20 Most Recent Pioneer SD-P55A3-K 55" Rear Projection Television Questions & Answers
The problem is on lamp try to replace it to get back the picture..
Pioneer... | Answered on Feb 23, 2012
Sounds like you got a bad connection, that has finally come off.
Moving those big things can cause that.
Open the back and check.
And call an expert.
If ya in VB, I'll do it.
PLEASE RATE THIS ANSWER
Pioneer... | Answered on Aug 29, 2011
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Pioneer... | Answered on Jun 21, 2011
its called an intermitent fault afraid its a dealer to fix it
Pioneer... | Answered on Dec 11, 2010
No,don't this tv is a delicate equipments inside.Tv CRTS R,G,B TUBES guns are easily to be broken if dosen't have the outer frame to protect it.Also the Tv CRTS R,G,B TUBES guns have coolant chemicals inside it,could also damage ur tv even if the CRTS R,G,B TUBES guns are not broken.Tries to put it on the cargo pallet,put a heavy blanket on.Ties it with a heavy ropes tightly and firmly.Than put it in a moving Rider truck or a personal truck.Now firmly sacures the tv for good not to make any movment.Now u can tranport it anywhere.
Pioneer... | Answered on Dec 06, 2010
Look for Blowed Fuse on the Power supply board located in the middle of the board 6.3amps and if its OK then replace Both of the STK ICs Black ICs will have PN STK392-110s use 150s Mats Electronics.com has them these ICs retail for $55.00 each your cost $9.95 1-800-628-1118
Pioneer... | Answered on Sep 18, 2010
probably the solder connections on the convergence board.. solder it up good and it will usually stop blowing that fuse..
what is the fuse #?
let me know if i can be of further asistance
Pioneer... | Answered on Jun 08, 2010
ugly fix but works ! this is a two person easy task ,take back off tv your looking for a litle black box . there are three close together , tap with a pointy screw driver while partner turn tv on off . http://picasaweb.google.com/cyburdinesoftware/Big_screen#5457513254326469986
Pioneer... | Answered on Apr 07, 2010
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Pioneer... | Answered on Apr 03, 2010
Th convergance amps have failed you will half to replace them, or have it done parts are around 70 dollars not and easy fix on a pioneer time consuming
Pioneer... | Answered on Dec 10, 2009
It ur convergence it dead,know how to solders?Tries these websites for convergence kits.Tv repair World.com Tv repair kits.
Pioneer... | Answered on Dec 03, 2009
I suggest you do a technical review porq you may worsen your situation
Pioneer... | Answered on Oct 27, 2009
call someone out to reconverge it for you it shouldnt cost alot and it will get the picture right again
Pioneer... | Answered on Apr 26, 2009
This sounds like a picture mode issue. You maybe in a ZOOM mode. Try adjusting your set to FULL mode. If you are using a Sat receiver or cable box, some of these may have picture viewing mode as well, wich may need to be set in FULL or NORMAL viewing mode.
Good Luck!
Pioneer... | Answered on Apr 11, 2009
That means that the tV is on protection mode, start unplugging the set for some time first.
Pioneer... | Answered on Mar 08, 2009
What you can do is get yourself a service manual from here:
http://servicemanuals.vstore.ca/
They also have spare parts and offer free online advice as you attempt a DIY. The issue is most likely a cold solder somewhere on the power board or some faulty capacitors. If you want to go in for a long term solution, you can easily replace the whole power board or just change the faulty capacitors. You will have to open the back panel and take a look. You can make out which are faulty, because their caps will be swollen on top. Here's a sample pic of a bust capacitor (not same model):
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows this kinda stuff to do it for you, or get a qualified technician.
Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to do it for you.
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Hope that helps!
Pioneer... | Answered on Oct 04, 2008
Power supply problem. Get into the area and try to find out what voltages are out of spec and repair them as such...accordianman
Pioneer... | Answered on Jul 31, 2008
Need to know that you have at least 2 sources for this feature. Do you?...accordianman
This is a common problem with pioneers. try resoldering the vertical output Ic that should remedy the problem. if not the vertical IC may be faulty
Pioneer... | Answered on May 28, 2008
just try to switch the computer off or press ctrl+alt+delete
Pioneer... | Answered on May 08, 2008
Pioneer SD-P55A3-K 55" Rear Projection Television Logo
38 questions posted
Top Pioneer Televison & Video Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Televison & Video
Most Popular Question
pioneer sd p55a3 projection tv stays 5
  • Televison & Video
