20 Most Recent Microsoft Office XP Standard for PC Questions & Answers
Boot into safe mode by pressing either F4 or F8 or one of the F buttons (it is different on different computers) when you power on your computer. You have to press it before your computer boots into the operating system. You should get a menu with one of the options that says "Safemode with networking" choose that one and press enter. When you boot into safemode, it loads only the essential services nessary to run your computer. It may look funny because the graphics card does not operate properly in safe mode it is ok. When windows loads, try internet explorer and go to cnet.com and click on downloads at the top of the page. Next find Malwarebytes and download and run a scan. If that doesn't find anything than try spybot search and destroy, or Adaware SE . Then after you remove ALL found threats reboot and it will boot regualy (Not Safemode this time) Wha laa!!!! If that doesn't work than it is too long of a solution to elaborate in this post.
Microsoft Office... | Answered on Jan 07, 2013
There is a hidden admin account. Reboot the computer and tab F8 in one second intervals until you get a menu. Select "Safe Mode". You should see an account Administrator. Click on it and it should login unless someone set a password on it. If it has a password you will need to download the NT Offline password reset tool and boot into that and follow the prompts to remove the password from your account.
Microsoft Office... | Answered on Dec 04, 2012
upgrade the OS.
Hope it helps.
Microsoft Office... | Answered on Oct 17, 2012
buy the upgrade
Microsoft Office... | Answered on May 23, 2012
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Microsoft Office... | Answered on May 15, 2012
seems you need another program just load it down online
Microsoft Office... | Answered on Apr 22, 2012
To uninstall eType:
Enter Start menu> All programs > eType folder and you'll find the uninstall link under eType.
For more details and print screen, see Q 5.14 at www.etype.com/help/faq/configurations/
BTW - To remove only eType's promotion link:
Enter eType's Settings window> Advanced tab and uncheck: "Help keep eType free by sharing with your friends".
Microsoft Office... | Answered on Aug 14, 2011
Do a GOOGLE-search for the 'produkey' software.
Download this software, and run it.
It will tell you the serial-number that you used when you installed MS Office XP. Write the product-key down!
Microsoft Office... | Answered on Dec 14, 2009
Go to Microsoft website and buy approp license fee and you will be issued with a product key
Microsoft Office... | Answered on Jul 07, 2009
All what u need to do are:
  1. copy the whole content of the cd to desktop
  2. open run type regedit
  3. go to local machine>software
  4. find the file named office and delete it
  5. reinstall office from desktop and make sure that the office cd still in ur optic drive
  6. when the pop-up said office cannot ...........appeared select the file from ur cd/dvd drive...solved
It's worked for me hope u too...arigato
Microsoft Office... | Answered on Aug 31, 2020
Use Outlook Repair Toolbox is the best of these Microsoft Outlook PST repair software downloads, letting users quickly and completely restore their lost Outlook messages.
For more: https://www.pstrepairtoolbox.com/
Microsoft Office... | Answered on Oct 19, 2019
You can get a demo off the Microsoft website. Some colleges are a part of a software alliance with Mircosoft and can get Mircosoft software free. Other than that it is impossible to get Word without breaking the law :(
Microsoft Office... | Answered on Sep 25, 2019
On the top of the Microsoft Office 2007 disc you will find the product key which is a combination of both alphabets and digits. Key in that your office will get activated.
If you cannot find you can follow the below steps:
Activate Office 2007
Microsoft Office... | Answered on Jun 13, 2019
First thing to try is completely uninstall the application, and then reinstall it.
Microsoft Office... | Answered on May 09, 2019
Hopefully this is not a spam setup question for the first answer, that will get this whole question deleted. Outlook has a fixed email inbox size and wont deal with a pst file that large. https://support.microsoft.com/en-us/help/982577/the-file-size-limits-of-pst-and-ost-files-are-larger-in-outlook-2010-a
Microsoft Office... | Answered on Apr 01, 2019
I would need a little more info to be certain of what advice to give, but I have experienced similar issues with text boxes not moving automatically down with the rest of the surrounding text when adding more text above the text box. Also, it could be a margin issue, or a header spacing issue. Your problem could be different though. It is likely something in your document is set to a fixed location. Is your word 2016 fully updated? Or did you turn updates off? That could be the issue if you cut and pasted something from the web or a document from work that has newer behind the scenes coding than your home version supports, or some of the data was copied from a different word processing program like libre office or openoffice...
Microsoft Office... | Answered on Mar 12, 2019
Tip
Edit PDF File in Microsoft Word 2013
Microsoft Office includes a new feature named PDF reflow which allows users to open PDF files in Word 2013 and do editing according to the requirement and you can save that file either as Word doc or PDF again. Through simple guide below you may know how to edit PDF in Word .
Step one
Open Word and then to open your PDF file from computer desktop navigate through menu File Open Computer Desktop
Step two
Word will take few minutes to convert PDF into Word Doc file so be patient and let it complete the process. When your file will get open click Enable Editing button
Now, you are enabled to do editing in your document just as you do in a normal Word file
Step three
When you finish editing save your file and navigate through File tab Save As and choose PDF format from the list of options followed by Save as type: or you can set it to Word Doc, it depends on your choice and then click Save button
Predecessors of Microsoft Word has embedded feature to save Word Doc as PDF file but it includes the ability to convert PDF into Word doc and then again save it to PDF, which is quite useful option.
on Aug 22, 2018 | Microsoft Office Computers &...
Hi Sumanth
Try these methods are as follows:
  • Start an Office program that has not been activated.
  • Click Activate Product on the Help menu in any Office program.
  • Run the Office Activation Wizard outside an Office program.
    To do this, click Start, point to Programs, point to Microsoft Office Tools, and then click Activate Product.
    Note This method is not available in Microsoft Office 2003 and the 2007 Microsoft Office system.
For Access 2007, for Excel 2007, for PowerPoint 2007, and for Word 2007, there are two methods to access the Office Activation Wizard. These methods are as follows:
  • Click Activate on the Resources tab. To do this, follow these steps:
    1. Click the Microsoft Office Button, and then click Program Name Options.
    2. Click the Resources tab, and then click Activate.
Thank you
[email protected]
091-9916828137
Microsoft Office... | Answered on May 29, 2018
Microsoft Office XP Standard for PC Logo
Popular Tags
21 questions posted
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Office Microsoft
  • Office Microsoft
Most Popular Question
remove searchnu com 421 from computer
  • Computers & Internet
