20 Most Recent Pioneer VSX-27TX Receiver Questions & Answers
Hi I have a Pioneer
Turn on your TV and see if it has found its way into the System Setup Menu by mistake.
7/16/2011 12:16:03 AM • Pioneer VSX-27TX... • Answered on Jul 16, 2011
I own a Pioneer VSX-27TX Elite and it will make
Hi John,
Your standby power supply is good since you hear the click sound from the relay but I've suspect an open parts in line with the main voltage regulator section of the power supply. You have to check for open fusible resistor in line with the regulator IC/transistor, shorted/open voltage regulator IC/transistor. Also check for bad solder joints in that area. If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Also check if your unit is under warranty /extended warranty, avail it because the manufacturer of your unit will fix it for free. Don't open the cover, this will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
2/20/2011 6:04:09 AM • Pioneer VSX-27TX... • Answered on Feb 20, 2011
Pioneer Elite vsx-27tx receiver with no bass!?
There may be a subwoofer mute function on your amp. The sub out is nothing more than a preamp output with a low frequency response. It is meant to be amplified by an external amp. Either check your powered subwoofer for operation or look through your operators manual for a sub mute function.
2/12/2010 1:28:54 PM • Pioneer VSX-27TX... • Answered on Feb 12, 2010
RCA Model RT2500/RT2500R Audio/video Reciever
It may be only some tired capacitors in the power supply; they can cause this kind of problem.
Parts are probably the lesser cost; you will need a tech with a little bit of gear to find the culprits.
12/18/2009 7:06:03 PM • Pioneer VSX-27TX... • Answered on Dec 18, 2009
PIONEER VSX-27TX RECIEVER
Hi!
you can locate the R9371 & R9374 beside or the same circuit of the IC 9374 Very near not far to IC 9374.
11/23/2007 2:17:37 AM • Pioneer VSX-27TX... • Answered on Nov 23, 2007
No DTS sound / RESET
Hi I have a Pioneer VSX D908S which is basically the same amplifier as yours with the difference that the one I have has no THX certification, as a matter of fact the service manual is the same, and mine has the same problem. The prblem is located in the DSP board, if you are able to remove the bonett, you will see on the right side a metal cover, remove it, once you have removed it, look for a IC9374 it is located, -looking this board in front to you- almost at the left upper corner, this IC has the PDK042A on it, with a soldering iron resolder this circuit. This is common problem with this pioneer amplifiers, and this procedure not always works, the final solution is to buy the DSP board but it is expensive. Good luck! Miguel
10/7/2007 4:52:12 AM • Pioneer VSX-27TX... • Answered on Oct 07, 2007
Slow playing pioneer phonograph pl-202az
most record players use a rubber wheel against the turntable (on the inside) to turn it.. as they get old and brittle they tend to slip a lot. a temporary fix involves cleaning the rubber piece but it really needs replacing..
1/23/2023 4:25:36 PM • Pioneer Audio... • Answered on Jan 23, 2023
Pioneer VSA-5500 can switch on but no display and sound
It sounds like you are having an issue with your Pioneer VSA-5500 receiver not displaying or producing any sound. It's likely that the problem is related to a malfunctioning main control board or a power supply issue. Here are a few things you can try:
  1. Check all the connections between the main control board, power supply, and other components to ensure that they are properly connected and not loose.
  2. Check the fuse on the power supply board, make sure it's not blown, if it is, replace it with a new one.
  3. Check the voltage on the power supply board, make sure the voltage is correct, if the voltage is too low or too high, the main control board may not be receiving enough power to function.
  4. Check the power supply board for any signs of damage, such as burn marks or leakage, if the power supply board is damaged, it will need to be replaced.
  5. Check the main control board for any signs of damage, such as burn marks or leakage, if the main control board is damaged, it will need to be replaced.
  6. If none of the above steps resolve the issue, it's likely that the problem is with another component in the receiver and it will require further diagnosis by a professional technician.
It's important to note that troubleshooting and repairing electronic equipment can be dangerous, especially if you're not familiar with the device, so it's best to contact a professional technician if you're not comfortable working with it.
