press the remote to switch it on the grenn light comes on for a few seconds then goes out. the screen fails
That problem is usually have 2 causes..Its either power supply board or main board..Please take this steps on how to determine the problem:1. Open the back cover.2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..4. If the power supply output is normal..The problem could be on the main board...5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..Hope this solution will be helpful..Thanks for using fixya...
6/7/2012 11:27:19 AM • Pioneer... • Answered on Jun 07, 2012
0answers
Why is my pdp503mxe plasma
By blue screen, do you mean the no input screen? Please clarify this so that I can help you with your problem.
2/17/2011 3:11:33 AM • Pioneer... • Answered on Feb 17, 2011
I have a pioneer plasma
You may need to go to your menu and run a scan.
2/16/2011 6:36:37 PM • Pioneer... • Answered on Feb 16, 2011
Pioneer PDP 507XDA 50-inch plasma TV. Sound but no picture. SOME CHANNELS WORK BUT OTHERS IS SCREEN SAVER WITH CHANNEL AUDIO.
Question edited for clarity. Great question Madeleine. The ones with Screen Saver and Audio are in Preview Mode. If you want to watch them, you have to subscribe. It is a tactic to get you hooked and get you to pay. Sometimes they will give you a couple of minutes of video and audio at the beginning of a programme. It isn't a television issue, it is your cable provider and a sales technique. ..
3/8/2024 6:48:51 AM • Pioneer... • Answered on Mar 08, 2024
2answers
Pioneer DVR-640H DVD Recorder. Shows "Overheating has stopped operation" error. How to fix it? Thank you.
Remove the case, look for a fan, vacuum the main board and all case vents. ..
3/7/2024 2:31:41 PM • Pioneer... • Answered on Mar 07, 2024
My pioneer 50" plasma tv #PDP 5071 PU won t stay on and the blue ON lite keeps blinking 8 x over and over. Is it dead? Did Comcast update fry it? It started yesterday. I tried unplugging it.
Sorry you're having problems. Offhand the 8 blink code on a Pioneer Plasma translates to an internal communication failure in the TV and generally requires repairs. However it's worth it to try a hard reset, as sometimes the processor in the TV can simply have locked up. The first thing you would try, is disconnect the set from power, then press and hold the power button on the TV itself (not the remote), for 10 seconds and release. Then plug the set back in, and also check that the power cord is connected tight at the TV as well. Press power once, and see if the set powers up normally.
2/21/2024 5:51:30 PM • Pioneer... • Answered on Feb 21, 2024
My pioneer amp 820w blinking blue why?
The blue blinking light on your Pioneer amp could indicate a number of issues. One possible reason is that the amp is in "standby" mode, which means that it is not currently receiving any audio signals. Another possibility is that the amp is experiencing an error or malfunction. To get a better understanding of the issue, I would recommend checking the user manual for your Pioneer amp. If you don't have the manual, you can try searching for it online using the model number of your amp. You can also try resetting the amp by unplugging it from the power source for a few minutes and then plugging it back in. If the problem persists, it may be time to take your amp to a professional for repair.
11/20/2023 8:53:25 PM • Pioneer... • Answered on Nov 20, 2023
Pioneer DV-366 says no disc and ejects it?
You need to run a DVD or CD cleaner disc. It has small bristles that clean the dust off the tracking laser. It is less powerful than the reading laser, and is the one that registers there is a disc there. https://www.google.com/search?q=dvd+cleaner+disc ..
11/19/2023 5:44:28 PM • Pioneer... • Answered on Nov 19, 2023
Pioneer plasma TV not working with Roku
Looks like it may be too old? Lots of help below, but this seems hopeful. https://community.roku.com/t5/Roku-setup/Roku-Ultra-with-an-older-HD-plasma-TV-with-1080i-resolution/td-p/561009 Does a Roku Stick Work on Any TV? The Roku Streaming Stick 4K is designed to be compatible with any TV that has an HDMI port. This means it will work on both smart and non-smart TVs, as long as they have an HDMI connection. If your TV is analog, don't worry! You can still use the Roku Streaming Stick 4K by using an AV Composite Converter. This will allow you to enjoy all the features of the Roku Streaming Stick on your TV. All Roku streaming players will work for any television with an HDMI connection, so any Roku player can be connected to a 4K UHD or HDR-compatible television. However, to stream movies and TV shows in 4K UHD or HDR you will need a compatible Roku streaming player and television that supports 4K UHD or HDR. Jul 24, 2023
Do I need a special TV? - Roku Support
Roku https://support.roku.com > en-ca > article
Does Roku Work on Any TV? Here's What You Need to Know
The Home Theater DIY https://thehometheaterdiy.com > does-roku-work-on-a... 2 days ago - Yes, Roku does work on basically any TV as long as it has an HDMI port. Older, lower resolution TV's probably don't need the most updated 4k ...
