20 Most Recent Pioneer CT-05D Single Cassette Deck Questions & Answers
2answers
My pioneer ct-05d dual cassette player works find all controls or functional but the problem begin when i play atape there is a constant humming noise that is present as long as the tape is playing b
There can be bad solder joints and or bad grounding in the unit. A Technician will know how to fix this.
7/12/2014 10:24:41 PM • Pioneer CT-05D... • Answered on Jul 12, 2014
Pioneer DJM 600 Mixer: Disaster! Power Supply KO to Effect Board and Potentiometer Board
Replace the power supply.
4/12/2024 5:38:08 AM • Pioneer Audio... • Answered on Apr 12, 2024
The left channel on our Pioneer VSX-D409 is weak. Some sound is coming through, but very little. We have double checked the wire and the connection in back. Everything there is kosher. Any ideas?
Check the balance control. Apart from that the unit will have to be checked internally to ascertain where the signal is breaking down. This will require some skill and some equipment. My guess is it will be a dry solder joint or a dried out capacitor. If a capacitor looks 'leaky' or swollen, it is a good bet it is outside its tolerance and should be replaced. Sorry couldn't be any better help. Good luck.
2/23/2024 6:02:48 AM • Pioneer Audio... • Answered on Feb 23, 2024
My Pioneer VSX 1021-K won't respond to remote. How do I access Home Menu, System Setup, and Remote Control Mode Setup without the remote and using only the buttons on the front of the receiver?
You can't!Change the batteries in the remote and look at the front of the remote using the front facing selfie camera on a smartphone. Press the power button and see if you see a red or blue flash. If you don't see light the remote has failed.You can't do any advanced features without it. You can get a replacement.Replacement Remote Control for Pioneer VSX-1121 ...Amazon.cahttps://www.amazon.ca > Replacement-VSX-1121-VS...Replacement Remote Control for Pioneer VSX-1121 VSX-1021 VSX-1022K VSX-1020K VSX-818V VSX-522 VSX-523 VSX-517 VSX-520-S A/V Receiver Brand: MONSIATUG ; Sold by. Rating: 5 · ‎ 3 reviews · ‎ $19.95 · ‎ In stockUniversal Replacement Remote Control for Pioneer VSX ...Amazon.cahttps://www.amazon.ca > Universal-Replacement-VSX...Universal Replacement Remote Control for Pioneer VSX-9140TXH AXD7525 VSX-1021 VSX-1021-K 7.1-Channel Home Theater AV A/V Receiver System ; Ships from. Sure-Win.Rating: 4.7 · ‎ 8 reviews · ‎ $32.26 · ‎ In stockpioneer vsx-1021-k remote for saleeBayhttps://www.ebay.ca > schRemote Control For Pioneer A/V Receiver VSX-1021 VSX-1021-K VSX-47TX VSX-D939TX. Brand New. C $18.37. Was: C $19.33 5% off. Buy It Now. +C $5.26 shipping...
2/8/2024 10:40:49 PM • Pioneer Audio... • Answered on Feb 08, 2024
Pioneer SX-R9 Stereo AM/FM Receiver. The select function CD, MD, TUNER, AUX is not working. How I can fix this?
Question edited for clarity and typo, remove .. dramatics ...... Duplicate question Deleted. Refresh page to see your question.
Pioneer SX-R9 Service Manual
ManualsLib https://www.manualslib.com > ... > Amplifier > SX-R9 View and Download Pioneer SX-R9 service manual online. Stereo Tuner amplifier. SX-R9 amplifier pdf manual download. Or find a local audio technician.
12/22/2023 2:58:20 AM • Pioneer Audio... • Answered on Dec 22, 2023
I have a Pioneer VSX-1019AH Receiver and I cant get my Optical input from tv to work
See page 6 of user manual. It tells the sequence of initial setup. See page 23 of user manual. It tells TV and Playback connections and setting up your devices. See page 102 for troubleshooting. XRB3109A (pioneerelectronics.com)
12/17/2023 11:14:56 AM • Pioneer Audio... • Answered on Dec 17, 2023
What speakers work with a Pioneer PD-M403 cd player?
A PD-M403 is a CD player, nothing else and you require an amplifier to drive a loudspeaker unless you have a 'powered' loudspeaker.
