20 Most Recent Pioneer VSX-D514 Receiver Questions & Answers
Sub not working
The sub pre out is for a small output signal which is to send a signal to a power amplifier which amplifies this signal to a level that will drive the subwoofer. the preamp out signal is not capable of driving a speaker without being amplified.
8/17/2017 6:28:29 AM • Pioneer VSX-D514... • Answered on Aug 17, 2017
App err
PDF]VSX-D414 VSX-D514 - Pioneer
www.pioneer-latin.com/downloads/xre3077a.pdf
Increase the separation between the equipment and receiver. - Connect the .....AUDIO/VIDEO MULTI-CHANNEL RECEIVER VSX-D514. RCE. VSB. MODE.
Pioneer VSX-D514 Receiver Repair Questions,... - Fixya
www.fixya.com > Forum > Audio & Video Receivers > Pioneer
Recent Pioneer VSX-D514 Receiver questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Audio & Video ...
app err Turns on then says amp err. - Fixya
12/26/2015 10:27:29 PM • Pioneer VSX-D514... • Answered on Dec 26, 2015
2answers
Overload...
Pioneer posted this on it's Canadian Web Site:
Poor wiring connections, bad wires or a bad speaker may cause this. As you increase the volume, you will increase the amount of current you are drawing from the receiver. To troubleshoot this issue, try the following:
  1. Disconnect each speaker wire connection. Inspect for any frayed or damaged wiring and replace it.
  2. Check the impedance of the speakers; make sure they are properly rated for your stereo. In most cases, they need to be 8 ohms. Only a few Pioneer receivers will support lower impedance.
  3. If the problem still continues, try these steps:
    1. Turn the receiver off.
    2. Remove one speaker.
    3. Turn the receiver on.
    4. Increase the volume.
If the receiver overloads, repeat steps 1-4 (selecting a different speaker each time). If you disconnect a certain speaker and the receiver no longer overloads, have this speaker checked at a service center. It could have a bad speaker component, like a tweeter, sub-woofer, or even a bad crossover.
12/26/2015 10:06:12 PM • Pioneer VSX-D514... • Answered on Dec 26, 2015
5answers
Receiver problem
Try this, it may work for you.
1.)Plug the unit into your mains voltage.
2.)Depress the enter and advanced surround buttons (on the front panel of receiver) at the same time for
at least 2 seconds, you should hear the relay tick and front panel should light up.
9/6/2015 3:23:37 PM • Pioneer VSX-D514... • Answered on Sep 06, 2015
How to reset
Press STANDARD and STANDBY keys simultaneously when the recvr is in standby mode.
6/16/2015 1:39:33 PM • Pioneer VSX-D514... • Answered on Jun 16, 2015
2answers
Losing configuration
I am not sure there is nothing that I can fined on the user manual but if you talk to your nearres electronics shop and see if there is any thing they can do
6/16/2015 1:36:32 PM • Pioneer VSX-D514... • Answered on Jun 16, 2015
0answers
How can I listen to just the radio?
Make sure you have an arial connected and select tuner
2/15/2014 11:26:52 PM • Pioneer VSX-D514... • Answered on Feb 15, 2014
0answers
I have bought Pioneer VSX D514 Receiver in 2006
any will work go to best buy
9/17/2013 11:35:20 PM • Pioneer VSX-D514... • Answered on Sep 17, 2013
Can you reset the reciever
Unplug it from the wall then with it unplugged, hold the power button for 30-45 seconds.
7/13/2013 9:51:06 AM • Pioneer VSX-D514... • Answered on Jul 13, 2013
Pioneer VSX-D514 Receiver Logo
40 questions posted
Top Pioneer Audio Players & Recorders Experts
David Shaub
Steve
Morne Olivier
Morne Olivier
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Audio Players & Recorders
Most Popular Question
just bought subwoofer
  • Audio Players & Recorders
