20 Most Recent EliteGroup L7VMM2 Motherboard Questions & Answers
Can u possibly tell me
check your PC make/website of your BIOS
2/3/2018 8:19:40 PM • EliteGroup... • Answered on Feb 03, 2018
You can download the following drivers for your
TRY NEWEGG.COM
6/23/2017 7:46:07 AM • EliteGroup... • Answered on Jun 23, 2017
0answers
Audio driver WINDOWS 7
http://www.innovative-sol.com/drivermax/GOOD DRIVERPROGRAM.DO A SCAN.
6/14/2013 4:43:54 AM • EliteGroup... • Answered on Jun 14, 2013
Upgrade the 1.6GHz CPU on L7VMM2 Motherboard
ECS Support > L7VMM2 motherboard > Main Support page,http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=419&CategoryID=1&MenuID=50&LanID=0Click on the CPU tab.(Features / Specification / Download / Support / FAQ / CPU / etc)Will support Up To an AMD Athlon XP 2600+,http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessorsMaximum Front Side Bus support is 266Megahertz.(Max FSB = 266MHz)(Motherboard manual states 133MHz.Note that AMD processors are 'Double-pumped'.This = 266MHz )Supports AMD Athlon, AMD Athlon XP, and AMD Duron, processors.Note in the CPU Support chart where it states -Socket 462 > AMD Athlon XP > 2600+ (.13u)The .13u stands for 130nm core architecture technology.(nm = NanoMeter. 1 Billionth of a Meter )NOTE*For the Socket 462 (Socket A) processors, the AMD Athlon XP models are the top of the line.'Sempy', or Sempron processors are at the bottom.Low L2 processor memory cache compared to Athlon XP or Duron models.http://en.wikipedia.org/wiki/List_of_AMD_Duron_microprocessorshttp://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessorshttp://www.cpu-world.com/http://www.cpu-world.com/CPUs/K7/TYPE-Athlon%20XP.htmlRegards,joecoolvette
10/16/2012 7:47:13 PM • EliteGroup... • Answered on Oct 16, 2012
Buna ziua ! am o
uite aici
clic pe Downloads si acolo o sa le gasesti pe toate;
nu uita sa accepti raspunsul si sa dai o testimony.
2/21/2011 8:36:25 AM • EliteGroup... • Answered on Feb 21, 2011
Mi problema es cuando prendo mi pc no arranca
Verifique la tarjeta de video or replace the memory
1/7/2011 11:18:09 PM • EliteGroup... • Answered on Jan 07, 2011
I get error messages in
You can try fixing the problem by first dismantling all the connecting cables specially the cable that connects your hard drives and other removable disks to the mother board. Clean the terminal pins to both connectors, make sure that its free from dusts and dirt. Reassemble everything and see to it that they are properly connected before running your PC.
10/30/2010 5:52:12 AM • EliteGroup... • Answered on Oct 30, 2010
2answers
Computer just beeps.... will not boot up....
Test your PSU or replace it
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
good luck
8/27/2010 8:13:56 PM • EliteGroup... • Answered on Aug 27, 2010
I need the download site
8/13/2010 6:59:58 AM • EliteGroup... • Answered on Aug 13, 2010
2answers
New power supply does not work...is it the motherboard
well there are two ways to to figure out which item is broken first you can hook up the power supply and test the pins in the plug with a voltage tester to see if it has power. I do not recommend this approach if you are unsure of what you are doing the voltage coming from a computer power supply is very dangerous. the second thing you could do is attach a different power supply to *********** board if ti works the mother board is good and it your power supply that is busted. Also make sure to check the back of the power supply and make sure it is set to 110 and 220 voltage because this can cause your power supply to not function correctly. It will be a little red switch on the back that says 110v on one side of it and 220v on the other.
I hope this helped.
Thank you,
Norse
7/3/2010 4:25:48 PM • EliteGroup... • Answered on Jul 03, 2010
Code 10 for the floppy drive windows xp emachine
Your Windows XP needs updating.
See this link:
http://support.microsoft.com/kb/894480
4/5/2010 5:37:18 PM • EliteGroup... • Answered on Apr 05, 2010
Can I put a 4x/8x AGP card on this motherboard?
The AGP (graphics port) only takes 4x on this motherboard, you can upgrade the memory as far as 2 gig, so yes you can upgrade the memory to 1 gig pc2100.
3/31/2010 3:23:49 PM • EliteGroup... • Answered on Mar 31, 2010
I have a L7VMM2 - Rev 2 motherboard with a Athlon
Have you checked the posibility of 512 Mb limit per slot for your motherboard? This is often at some older mobos. The manufacture page for your mobo is here check the revision you own.
Stelios.
2/22/2010 10:23:49 AM • EliteGroup... • Answered on Feb 22, 2010
I need hel With my Emachines T2085, What would be
It really depends what you're going to be using the computer for. It is suggested that you have at least a minimum 1 GB of RAM if you're using Windows XP. If you want to find out which RAM is compatible, try using Crucial's website.
2/9/2010 7:40:22 AM • EliteGroup... • Answered on Feb 09, 2010
Cannot change the bios
remove the jumper to clear/reset bios - or take out batter - refer to your manual or go the elitegroup website for details.
2/5/2010 3:47:50 PM • EliteGroup... • Answered on Feb 05, 2010
EliteGroup L7VMM2 Motherboard Logo
67 questions posted
Top EliteGroup Computers & Internet Experts
Muzahura Frank
Mehandi Husain ...
Narseman
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
mother board support vista or win7
  • Computers & Internet
