20 Most Recent Visioneer OneTouch 8700 Flatbed Scanner Questions & Answers
2answers
Need drivers for windows xp pro 64
The XP driver is available at:
http://support.visioneer.com/products/8700/downloads.asp
There is no indication of 64-bit or 32-bit support. However, the driver is not guaranteed to work with XP SP2 (only tested with SP1). This suggests that SP3 is also not tested.
I wish that I could be of more help.
3/8/2014 1:24:35 PM • Visioneer... • Answered on Mar 08, 2014
2answers
Need a driver for Visioneer OneTouch 8700 Flatbed
The drivers for supported OS versions are available here: http://support.visioneer.com/products/8700/downloads.asp . The supported OS versions are: Windows XP SP 1 / 2000 Professional / Me / 98SE and the additional software that was bundled on the CD is not included.
If you have a different Microsoft OS, you can check the Microsoft compatibility center for either Vidat or Win7. A check of the Win7 compatibility Center http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx showed some Visioneer OneTouch scanners work with Win7. However, the 8700F is not in the list.
I hope this helps.
(Dual boot with XP or a virtual computer with an older valid OS version will work. The Win7 Pro and Ultimate let you use Virtual PC and XP mode to run an XP virtual computer for free.)
10/25/2012 1:03:12 PM • Visioneer... • Answered on Oct 25, 2012
Can i use one touch 8700 with windows 7
THIS SITE IS RUN BY *****
5/14/2011 6:20:11 PM • Visioneer... • Answered on May 14, 2011
My computer is not reading driver
Here is a web page for a new driver installation. You will need to choose what Windows operating sytem you have
http://www.google.com/search?hl=en&rls=com.microsoft%3Aen-us%3AIE-ContextMenu&rlz=1I7GWYE_en&q=Visioneer+OneTouch+8700+Flatbed+Scanner+driver&aq=f&aqi=&aql=&oq=&gs_rfai=
7/17/2010 12:54:19 PM • Visioneer... • Answered on Jul 17, 2010
2answers
I had a new install of windows xp (with service
You will have to uninstall the device. Delete any files it created on the drive as part of the install. (Not things you'[ve scanned, just program files) then disconnect the scanner. Reattach the scanner in a different USB port (different SCSI id if your using SCSI) and let Windows re-detect the scanner.
This time don't run the setup from the driver CD. Instead let Windows find the scanner and try and set it up on it's own, if it prompts you for a driver, point it to the INF file in the installer directory. If it doesn't, let it use the one it chooses.
After installing in this way you should be able to use the scanner as a TWAIN source from any application.
4/19/2010 7:40:39 PM • Visioneer... • Answered on Apr 19, 2010
4answers
I've seen this question before,
Yes. There are no Drivers. But, few people were Successful in using the Drivers made for One Touch 9420 Vista Drivers. You could also try to Use the same XP Sp1 Driver for Vista.
In these Cases, the only option left would be Hit and Trial. Use the Drivers for Different Model. If you are lucky and the system finds the Compatibility, it's a HIT.
There are certain Web Sites which Sells the Driver. I never came across anyone who was Successful using that Site. I have heard the names, so i would not advise you to take a hit on your Money by paying 40-50 bucks for NO USE.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
1/21/2010 4:49:08 PM • Visioneer... • Answered on Jan 21, 2010
0answers
Will my visioneer 5800usb scanner work with windows 10 ?
Yes. If you don't have the drivers for windows 10. Go to support site, download then & install.
4/28/2019 3:47:38 AM • Visioneer Office... • Answered on Apr 28, 2019
Universal drivers
Go to Visioneer product support site support.visioneer.com/ , enter your model number and search for installation drivers
10/11/2018 10:49:07 AM • Visioneer Office... • Answered on Oct 11, 2018
Have an older Visioneer 7100 USB Scanner, Has worked fine for more than 10 years, Now I can't get any scanned objects to appear on my Paperport Desktop. Have no problem using scanner with all other s
Have you upgraded to newer version of windows? Have you tried reinstalling Paperport? (back up max files 1st) I have had a visioneer and still use Paperport 8. Often I have problems with Windows 8 and reinstall paperport now and then.
6/27/2014 8:39:02 PM • Visioneer Office... • Answered on Jun 27, 2014
Visioneer fu661e scanner driver for windows 7 professional
after dinging i have found your driver http://support.visioneer.com/products/4400/downloads.asp hope that it helped
2/18/2014 11:11:12 PM • Visioneer Office... • Answered on Feb 18, 2014
Visioneer OneTouch 8700 Flatbed Scanner Logo
11 questions posted
Top Visioneer Office Equipment & Supplies Experts
Ekse
scramblepad
scramblepad
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
OneTouch Visioneer
  • OneTouch Visioneer
Most Popular Question
need drivers windows xp pro 64
  • Office Equipment & Supplies