11/28/2023 5:28:32 PM • Pioneer Audio... • Answered on Nov 28, 2023
How to reset a pioneer vsx 456 receiver
To reset your Pioneer VSX-456 receiver, you can try the following steps: Turn off the receiver. Press and hold the "Enter" button and the "On/Standby" button simultaneously until "Reset" and "No" appears on your display. Use the "Preset" arrow buttons to make the display say "Reset" and "Yes" . Press the "Enter" button on the front panel to confirm . If this does not work, you can also try unplugging all external devices before beginning the system reset. Switch the receiver into standby mode by holding down "Band" and then pressing and holding the "Standby/On" button for about two seconds. When you see "Reset?" on the display, press the "Preset" arrow buttons to make it say "Yes." Finally, press the "Enter" button on the front panel to confirm .
10/27/2023 9:56:48 PM • Pioneer Audio... • Answered on Oct 27, 2023
How to reset a vintage pioneer cass./fm radio mod, # keh-m3000skd
there is no set. unit need to be repaired.
10/25/2023 9:00:13 PM • Pioneer Audio... • Answered on Oct 25, 2023
Pioneer PL-50A turntable manuals
9/13/2023 1:04:14 PM • Pioneer Audio... • Answered on Sep 13, 2023
Hello, I have a LG TV 65UH6030 and I'm trying to get surround sound working through my Pioneer Elite amp. John
Check the output of the sound of the TV. Check it is output the right sound signal IE: Dolby or whatever the amp can use.
9/7/2023 7:51:32 PM • Pioneer Audio... • Answered on Sep 07, 2023
Pioneer receiver sx218 push power on clicks but nothing in front or any other sounds any ideas
If your Pioneer SX-218 receiver is not producing any sound or showing any indication of power, despite hearing a clicking sound when you push the power button, there could be a few potential causes for the issue:
  1. Power Supply: Verify that the receiver is properly connected to a working power outlet and that the power cable is securely plugged in. Check for any loose connections or damaged power cords. Try plugging the receiver into a different power outlet to eliminate the possibility of a faulty outlet causing the issue.
  2. Protection Mode: Some receivers have built-in protection mechanisms that activate in case of a fault or short circuit. This can cause the receiver to shut down and not produce any sound. Check for any obvious issues, such as loose speaker wires or a shorted speaker. Disconnect all speakers and peripherals from the receiver, then power it on to see if it starts up. If it does, gradually reconnect the speakers and peripherals one by one to identify any potential issues.
  3. Speaker Impedance: Ensure that the speakers connected to the receiver have the correct impedance rating compatible with the receiver's specifications. Using speakers with impedance levels outside the recommended range can cause the receiver to go into protection mode or produce no sound.
  4. Reset the Receiver: Perform a factory reset on the receiver to eliminate any settings-related issues. Refer to the user manual or the manufacturer's website for instructions on how to reset your specific model. Keep in mind that a factory reset will erase any custom settings and configurations, so you may need to set up the receiver again afterward.
  5. Internal Component Fault: If none of the above steps resolve the issue, it's possible that there may be an internal component failure in the receiver. In such cases, it is recommended to contact Pioneer customer support or consult a qualified technician for further diagnosis and repair.
Remember to consult the user manual for your Pioneer SX-218 receiver for specific troubleshooting steps and instructions tailored to your model. If you are unsure or uncomfortable performing any troubleshooting steps, it's best to seek professional assistance to avoid causing further damage to the receiver.
7/15/2023 1:40:49 PM • Pioneer Audio... • Answered on Jul 15, 2023
How to program my sanyogxdb remote to w ok rk my pioneer elite vsx 33 rece v er
To program your Sanyo GXDB remote to work with your Pioneer Elite VSX 33 receiver, you can try the following steps:
  1. Turn on the Pioneer Elite VSX 33 receiver manually using the power button located on the receiver itself.
  2. Hold down the "Code Search" button on your Sanyo GXDB remote until the LED light on the remote stays lit or blinks.
  3. Press the "TV" or "DVD" button on the remote, depending on which device mode you want to program the receiver to.
  4. Enter the corresponding code for Pioneer receivers. You can find a list of Pioneer remote control codes in the instruction manual that came with your Sanyo GXDB remote or by searching online. Enter the code using the number buttons on the remote.
  5. Point the remote at the Pioneer receiver and press the "Power" button. If the receiver turns off, it means the remote has been successfully programmed. If not, repeat the process using a different code from the list until you find the one that works.
