20 Most Recent Pioneer SD-P62A3-K 62" Rear Projection Television Questions & Answers
Ok i have a pioneer
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
9/3/2017 9:00:11 AM • Pioneer... • Answered on Sep 03, 2017
2answers
TV comes on with snow and clears up after 10-15 mins
Their is no more you can do.
You need a professional.
Stop using the TV until it is repaired.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
5/1/2012 3:55:57 PM • Pioneer... • Answered on May 01, 2012
The picture gets shakie,then it just turns
the problem on this tv is a lot of loose connection on the power supply board , u need to solder all the componect on the power supply board and sould be ok , or u can hire a tv tech and do this job for u normal repair is about $250
12/1/2010 6:38:38 PM • Pioneer... • Answered on Dec 01, 2010
My SD-P6093-K Pioneer has recently
STK ICs 2 of them,example STK392-110.also CK hori out put transistor and little blue capacitor 2Kvolts it feeds back to Hori Transistor. Mats has STKs
1-800-628-1118 $10.95 each they retail for $55.00 each in repair shops.
3/16/2010 12:04:13 PM • Pioneer... • Answered on Mar 16, 2010
2answers
My SD-P6093-K Pioneer has recently stopped turning
BAD STKs can cause this they are Big black ics will have part # on them,also check 6amp fuse if blowed it will not come on.
7/11/2009 5:12:11 PM • Pioneer... • Answered on Jul 11, 2009
2answers
Pioneer rear projection tv
You might want to check the power supply/deflection board for bad solder connections. i found on the one i was working on. the standby and main power relays was broken loose from the board also check for any other solder joints that look cold jointed. i have been a tv technician for 13 years.
I hope that will fix your problems...
Keith Mitchell...
5/19/2009 4:43:10 AM • Pioneer... • Answered on May 19, 2009
Ok my projection tv when
It would be difficult to fix without an oscilloscope.
I tried to finding a repair manual for your model, but older model manuals are hard to find.
12/4/2008 7:10:48 PM • Pioneer... • Answered on Dec 04, 2008
Tv turns off and wont come back on
mine did same thing fixed @ shop for less than 100.00
1/16/2008 8:56:31 PM • Pioneer... • Answered on Jan 16, 2008
Pioneer SD-62A5 has red standby light, won't turn on
Check C258 video assy.
8/16/2007 7:36:08 PM • Pioneer... • Answered on Aug 16, 2007
Pioneer rear projection tv in standby mode
if the relay clicks when pressing power check C258 in video assy.
8/16/2007 7:34:18 PM • Pioneer... • Answered on Aug 16, 2007
Pioneer plasma TV model PDP-4271HD. When I turn the power on it starts to come on and then shuts down the blue Power indicator light flashes.
Unless your a skilled electronic tech and have the test gear to trouble shoot the set don't waist your money trying to fix it. Plasma sets are about 10x more complex than a LCD set
8/19/2022 9:59:19 PM • Pioneer... • Answered on Aug 19, 2022
Own a pioneer elite VSX-LX302 - how to to unlock the F.IR which has locked by itself
The Lock feature has been activated. Within your user manual the lock function is explained.This happens when Multi Room is selected.De select it.
7/23/2022 6:25:10 AM • Pioneer... • Answered on Jul 23, 2022
2answers
I have a pioneer pro 151 TV having issues turning TV on I get a blue light blinking 9 times
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
7/4/2022 11:36:53 PM • Pioneer... • Answered on Jul 04, 2022
2answers
Pioneer pro 150fd Blinking red light
remote batteries fresh. USA? yp.com call for service TV end. bad PSU in TV or shorts to it. top causes of dead. omg AC power strip dead? connect TV to live wall jack first./
7/4/2022 10:42:41 PM • Pioneer... • Answered on Jul 04, 2022
Pioneer remote stopped working for DVD player DV-490V. How do I reset it?
have you replaced batteries in remote? perhaps remote is not working, you can buy a new one on amazon for $10.00 there is no rest.
6/23/2022 3:01:42 PM • Pioneer... • Answered on Jun 23, 2022
Pioneer plasma black screen
Time for a new TV
6/6/2022 7:51:09 PM • Pioneer... • Answered on Jun 06, 2022
Manual for pioneer axd7247 remote?
How do you program the remote to the stereo
5/22/2022 8:25:06 PM • Pioneer... • Answered on May 22, 2022
Pioneer SD-P62A3-K 62" Rear Projection Television Logo
Popular Tags
13 questions posted
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Televison & Video
Most Popular Question
sd p6093 k pioneer recently
  • Televison & Video
