20 Most Recent Pioneer PureVision PDP-5030HD 50 in. HD-Ready Plasma Television Questions & Answers
Ok here's how I manage solve the problem... Having the back removed opens the contacts on the interlock switch so I guess if it powers up in this state it senses the high voltages are exposed and for safety shuts down... After this the unit will not power up and the power led flashes red continuously as described before…
After some thought it occurred to me that there may not be a problem at all, just be a simple reset function for this condition… I managed to find an easy solution to this… Just call up the hidden engineer’s service menu – On 3rd generation Pioneer Plasmas it’s as follows > Power down the screen > Hold down the “Input” and “Vol +” buttons on the front > Power the screen up and the Service menu comes up on the screen > You don't need to change anything just simply power off and from then the screen should operate as normal…It did for me so I’m well happy now!!
I hope this information will help someone else one day – Good Luck!!…Rob UK…
Pioneer... • Answered on Nov 26, 2017
First check batteries in the remote are charged.Try pushing one of the channel selection numbers on the remote as it may be the off/on on your remote is stuck or has died completely. if this does not fix the problem try unplugging the set from the wall wait 5 mins (approx) and re plug into wall socket and try turning on .
Pioneer... • Answered on Oct 25, 2017
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/ http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty.
Pioneer... • Answered on Jun 07, 2017
power supply shot ... sometimes x board or y board
Pioneer... • Answered on Apr 28, 2015
REPLACE you power supply & THATS IT! TV PARTS www.shopjimmy.com
Pioneer... • Answered on Feb 08, 2013
I have some of these links but I'm not sure whether it would be helpful for you or not.
POWER/INVERTER ***'Y BD FSP060-3L02 LF - Part number 0500-0405-0580
POWER/INVERTER ***'Y BK01094.011 LF -Part Number 0500-0408-0530
INVERTER BOARD L30WGU - Part number 0940-0000-0140
Hope this was what you were looking for.
Here are the images for some of the components
7809333_l.jpg POWER/INVERTER ASSY BOARD FSP060-3L02 LF / Back light inverter board
It sound that the main power regulator board to your plasma display is faulty. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
Pioneer... • Answered on Nov 04, 2012
TRY BUYING AN 04 RECEIVER IT SHOULD WORK
Pioneer... • Answered on Jan 28, 2011
Wish I knew, have one exact same trouble. Have checked all supply voltages which are correct. It appears that the screen and media Rx are not passing data after turn on, there are no transitions on any of the SDA SCL lines, all are in a high state +5V. There are transitions on them at boot up. I am using a Kworld KW-SA295-Q DE box, has a DVI-I output that provides a great picture on the monitor / screen. I believe the PC/IF board has the problem, but have not found one to substitute to test.
Also the receiver is not set to any of the default conditions.
The tuners are active but are not tuned to channel 2 the ICs not controlled by the data buss all pass signals. My thinking is that the control software has been corrupted. I found the training guide on line that has part of the procedure for upgrading the AVC System software but it is incomplete. If anyone has the info please post or send via E mail shalopt2 at juno dot com
or a known good PC/IF board that I can use for additional testing. There is no OSD as it is provided by the media RX PC/IF board.
gg
Pioneer... • Answered on Jan 09, 2011
Pioneer PureVision PDP-5030HD 50 in. HD-Ready Plasma Television Logo
61 questions posted
Top Pioneer Televison & Video Experts
Demonic-2011
Demonic-2011
Raj Patel
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Televison & Video
Most Popular Question
pioneer pdp 5030 power supply problem
  • Televison & Video