  6. Once the remote successfully turns off the receiver, press the "Code Search" button again to save the code. The LED light on the remote should turn off or stop blinking.
  7. Test the remote by pressing other buttons, such as volume up/down or channel up/down, to ensure it is functioning properly with your Pioneer Elite VSX 33 receiver.
If you're still having trouble programming the remote, consult the instruction manual that came with the Sanyo GXDB remote or contact Sanyo customer support for further assistance.
7/15/2023 1:40:04 PM • Pioneer Audio... • Answered on Jul 15, 2023
Pioneer vsx-902 receiver comes on but No display.
I am assuming the receiver is new. In this regard, if the Pioneer VSX-902 receiver is turning on but you're not seeing any display, here are some troubleshooting steps you can try:
  1. Check the video connections: Ensure that the HDMI, component, or other video cables are securely connected between the receiver and your display device (such as a TV or projector). Make sure the cables are inserted properly and that they are in good condition. Try disconnecting and reconnecting the cables to ensure a secure connection.
  2. Verify the input and output settings: Check that the receiver's input source is correctly selected. Use the remote control or front panel buttons to cycle through the different input options until you find the one connected to your video source. Additionally, confirm that the output settings of the receiver are properly configured to match your display device.
  3. Check the display settings: Some receivers have options for adjusting the display settings, such as brightness, contrast, or resolution. Check the receiver's on-screen menu (if available) or refer to the user manual to access the display settings and make sure they are properly configured.
  4. Perform a factory reset: Try performing a factory reset on your Pioneer VSX-902 receiver. This can often resolve any software-related issues that may be affecting the display. Refer to the user manual for instructions on how to perform a factory reset specific to your model.
  5. Test with a different display device: If possible, try connecting your receiver to a different display device (such as a different TV or monitor) to determine if the issue lies with the receiver or the original display. This can help narrow down the problem and identify if it's related to the receiver or the specific connection or settings with the original display.
If none of the above steps resolve the issue, it's recommended to contact Pioneer customer support or consult a professional technician for further assistance.
7/2/2023 4:30:15 PM • Pioneer Audio... • Answered on Jul 02, 2023
Hard reset pioneer cdj 400
To perform a hard reset on a Pioneer CDJ-400, follow these steps: 1. Turn off the CDJ-400 by pressing the power button located on the front of the unit. 2. While holding down the Eject button (located on the top left of the CDJ-400), turn on the power switch. 3. Continue holding the Eject button until the display shows "PIONEER CDJ-400." 4. Release the Eject button. 5. Press and hold the Track Search Forward (">>") button and the Track Search Backward ("<<") button simultaneously. 6. Keep holding these buttons until the message "Resetting All Data" appears on the display. 7. Release the Track Search buttons. 8. The CDJ-400 will perform the hard reset and return to its factory default settings. This process may take a few moments. 9. Once the reset is complete, the CDJ-400 will restart. Please note that performing a hard reset will erase any custom settings or saved data on the CDJ-400. Use this option with caution and make sure to back up any important data before proceeding.
6/14/2023 6:11:25 PM • Pioneer Audio... • Answered on Jun 14, 2023
I have a pioneer pd-F 505 25 disk cd changer
Try an known good CD that works in other CD players
6/4/2023 1:58:11 PM • Pioneer Audio... • Answered on Jun 04, 2023
2answers
Pioneer RX 590 Dual Cassette Deck. I am looking for a replacement belt kit and it looks like they don't make them anymore. Is there anything I can use for a substitute?
Question edited for clarity and correct order, 'make model (what it is)' plus spelling of 'dual'. There are two prospects here including a place that makes custom belts'. The RX-541 may fit. https://www.google.com/search?q=Pioneer+RX+590+Dual+Cassette+Deck+belt+kit ..
6/2/2023 1:14:48 AM • Pioneer Audio... • Answered on Jun 02, 2023
I own an Pioneer CD
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
The service manual is available for free after you register here...
http://www.hifiengine.com/manuals/pioneer/m-l11.shtml
5/19/2023 2:37:50 PM • Pioneer Audio... • Answered on May 19, 2023
Pioneer CT-05D Single Cassette Deck Logo
1 questions posted
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Audio Players & Recorders
Most Popular Question
pioneer ct 05d dual cassette player
  • Audio Players & Recorders