How to set up your Roku streaming player or ...
Roku https://support.roku.com > Roku setup Jul 24, 2023 - From a USB port on your TV Any Roku Streaming Stick supports USB power, but only some Roku players do. If you are connecting your Roku device ... ‎Roku TV · ‎Roku Streaming Stick 4K · ‎4K TV · ‎Roku Streaming Stick 4K+
Compatibility Unleashed: Does Roku Work on Any TV?
Automate Your Life https://automatelife.net > does-roku-work-on-any-tv 1 day ago - The Roku Streaming Stick 4K is designed to be compatible with any TV that has an HDMI port. This means it will work on both smart and non-smart ... ‎Does a Roku Stick Work on... · ‎Steps to Install Roku on an Old...
9/9/2023 12:14:19 AM • Pioneer... • Answered on Sep 09, 2023
Pioneer vsx1020 wont turn on with telly,if I unplug 15 min from power point does but when turn off telly turn off amp which is good,but if I turn on once again the telly,amp wont turn on
If your Pioneer VSX-1020 receiver is not turning on along with your television, here are a few troubleshooting steps you can try:
  1. Check the power connections: Ensure that the receiver is properly plugged into a power outlet and that the power cable is securely connected to the back of the unit. Also, check if the power outlet is functioning properly by plugging in another device.
  2. Reset the receiver: Perform a soft reset by turning off the receiver, unplugging it from the power source, and waiting for about 15 minutes. Then, plug it back in and turn it on. This can help reset any temporary glitches or issues with the receiver's electronics.
  3. Check the remote control settings: Verify that the remote control is properly set up to control both the television and the receiver. Make sure you have followed the instructions in the receiver's manual for programming the remote control to work with your specific television brand.
  4. Test with a different HDMI cable: If you are using an HDMI connection between the receiver and the television, try using a different HDMI cable to rule out any potential cable issues. Sometimes, a faulty cable can prevent the devices from properly communicating.
  5. Update the firmware: Visit the Pioneer website and check if there are any firmware updates available for your receiver model. Updating the firmware can sometimes resolve compatibility issues and improve overall performance.
  6. Contact customer support: If the issue persists, it may be best to contact Pioneer's customer support for further assistance. They can provide specific troubleshooting steps or advise on whether the receiver may require servicing or repair.
Remember to consult the receiver's manual for additional troubleshooting steps and to ensure you are following the correct procedures for your specific model.
6/18/2023 7:44:46 AM • Pioneer... • Answered on Jun 18, 2023
Pioneer VSX-930. The 'FL' light flashing on and off?
Cindy Wells is a trusted Expert here.
  • Pioneer Master
  • 6,628 Answers
FL OFF could indicate a problem with the power supply or the cooling fan inside the receiver. Try unplugging the unit to reset the error code. If the error persists, the receiver needs to be serviced. If the Pioneer VSX-90 is still under warranty (1 year), contact the manufacturer. Otherwise, decide if it is worth fixing (including the shipping costs and minimum service fee). I wish that I had better news for you. (There are service manuals available for sale online. I know nothing about these vendors.) Cindy Wells Posted on Nov 28, 2022 https://www.google.com/search?q=Pioneer+VSX-930.+The+%27FL%27+light+flashing+on+and+off You can take it to any audio technician locally ..
6/12/2023 6:44:53 PM • Pioneer... • Answered on Jun 12, 2023
How do I fix code sd11 on pioneer elite plasma TV
Take the back off the set and use a can of air to blow out the various heat sinks on the boards along with the fans, it should run much cooler after that and get rid of the code.
6/5/2023 5:34:46 PM • Pioneer... • Answered on Jun 05, 2023
I need a wire diagram for a pioneer avg-p1400dvd
5/23/2023 2:04:38 PM • Pioneer... • Answered on May 23, 2023
PDP-506HDG Pioneer plasma display system TV does not find any hd channels
Try another TV, if that works the issue is with the main board in your Pioneer TV, may be hard to find at a decent price.
4/30/2023 8:41:35 PM • Pioneer... • Answered on Apr 30, 2023
PIONEER PD-M6 MULTI DISC CD PLAYER
Unfortunately t isn't available anywhere. If it was, this link would find it. https://www.google.com/search?q=%22PIONEER+PD-M6%22+replacement+magazine ..
4/11/2023 2:08:03 AM • Pioneer... • Answered on Apr 11, 2023
Pioneer PureVision PDP-503MXE 50 in. Plasma Television Logo
Popular Tags
14 questions posted
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Televison & Video
Most Popular Question
pioneer 503mxe wire up
  • Televison & Video
