20 Most Recent NTI Backup Now EZ Questions & Answers
There are 3 possible reasons why you are getting this error message:
1. An invalid character in QuickBooks installation path.
2. An incorrect path setting in the Windows registry.
3.Insufficient hard drive space available to install the QuickBooks program.
To fix this problem, please do the following:
  1. Restart your computer, and reinstall QuickBooks.
  2. Confirm that at least 2.5 GB of disk space is available for installing QuickBooks (Quickbooks 2010 requires 1.5GB of disk space):
    1. Double-click the Computer (for Windows 7 or Vista) or My Computer (for Windows XP) icon on your Windows desktop.
    2. Note the amount of free space shown in the window next to the drive letter where QuickBooks is being installed:
      • If the amount of free space is less than 1 GB, free up disk space before installing QuickBooks or install QuickBooks on a different drive.
      • If the amount of free space is greater than 1 GB, proceed with step 2.
  3. Remove invalid characters from the QuickBooks installation path:
    1. Right-click the Windows Start button and select Explore.
    2. Navigate to the path shown in the error:
      • If there are non-alphanumeric characters in the name of any folder in the installation path, right-click the folder and select Rename to remove them, and then reinstall QuickBooks.
      • If there are only alphanumeric characters in the installation path, proceed with step 3.
  4. Create a new user in Windows to rewrite any Windows registry settings that may be causing the error and log in as that user to install QuickBooks.
Note: You must be logged in as a Windows administrator or as a member of the Administrator group to add a new user.
If this solution does not resolve the issue, you can read discussions and post messages and questions relating to your issue on the Intuit QuickBooks Community site for free, or you can contact a technical support agent for additional guidance. Fees may apply.
NTI Backup Now... | Answered on Mar 21, 2018
Try AOMEI Data Backuper, a free backup and restore software. It can help you restore from the backups. http://www.aomeitech.com/aomei-data-backuper.html
NTI Backup Now... | Answered on Jul 02, 2017
Maybe the restore function only works with the original piece of equipment. Ouch.
You might want to contact the manufacturer of the software to see if they have a fix or solution. Good luck!
NTI Backup Now... | Answered on Apr 10, 2017
1.Log on to the computer by using an account that has administrator rights.
2.Click Start Collapse this imageExpand this im, type msconfig.exe in the Start Search box, and then press ENTER to start the System Configuration Utility.
·Collapse this imageExpand thisIf you are prompted for an administrator password or for confirmation, type your password, or click Continue.
3.On the General tab, click Selective Startup, and then click to clear the Load startup items check box. (TheUse Original Boot.ini check box is unavailable.)
4.On the Services tab, click to select the Hide all Microsoft services check box, and then click Disable all.
Note Following this step lets Microsoft services continue to run. These services include Networking, Plug and Play, Event Logging, Error Reporting, and other services. If you disable these services, you may permanently delete all restore points. Do not do this if you want to use the System Restore utility together with existing restore points.
5.Click OK, and then click Restart.
NTI Backup Now... | Answered on Sep 04, 2015
Mac and windows 7 they can work as dual boot depends your motherboard specs i would need to see what pc or laptop to make sure pls contact me see if i can help further thanks
NTI Backup Now... | Answered on Oct 12, 2014
You can search your computer for files with a .pst extension by doing a search like *.pst. Once located you can grab them and restore them by opening outlook and choosing to import those files. A bit of a techie solution can be found here How to import from pst file back to Outlook Express AnandTech Forums
NTI Backup Now... | Answered on Sep 09, 2014
Are you sure you have it pointing to the correct drive? Maybe it's looking at the home pc drive.
NTI Backup Now... | Answered on Jul 20, 2014
Did you try to reinstall the EZ software? perhaps you accidentally removed (a part of) a program.
Then try to restor the data again.
NTI Backup Now... | Answered on Jul 10, 2014
  1. Open the windows explorer and navigate to where the backups are.
  2. Switch your view to details
  3. See which backups are the newest, don't delete them
  4. Delete the rest.
  5. Configure the Backup process to make fewer backups, like once per month, or one full, then several incremental ones.
NTI Backup Now... | Answered on Jun 05, 2014
The partition restoration process is extremely lengthy and time consuming, I would suggest trying to do it overnight and if after that it still seems stuck at 0%, then something must be wrong with the restorer.
Computers & Internet Logo
74 questions posted
Popular Products
Top NTI Computers & Internet Experts
Harrie
k24674
Brett
Level 1 Expert
Are you a NTI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • NTI Computers & Internet
Most Popular Question
factory reset
  • Computers & Internet
