20 Most Recent
Pioneer VSX-D407 Receiver Questions & Answers
Will not turn on
Have you tried to plug it in? if that doesnt work, try to see if any of the connection is fryed or clipped on the back.
Crackling Speakers
It sounds to me like an impedance mis-matching problem!!!
But it does seem you have done everything correctly so I cant offer any other suggestions - sorry!!!!
Components do not work
Yes there is bound to be at least one internal low-voltage fuse - so get inside with unit completely removed from any mains source!!
Good luck.
How to reset a pioneer vsx 456 receiver
To reset your Pioneer VSX-456 receiver, you can try the following steps:
Turn off the receiver.
Press and hold the "Enter" button and the "On/Standby" button simultaneously until "Reset" and "No" appears on your display.
Use the "Preset" arrow buttons to make the display say "Reset" and "Yes" .
Press the "Enter" button on the front panel to confirm .
If this does not work, you can also try unplugging all external devices before beginning the system reset. Switch the receiver into standby mode by holding down "Band" and then pressing and holding the "Standby/On" button for about two seconds. When you see "Reset?" on the display, press the "Preset" arrow buttons to make it say "Yes." Finally, press the "Enter" button on the front panel to confirm .
