20 Most Recent ITT Night Quest 5001 Goggles Questions & Answers
I have an/pvs-7b night vision and need to replace my battery cap. The metal piece in side broke off???
Considering many vendors who sell parts are going to have a minimum order, Night Vision Depot for example has a 100 dollar minimum; you might consider trying to repair your old one or fabricating a new one. Otherwise checking on Ebay for one. On the other hand if you can fabricate a new one easily, you might consider being a vendor of that part too as you would not be the only person to encounter that dilema.
7/20/2019 7:19:40 PM • ITT Night Quest... • Answered on Jul 20, 2019
In network security + acronyms what is 3DES and definition
Triple Data Encryption Standard (DES) is a type of computerized cryptography where block cipher algorithms are applied three times to each data block. The key size is increased in Triple DES to ensure additional security through encryption capabilities. Each block contains 64 bits of data. Three keys are referred to as bundle keys with 56 bits per key. There are three keying options in data encryption standards:
  1. All keys being independent
  2. Key 1 and key 2 being independent keys
  3. All three keys being identical
Key option #3 is known as triple DES. The triple DES key length contains 168 bits but the key security falls to 112 bits. What is Triple DES Definition from Techopedia
6/5/2014 12:14:44 AM • ITT Night Quest... • Answered on Jun 05, 2014
I need a manual for
Great looking product - GEN3 - much better than the Night Owl stuff from 5 yrs ago.
Not sure if you can obtain a manual for a product that is restricted by ITAR regulations. I thought these were MIL use .
The only thing I can find is a SPEC link like :-- Operators Manual. CALL US TODAY AT: Toll Free 1-800-424-8222 http://www.morovision.com/pdf/2006/ITT_NQ5001.pdf
A reset is usually any method of disconnecting the power supply for at least 3-5 secs so the sensor can discharge into ground. Just removing the batteries should do this. -- Ray
1/22/2011 7:52:01 AM • ITT Night Quest... • Answered on Jan 22, 2011
0answers
0answers
2answers
Please teach me how to install IT 310 wc driver
Let me asl a few questions. Whay type of night visison devise do you have? Second, what is IT 310 wc driver installer? How old is the NV devise? stewbison
12/20/2013 11:11:36 AM • ITT Optics • Answered on Dec 20, 2013
0answers
0answers
0answers
I have a model F4975 monocular. How do I get to
Hello, do you have the ITT mini monocular? If yes, there should a cap about the size of a quarter with a slot cut into. Use a coin and unscrew the cap. I thank these mini uses button batteries but I am not sure. I don't get to see to many ITT stuff they so expensive. I'm cheap.. GB...stewbison
9/7/2011 3:29:36 AM • ITT Optics • Answered on Sep 07, 2011
I have a ITT nightquest
Jello, It a very nice night scope then and even to day, it American made. Those ITT 1st generation image intensifier tube have a life of about 10K hours+. If it had a few exposures to bright lights this will take a way from the life of the tube.
The only way to trouble shoot the problem is to take it parts. ITT will not provide any information on this Nightqest NV devise. You'll need someone the knows electronic in depth, troubleshoot solid state devise, and make HV ingitors for the tube in thousands of voltage. The problem could a simple passive component to the image intensifier tube has quit. Expensive to repair if the tube is bad. stewbison
8/3/2011 3:44:29 AM • ITT Optics • Answered on Aug 03, 2011
0answers
Pc ibm why it is so expensive?
IBM's are very good quality. I have an older IBM that I have been using for about 6 years now. It's actually much faster than most of those new computers.
6/19/2009 7:02:52 AM • ITT Optics • Answered on Jun 19, 2009
ITT Night Quest 5001 Goggles Logo
5 questions posted
Top ITT Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you an ITT Optic Expert? Answer questions, earn points and help others
View Most Popular
ITT Optics
  • ITT Optics
Most Popular Question
in network security acronyms 3des
  • Optics
