20 Most Recent Pioneer VSX-D906S Receiver Questions & Answers
2answers
Have power to tuner but it powers down
This is most likely caysed by a sghorted power transistor.
7/6/2021 11:22:51 PM • Pioneer... • Answered on Jul 06, 2021
2answers
I just bought a used VSX-D906S and surround
DSP modes usually act on ANY input source, including stereo. Are you saying you have no surround speaker fucntions? Get in the setup and define, then adjust them.
8/19/2012 8:16:56 AM • Pioneer... • Answered on Aug 19, 2012
0answers
0answers
0answers
I have a VSX D710S and it flashes poweroff then
Im having this same problem. It happened after I had the music up really loud for about 3 hours. Also, where it has the volume all i see is -- instead of a number when i try to turn it on
7/14/2011 1:00:02 AM • Pioneer... • Answered on Jul 14, 2011
Got button happy on cable
Somewhere here you changed the input on your TV and or Pioneer. The TV audio output should be on the input of your Pioneer. Make sure that you change the input selection on the Pioneer to match where you have your audio input on the back of your Pioneer. So many of these devices have multiple inputs and outputs. They should be labeled on the back. Once you find that out you should then go to your remote and select the proper audio input from the menu. Let me know if that helps and we can try a couple other things. Also make sure your TV output from the tv is on to send it to the stereo unit.
6/16/2011 1:02:45 AM • Pioneer... • Answered on Jun 16, 2011
4answers
PIONEER RECEIVER VSX9700S REMOTE ISSUE
check your remote. try fresh batteries as well. if it still wont work, try opening your remote and clean it with a soft bristle brush or the like. try testing it again.
2/10/2008 8:42:57 PM • Pioneer... • Answered on Feb 10, 2008
How to turn on pioneer xv-ev61 when timer light is on and cannot do anything
There may be a problem with the stereo itself, or with the power supply. If the stereo is plugged into an outlet, try plugging it into a different outlet to see if that makes a difference. If the problem persists, you may need to consult a stereo repair specialist.
11/5/2022 1:18:49 PM • Pioneer Audio... • Answered on Nov 05, 2022
Remote to pioneer vsx-d412 I need this. Is there a universal remote
amazon HCDZ Replacement Remote Control for Pioneer AXD7246 XXD3038 XXD3039 VSX-D412 VSX-D412-K VSX-D412-S VSX-D309 Audio Video Multi-Channel Receiver
11/1/2022 11:06:38 PM • Pioneer Audio... • Answered on Nov 01, 2022
How do I get my new LG OLED 65C1PU TV to play through my old Pioneer VSX-D507S surround system?
Old technology and new technology often don't mix. Your television is new and geared up for Bluetooth and HDMI, your old surround sound system is composite video and audio. You need to test the television with something else, and then check the surround sound with a different input. If they both work then you know it is a compatibility issue. Your best bet is a new Bluetooth Sound Bar that is as good as the television.A similar issue was posted here yesterday, so you are not alone.https://www.fixya.com/support/t29896811-jvc_rx_6018v_not_working_tv..
10/28/2022 7:25:16 PM • Pioneer Audio... • Answered on Oct 28, 2022
Pioneer SVX 305. Cannot tune into radio station. Do I need to plug a tuner into this unit? I thought I could get radio reception directly.
Your pioneer receiver should pickup radio signals. Set the receiver to fm and make sure volume is up and mute is not on. Installing an antenna will bring in more stations.
10/27/2022 3:14:59 AM • Pioneer Audio... • Answered on Oct 27, 2022
No optical light from pioneer vsx516
Hi, Please double check that you've adjust the volume on the speaker and test sound with multiple sources (ie CDs, DVDs etc) to ensure that the volume/sound issue is cause by the speaker and not the item that it's attempting to play. You can also check for any disconnected wires going from or to the speaker. Thank you.
10/6/2022 1:32:48 AM • Pioneer Audio... • Answered on Oct 06, 2022
Pioneer VSX 934 automatically turn off with FL Off red light blinking
Have you solved ???? Thanks .. I have the same problem
10/3/2022 2:23:00 PM • Pioneer Audio... • Answered on Oct 03, 2022
Pioneer vsx-43 how to turn it of????
Smash it against the wall then buy a new unit from best buy, they have a great return policy.
9/25/2022 11:24:51 PM • Pioneer Audio... • Answered on Sep 25, 2022
3answers
Pioneer PDR-609 CD Recorder. -
I don't have a stand-alone cd recorder but like many people I have burned discs on the computer and had many disappointments. While some disc drives are clearly better than others, for no apparent reason, there does seem to be more reject discs with some software than others. Particularly disappointing is the Nero burning software that performs well when it is first installed but seems to deteriorate fairly quickly with every computer restart. I know nothing about such things so I am only guessing the cause might be that Nero displaces some Windows components and Windows seems to try repairing itself when booting. Like most things these days, especially digital things, your cd recorder is in fact a computer that depends entirely on the software loaded into it, software that could degrade or become corrupted over time. While it is possible the disc drive (laser perhaps) has become less potent it wouldn't be unreasonable to suspect the software and I suggest you contact Panasonic. It is probable, like many things requiring software, early versions were found to have problems and would be periodically updated.
9/22/2022 2:40:09 AM • Pioneer Audio... • Answered on Sep 22, 2022
Pioneer model PL-950 turntable stylus/needle help please
hiKNOW most technical words , as in difference of CARTRIDGE OR stylus (or needle) inside it, are not used clearlyThis page https://audiokarma.org/forums/index.php?threads/purchased-pioneer-pl-950-new-to-vinyl.543166/gives a cartridge substitute: "For cartridges I have seen many recommend the Audio Technica at-95e."Before buyin see- https://www.audio-technica.com/en-us/at95e for the cartridge.A needle only ebay- Enhanced Elliptical Stylus Needle Audio-Technica ATN95E AT95E Cartridge 710-DE
9/17/2022 6:49:10 AM • Pioneer Audio... • Answered on Sep 17, 2022
Pioneer VSX-D906S Receiver Logo
18 questions posted
Top Pioneer Audio Players & Recorders Experts
David Shaub
Steve
Morne Olivier
Morne Olivier
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Audio Players & Recorders
Most Popular Question
power tuner but powers down
  • Audio Players & Recorders
