20 Most Recent Spectra KT2114 Television Questions & Answers
You will need to go back into the menu and see what ia available in the video input mode. You may have switched the type of input you can use such as default or componts ect. If you have an isntruction manual, look in there or call the manufacturer, should also be in the instruction or user manual. Good Luck
Spectra KT2114... | Answered on Oct 13, 2008
IT WAS A SYSTEM CONTROL PROBLEM AND YOU NEED HELP OF A TECHNICIAN IF YOU WANT TO RMOVE IT
Spectra KT2114... | Answered on Aug 27, 2007
Try go tru the manual perhaps u can get back to default setting and I hope the manufacturer too should be of help.
Spectra KT2114... | Answered on Jun 01, 2007
First and foremost, is it completely black or if you change the channels (like to an HDMI channel) do you see the display number in the corner? If the latter, then it's possible that the device(s) you have plugged into it, or the HDMI port went bad. Doubtful that is the problem, but I thought I would mention it first.
Try unplugging it and leaving it unplugged overnight. When you plug it back in do you have a picture? Probably not, but it's worth a try.
Beyond that, there are a couple of things that can be wrong:
Loose wiring - these TV's are really well known for loose wiring. If you feel competent enough to take the back off the TV, you can check for loose wiring
Bad capacitor's - these TV's also have really poor quality parts inside and a bad capacitor (or multiple bad capacitor's) can cause the same thing. Again, if you feel competent enough to take the back off the TV, you can look for bulging or leaking capacitors, they look sort of like a dripping or draining battery or bulging battery to someone not used to looking at them
Smacking the back of the TV - this one sounds weird, but sometimes smacking the backside of the TV will knock whatever came out of place back into place and it will start working again
Bad bulb - sometimes the bulb goes out, and a bulb is an inexpensive fix, but you'll need a TV repair shop to do the repair (unless you know something about TVs)
Worst case scenario - worst case scenario would be a burnt out board which can cost more than a new TV, especially of this brand
I don't recommend you open the TV unless you feel comfortable. It's high voltage back there and can result in injury if you don't know what you are doing. Additionally, there are some problems that can be fixed by watching You Tube videos it tells you how to diagnose the problem, what to purchase, etc. You might want to research such videos, if you feel comfortable doing the project yourself.
Spectra... | Answered on Apr 05, 2017
I also have a 32' Protron LCD TV and had the same problem. Try this, it worked for me.
Push the TV button once, then press and hold the Setup button untill TV button flashes two times (aboutut 3-5 seconds) now enter this code 10178. TV button should flash two more times. Now your remote should work your TV. Good Luck!!!
Televison &... | Answered 2 hours ago
Your TV must be connected to the Internet - through a wired or wireless network - in order to perform system updates. Alternatively, you can download the updates to a USB flash drive, and install the update on the TV via USB
To check whether the Automatically check for update or Automatic software download setting is turned ON or OFF, follow these steps:
  1. Press the HOME button on your remote control.
  2. Select Help.
    For Androidâ„¢ 9 / Android 8.0, select Apps, then select Help.
    NOTE: You can also display the Help screen by pressing the HELP button on the remote control.
  3. Select System software update.
Televison &... | Answered 16 hours ago
The player came with a Firmware-Upgrade-CD which made it ready to play all region codes.
Televison &... | Answered 18 hours ago
Chunghop 133E
TCL- 051, 053, 068,071,073,082, 083, 084, 085, 110, 111,144, 156
199, 209, 216, 243, 244, 245, 246, to 249
Panasonic- 020, 001, 002, 014, 015, 021, 022, 059, 066
SONY- 041, 049, 005, 094, 106, 148, 237, 238, 239, 240
JVC- 089, 161
Goldstar- 009, 019, 023, 024, 040, 043, 098, 140
Hope this helps!
diane
If you have child lock on a logic tv. On your remote the bottom where the button is music / sound. Hold in for 5 minutes and the lock will come off
Televison &... | Answered 19 hours ago
If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important
Televison &... | Answered 20 hours ago
Try unplugging it from the outlet for a few minutes. It may reset itself.
Televison &... | Answered Yesterday
Spectra KT2114 Television Logo
3 questions posted
Top Spectra Televison & Video Experts
mikemail1
Tom Chichester
Duarte Giron
Duarte Giron
Are you a Spectra Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Spectra Televison & Video
Most Popular Question
strange menu
  • Televison & Video
