20 Most Recent Visioneer OneTouch 9000 Flatbed Scanner Questions & Answers
As far as I am aware there is no Windows 7 Driver available for this scanner Contact Visioneer for a solution
http://www.visioneer.com/company/contact/
Please vote
thank you
Visioneer... | Answered on Feb 03, 2011
Hi, There shouldn't be any problem really. A couple of things you can try: 1. Verify that you have SP2 in the new Dell; 2. Verify that you have USB 2.0; 3. Verify that all your USB are enabled in your CMOS/BIOS; 4. Un-check "Allow computer to turn off this device to save power" in your USB Power Management; 5. Try other USB ports (front/rear). Hope this be of some help/idea. Post back how things turns up or should you need further information. Good luck and kind regards.
Visioneer... | Answered on Dec 01, 2010
take it to the service center and have a professional change the pin power.
Visioneer... | Answered on Jun 11, 2010
What version of windows are you using? Which software are you using to do the scan, and what version? It sounds like either the version of scanning software is incompatible with the version of windows, The USB connection (Assuming it is connected via USB) is a older USB connect (1.0 or 1.1) and a update to the firmware is causing a fault in the final scan, or finally the scanner has gone defunk... time to get a new one.
Visioneer... | Answered on Jun 26, 2009
  1. Toggle the lock switch on the scanner leaving the switch in the unlocked (open padlock) position.
Visioneer... | Answered on Jan 14, 2009
Please have a look at my reply to Happi Cappi, who had similar problem.
Sorry to tell you there are no drivers available
Visioneer... | Answered on Aug 24, 2008
hello walsel
try here for a fresh download Visioneer OneTouch 9000 and 9020 Drivers and Manuals
riz.
  1. Go into the OneTouch properties.
  2. Choose "Configure Before Scan" as the configuration.
  3. Choose the destination to be either "Storage".
Visioneer... | Answered on May 28, 2008
READ THIS ALL THE WAY TO THE END. I CANNOT BE RESPONSIBLE FOR YOUR KNOWLEDGE OR SKILLS.
I assume that the light in the lid does not light when trying to scan a negative.
Remove the lid from the scanner, unplug the connecting lead and lift off.
Remove the TWO screws near to the rear edge, holding the scanner plate in place.
GENTLY lift the lid around 15mm (the edge that has just had the screws removed) and GENTLY move backwards.
This will release the lid and it can be removed.
You will see the circuit board that controls the cold cathode lamp.
Check out the continuity of the lead with a meter.
The lamp can be removed as you will see in the photograph for easy replacement.
Refitting is simply a reversal of the above steps.
Visioneer... | Answered on Mar 30, 2008
Hi Happi,
Sorry but you are not going to be.
I had the 9020 scanner and then I got Vista (which in my opinion was a VERY expensive mistake), and like you I could not get the scanner to work.
I got in touch with Visioneer, and guess what, there are no drivers for vista. Visioneer then go on to tell me that this scanner has reached EOL. ("end of life") well I've had it three years what can I expect.
Sorry for the not nice info., I had to buy another scanner to use with vista..............Thanks Bill
Visioneer... | Answered on Mar 29, 2008
Yes. If you don't have the drivers for windows 10. Go to support site, download then & install.
Visioneer Office... | Answered on Apr 28, 2019
Visioneer OneTouch 9000 Flatbed Scanner Logo
20 questions posted
Top Visioneer Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
OneTouch Visioneer
  • OneTouch Visioneer
Most Popular Question
vista business driver visioneer one
  • Office Equipment & Supplies