1/14/2023 9:40:59 AM • Pioneer Audio... • Answered on Jan 14, 2023
How to factory reset a pioneer VSX-d508
To factory reset your Pioneer VSX-D508 audio receiver, you will need to follow these steps: Turn off the receiver. Press and hold the "Tone" and "Speaker A" buttons on the front panel of the receiver. While holding these buttons, turn the power back on. When the display shows "Initialize," release the buttons. The receiver will now begin the factory reset process. When it is finished, the display will show "Completed." Turn the receiver off and then back on again to complete the reset. Keep in mind that this process will reset all of the settings on your receiver to their default values. You will need to reconfigure any settings that you have changed since you purchased the receiver.
1/8/2023 1:21:50 PM • Pioneer Audio... • Answered on Jan 08, 2023
Why can I get no sounds for my vintage vsx 5600 pioneer home theater system
There could be a few reasons why you are not getting any sound from your vintage VSX 5600 Pioneer home theater system. Here are some things you can try:
  1. Check the connections: Make sure all of the cables are securely connected to the appropriate ports.
  2. Check the power: Make sure the home theater system is turned on and the power cord is plugged in.
  3. Check the volume: Make sure the volume on the home theater system and the volume on your TV are turned up.
  4. Check the input: Make sure the home theater system is set to the correct input.
  5. Check the speakers: Make sure the speakers are turned on and properly connected.
1/8/2023 8:08:08 AM • Pioneer Audio... • Answered on Jan 08, 2023
How to reset Pioneer VSX-AX3 with no power?
It is not recommended to attempt to reset a device with no power. If the power is off, the device will not be able to respond to any commands or perform any actions. If your Pioneer VSX-AX3 is not turning on or functioning properly, there are a few things you can try before attempting to reset it:
  1. Make sure the device is properly plugged in and that the outlet is functioning properly.
  2. Check the power cord for any damage, such as frayed wires or loose connections.
  3. If the device is connected to a surge protector or power strip, try plugging it directly into a wall outlet.
  4. Try a different power cord or outlet to eliminate the possibility of a problem with the cord or outlet.
If none of these steps help, you may need to have the device repaired or replaced.
1/8/2023 4:41:14 AM • Pioneer Audio... • Answered on Jan 08, 2023
What is the "Pioneer RX-570" belt path?
Question edited to toss in some CAPS. Question moved from Cars and Trucks category. Service Manual links https://www.google.com/search?q=%22pioneer+rx-570%22+belt+replacement ..
1/1/2023 6:24:50 AM • Pioneer Audio... • Answered on Jan 01, 2023
2answers
How do I hook up Kenwood gge 7030 to my pioneer sx217?
To connect a Kenwood GE 7030 equalizer to a Pioneer SX-217 receiver, you will need to use the tape record out and in jacks on the back of the receiver. Here is a general outline of the steps you can follow to set up the connection:
Locate the tape record out and in jacks on the back of the receiver. These are typically labeled "TAPE MONITOR OUT" and "TAPE MONITOR IN."
Locate the tape in and out jacks on the back of the equalizer. These are typically labeled "TAPE IN" and "TAPE OUT."
Use a pair of RCA cables to connect the tape out jack on the receiver to the tape in jack on the equalizer.
Use another pair of RCA cables to connect the tape out jack on the equalizer to the tape in jack on the receiver.
Turn on the equalizer and set the volume and tone controls to your desired settings.
Turn on the receiver and select the tape monitor function. You should now be able to hear sound through the speakers.
If you are still having trouble getting the equalizer to work, it is possible that there is an issue with the cables or with one of the components. You may want to try using different cables or checking for any visible signs of damage on the components. If you are still having trouble, it may be helpful to consult the user manual for the receiver or the equalizer or to seek the assistance of a professional audio technician.
12/24/2022 6:21:55 PM • Pioneer Audio... • Answered on Dec 24, 2022
Pioneer VSX-27TX Receiver Logo
Popular Tags
13 questions posted
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
David Shaub
Steve
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Audio Players & Recorders
Most Popular Question
rca model rt2500 rt2500r audio video
  • Audio Players & Recorders
