20 Most Recent
Black and Decker USA Black & Decker Platinum BDH2000L 20-Volt Max Lithium Ion Cordless Questions & Answers
Model 1001 311 060 Motion security light
Try setting DUAL BRIGHT to OFF.
Be sure daylight sensor is clear.
Try putting unit into test mode and it should be full ON or full OFF. If not, then likely unit is bad.
I am replacing an old dimmer with a new one.
Easiest Way to Replace a 3-Way Switch
If you're simply swapping an old 3-way switch for a new one, use this simple trick to get the wiring right: Before disconnecting any wires on the old switch, find the wire attached to the common screw terminal and label it with a piece of tape. Then, you can disconnect all three wires from the switch, as well as the ground wire. Because the other two wires (the travelers) are interchangeable, it doesn't matter which of the traveler screws you attach them to-there's no need to label them.
Why is my SaniFlo Saniaccess 2 tripping my GFCI constantly?
GFCI or RCD tripping is either moisture has entered the motor body or there is a wiring fault.
Neither of which would I consider a warranty issue especially noting the age.
Call an electrician to diagnose the fault first then take it from there.
