20 Most Recent EZInfo Imperial to Metric Conversions Questions & Answers
2mm is about 0.0787 inches.
EZInfo Imperial... | Answered on Sep 03, 2014
You can do it online here :
www.initium.demon.co.uk/converts/metimp.htm
Regards
EZInfo Imperial... | Answered on May 11, 2011
Hello
Here ia a link that may help.
http://www.ookingdom.com/metric/factors
EZInfo Imperial... | Answered on Mar 28, 2011
0,787 inches to 3,15 inches thank's for choosing fixya
EZInfo Imperial... | Answered on Aug 30, 2010
Windows Back up Files are by nature OS selective but are stored on portable systems.
Have a look here; https://fileinfo.com/extension/bkf
Computers &... | Answered 1 hour ago
get friendly with google
Computers &... | Answered 2 hours ago
Yes, I agree with you, this is not my fault but I am tired of this issue. How can I resolve it?
The Error Code oxc0000225 shows up after an update from OS, including upgrading from Windows 7 to Windows 10. The issue is the incorrect system disk. This can even happen if the PC turns off system files or even faulty equipment after a significant upgrade. You can't fix this problem from the inside of Windows, like other boot mistakes. But you would need to get a convenient Windows 10 disk upgrade tool for repair.
Just go through the link of a blog and follow the procedure.
View the blog:-
Computers &... | Answered 8 hours ago
You can't remove your MYSTERY program from a Command Prompt.
Reinstall the program, reboot and then go to Settings - Apps and Features, and remove it from there. Highlight the Program and click Uninstall.
If it is a complex program like AV, you often need to use removal clean-up software from the AV Vendor site.
It appears to be a known issue!
https://www.google.com/search?q=remove+program%2C+but+keep+getting+error+5
Computers &... | Answered 15 hours ago
I believe that is the Diamond Extreme XS51 sound card.
Try this location for drivers:
https://www.diamondmm.com/product/xs51-diamond-xtremesound-sound-card/
Computers &... | Answered 18 hours ago
I would recommend you boot the computer in Safe mode and see if the issue persists.
If the issue does not occur in Safe mode than it is probably some third part application that is interfering with the normal performance of the computer. You will need to disable or uninstall the same to regain the normal performance of the computer. To do so perform a Clean boot.
To perform a Clean boot on a computer that is running Windows 7, follow these steps.
1. Click Start, type msconfig in the Start Search box, and then press ENTER.
If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
2. On the General tab, click Selective Startup.
3. Under Selective Startup, click to clear the Load Startup Items check box.
4. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
5. Click OK.
6. When you are prompted, click Restart.
7. After the computer starts, check whether the problem is resolved.
10 Solutions to Fix Windows Explorer Has Stopped Working Error
Computers &... | Answered 23 hours ago
google
continents of Earth
It's probably not plugged in or the wall socket has run out of electricity?
Don't worry, our resident Computer Guru Larry will be along shortly. He will be able to fix it, even with no details :>)
The Dell error code 0141, also known as error code 2000-0141, is an error you might see on your Dell PC. ... Error code 0141 means that your PC can no longer detect your hard drive. No hard drive means no operating system and no data. No operating system means you can't use your computer.
Remove any CD/DVD from the drive and try again.
Check the correct hdd type and system is set within your BIOS settings. Check the hdd is set as first boot option.
Did you have spurious messages over the last few weeks ... if so your hdd has failed and you need a new one.
Computers &... | Answered 2 days ago
Word by either Microsoft or the better free ware version Open Office is a document reader/writer. Load the document and adjust as you want then save on exiting when you are happy with the result.
The converged network adapter used to add networking capabilities and can be wired, wireless, or serving dual wired/wireless roles. A network adapter must be compatible with the wireless network standard used. In many instances, the converged network adapter supports DPDK with benefit for packet processing acceleration. I think will be very good for your computer as it reduces needed power, fewer necessary cables and overlays network hardware offload
Follow these steps to run the chkdsk tool:
  1. Type cmd in the search box.
  2. Right-click on Command Prompt from the results list.
  3. Choose Run as Administrator.
  4. In Command Prompt type: chkdsk C: /f /r. Replace C: with the letter of the drive where Windows is installed.
  5. Hit Enter.
Read this for more
How To Fix Kernel Data Inpage Error in Windows 10?
Also use a PC optimization software to make your windowsOS run faster and keep your PC/laptop safe from viruses, trojans and malware and it also help to declutter the junk files from your windowsOS. I suggest to use PC optimizer
Make sure that you're Outlook Profile or any other of its parent's folder are not in the privacy tab of the Spotlight. If your Outlook Profile or any of its parent folder are displayed in the Spotlight privacy tab then Spotlight is unable to search. So then remove them from the privacy tab of Spotlight and try again.
You don't worry you can visit and get the list of top 20 the best HD Sector proxy site list.
Vsit:
https://www.allneedy.com/top-20-best-hdsector-proxy-and-unblock-sites/
Computers & Internet Logo
5 questions posted
Popular Products
Top EZInfo Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an EZInfo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EZInfo Computers & Internet
Most Popular Question
convert metric imperial
  • Computers & Internet
