20 Most Recent Pioneer VSX-54TX Receiver Questions & Answers
You can connect some turntables to the VSX-54TX. The turntable needs to have a built-in phono equalizer; then you can connect it to the Line In connection. See page 26 of the manual for the details. The manual is available on the Pioneer product page: http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Elite+Receivers/VSX-54TX in the Manuals & Brochures section. The current direct link to the manual is http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/128163968VSX-54TX%20OPERATING%20INSTRUCTIONS.pdf .
I hope this helps. If you post a comment with the model of the turntable, I may be able to help identify if it has the built-in equalizer.
Pioneer VSX-54TX... | Answered on Nov 18, 2015
Try put a ground line from any metal of your stuff to the any metal direct to the ground. these eliminate noise of the speaker.
Pioneer VSX-54TX... | Answered on Nov 26, 2014
http://www.retrevo.com/support/Pioneer-VSX-54TX-Receivers-manual/id/385dj996/t/2/
Or maybe something is obstructing the rear panel ventilation device (or it has failed). Page 84
I had a problem recently after a power outage where both my receiver and an external amp would not power up until I unplugged them from the wall for a moment first.
Pioneer VSX-54TX... | Answered on Aug 25, 2012
The unit is not making any noise or no lights on, shows the problem with the power supply of the unit. Take the cover of the unit off and look at the power supply board and see if you can find a fuse ( If it has a fuse) that's the first thing you can look at, if there is no fuse or fuse is intact it shows a burnt power IC, which requires to be replaced by a professional technician. Hope it helps and comment if you need more clarification. Best
Pioneer VSX-54TX... | Answered on Mar 01, 2010
Check your tv settings may need to change from speaker out to line out.
Check the tv input on the receiver, put the cd or dvd cables into the tv input. If you get audio the receiver is fine. No audio check the receiver settings.
Pioneer VSX-54TX... | Answered on Nov 16, 2009
IF nothing lights up and you are sure that the power outlet is working correctly (some power outlets are wired to be switched on and off by a wall switch so be sure that the power source is NOT the problem) then you may be busted. Check for fuses; I dont know this specific unit, but most power amps have some sort of inline fuse. If that doesnt get it, I would call PROTON and have them send you a new one.
r
Pioneer VSX-54TX... | Answered on Sep 24, 2009
Jan said: You've not made the problem clear. The sound "pauses" every fifteen seconds? For how long and what happens when it comes back? Which DTS decoder are you using and which connection between player and amplifier have you decided to use?
Pioneer VSX-54TX... | Answered on Mar 30, 2006
Using All Zone Standby; Setting The Switching Time For The ...
https://www.manualslib.com > Pioneer-Elite-Sc-91
Pioneer Elite SC-91 Manual Online: using all zone standby, Setting The Switching Time For The Receiver Operation Mode, Resetting The Remote Control ...
Operating Instructions - Pioneer Electronics
https://www.pioneerelectronics.com > PUSA > Manuals
PDF Increase the separation between the equipment and receiver. - Connect the ... Using the SR+ mode with a Pioneer flat panel TV . ... Plug the power cable into the AC outlet and switch on the receiver.1 Make ... See Automatically setting up for surround sound (MCACC ... 4 Optical and coaxial digital audio inputs (x7 (SC-07),.
AV Receiver - Pioneer Electronics
PDF The STANDBY/ON switch on this unit will not completely shut off all ... Plugging in the receiver . ... Automatically conducting optimum sound tuning (Full Auto MCACC) . ... Setting the switching time of AV amplifier operation mode. ... On a Mac, launch Safari and click <SC-85> displayed in 'Bonjour' on the Bookmarks bar.
https://www.pioneerelectronics.ca > Manuals > Home
PDF Before plugging in for the first time, read the following ... The STANDBY/ON switch on this unit will not ... Connecting a satellite/cable receiver or other set-top box . ... Switching on/off the Acoustic Calibration EQ, Auto Sound Retriever or Dialog ... For the SC-65, the optional AS-BT200 Bluetooth adapter works together with ...
Pioneer Audio... | Answered on Feb 07, 2021
https://www.prokr.net/ksa/al-riyadh-anti-insect/
Pioneer Audio... | Answered on Feb 06, 2021
A lot of audio and studio equipment is SMT now and is not easy to work on. It could be a CPU or any of a number of issues with finals, capacitors etc.
Pioneer Audio... | Answered on Jan 25, 2021
Pioneer VSX-54TX Receiver Logo
Popular Tags
9 questions posted
Top Pioneer Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
Jax Planet
Jax Planet
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Audio Players & Recorders
Most Popular Question
pioneer vsx 54 tx
  • Audio Players & Recorders
