20 Most Recent Pioneer SD-P50A3Q 50" Rear Projection Television Questions & Answers
Rear projection televisions are old technology. It is probably overheating. Check the cooling fans.
Time to upgrade to a Ultra HD 4K Flatscreen.
Pioneer... | Answered on Mar 07, 2018
Before you decide to throw it out have you tried checking the fuse at the back of the TV?
Could be only a blown fuse that's causing your tv not to switch on.
Good luck.
G.
Pioneer... | Answered on Aug 04, 2011
I only fine 5 fuse where is the 6 fuse locate? Please help I found the 5 on the power board... is the 6 fuse somewhere else not with the power board?
Pioneer... | Answered on Dec 05, 2010
and it does it becuse it is getting a voltage variance from some of the faulty components it has. This is a fail safe to protect the set from catching fire and doing more damage to other as yet non affected components. DIY is not recommended.
Please rate my help++++Thanks for using FIXYA
Pioneer... | Answered on May 23, 2010
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine.
Pioneer... | Answered on Jan 03, 2009
Pioneer... | Answered on Mar 20, 2008
As long as you have a HDMI port you should be able to use it. If you have only one, you won't be able to have any other player plugged in. The firestick doesn't care if the port it is plugged into is labeled 1 or 2 or 3
Pioneer... | Answered on Nov 09, 2019
Pioneer SD-P50A3Q 50" Rear Projection Television Logo
8 questions posted
Top Pioneer Televison & Video Experts
Marvin
Marvin
Ekse
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Televison & Video
Most Popular Question
pioneer 50 inch projection tv turn
  • Televison & Video
